• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Member
    mikefr
    Inspector (arx) cool features
    206 Views, 6 Replies
    03-11-2012 12:28 PM
    Hello all,
    I have been using the arx application "inspector.arx" and i noticed some cool features this app has:
    1. Inspector doesn't steal focus from autocad when the refresh button is clicked. Generally inspector doesn't steal focus.
    2. Inspector can be docked like a palette
    3. Autocad is always active when the mouse leaves the inspector form.
    Is it possible to create an app with .net with similar features? Imagine a form with buttons, labels, listviews... etc.
    Can anyone provide some tips or guidance to achieve that?
    Thanks a lot!
    Please use plain text.
    Re: Inspector (arx) cool features
    03-11-2012 01:09 PM in reply to: mikefr
    That's imho the difference, you are speaking from a Windows-Form-object, but not from a palette-/paletteset-object. Make custom controls instead of Windows-Forms and place these on PaletteSet-objects. Makes all much easier, not just focus.
    >>>here<<< is a sample done by Kean Walmsley.
    - alfred -
    Alfred NESWADBA
    Active Member
    mikefr
    03-11-2012 02:38 PM in reply to: alfred.neswadba
    Hi Alfred, I follow Kean's blog. He's done great job. I also tried palette but had problem with comboboxes. I use API version 17.2. Also when using a palette, you have to use custom controls to make them not stealing focus:
    Public Class myButton
        Inherits Windows.Forms.Button
        Public Sub New()
            MyBase.New()
            SetStyle(Windows.Forms.ControlStyles.Selectable, False)
        End Sub
    End Class
     I even tried using  the  ToolStripDropDown class. What i want is a smooth back n forth from a modeless form to autocad application. Creating your own commands is cool but you can't remember 100 commands... Instead you can create a form with buttons, settings and stuff.
    03-11-2012 02:52 PM in reply to: mikefr
    Yes!
    Correct, but I thought this workaround was not necessary since working base on Framework 3.5. But I'm not sure about this at the moment.
    Forms will ever be a bit more work to sync the focus, the mouse/cursor, the visible or hidden (or minimized) mode with the AutoCAD-application window.
    What I don't understand is the "100 commands" message? You can also place buttons on your usercontrol (on your palette) and that can start everything without needing any commands defined.
    - alfred -
    Alfred NESWADBA
    Active Member
    mikefr
    03-11-2012 03:25 PM in reply to: alfred.neswadba
    I just want to mention that a UI is the best solution when you create lots of commands. Something i noticed in inspector is that when it is clicked autocad doen't lose focus. Inspector looks like a form. I hope for some guidance to create a form with similar features. By the way is there any workaround for the combobox glitch?
    Active Contributor
    03-11-2012 07:14 PM in reply to: mikefr
    Trap the MouseEnter/MouseLeave events of your pallet and set the KeepFocus property. Always worked for me.
    HomeBoy Out
    Active Member
    mikefr
    03-12-2012 03:07 AM in reply to: HomeBoyLV
    Hi Homeboy, I have tried KeepFocus but no trapping the events. Do you mean creating a new class that inherits paletteset and overriding these two events?  When the events fire i change the KeepFocus propertie?
