.NET
Active Contributor
MGOMKD
Message 1 of 5 (149 Views)
Instance Forms in several drawings
149 Views, 4 Replies
04-24-2012 01:49 AM
Hi All,
I'had just met another matter for my Add-on. I noticed that when I instance a new drawing, while a first one is opened, when I load a new Form, this one keep all first drawing's properties. What could happen?
For example, I would like to add the layer list on a ComboBox.
My source:
Private Sub LayerBox_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        '* Initialisation LayerBox *'
        Using acTrans = acCurDb.TransactionManager.StartTransaction()
            acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
            For Each acObjId As ObjectId In acLyrTbl
                acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead)
                ComboBox1.Items.Add(acLyrTblRec.Name)
            Next acObjId
        End Using
    End Sub
 This source works, but if i instance a new form on a new drawing, the first drawing's layer list is kept and the new layer list on the second drawing is ignored!
Any ideas?
Alfred.NESWADBA
Message 2 of 5 (143 Views)
Re: Instance Forms in several drawings
04-24-2012 02:54 AM in reply to: MGOMKD
then you have to set your variable acCurDb to this other drawing before getting the list of layers.
- alfred -
Alfred NESWADBA
Active Contributor
MGOMKD
Message 3 of 5 (139 Views)
04-24-2012 03:34 AM in reply to: Alfred.NESWADBA
Hi alfred,
How can i set my variable acCurDb to each drawing
I set my variables like that (as it's explained on autoCAD Developper's Guide)
 Public acDoc As Document = Application.DocumentManager.MdiActiveDocument
 Public acCurDb As Database = acDoc.Database
Thank You
Alfred.NESWADBA
Message 4 of 5 (137 Views)
04-24-2012 03:37 AM in reply to: MGOMKD
you have the DocumentCollection within the ApplicationServices.Application, that is a list of all opened Documents, run through this list and you have all Documents.
Next step is then to watch events for Opening/Activating/Closing Documents as you have then to update your list.
- alfred -
Alfred NESWADBA
Active Contributor
MGOMKD
Message 5 of 5 (125 Views)
04-24-2012 06:17 AM in reply to: Alfred.NESWADBA
Hi alfred,
I've found the source and it works! Thanks you.
In starter Sub just add an Event Argument to detect document activation.
        AddHandler Application.DocumentManager.DocumentActivated, AddressOf docColDocAct
End Sub
 Then, when a document is activated the Event Argument refers to docColDocAct which reset acCurDb variable with the current document activated and return it to private Sub LayerBox_Load.
Public Sub docColDocAct(ByVal senderObj As Object, ByVal docColDocActEvtArgs As DocumentCollectionEventArgs)
        acCurDb = docColDocActEvtArgs.Document.Database
End Sub
Thank you alfred
You are not logged in.
Ask the Community
