• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Inserting block with attributes
    857 Views, 7 Replies
    12-03-2011 01:58 AM
    I wish to insert a title sheet dwg, which has attribute definitions, as a block in another dwg.
    I can insert it, and if I explode it, the attribute definitions appear. Otherwise they are not added to the database.
    I am using standard code, which I can attach if it helps.
    it starts
    Dim btr As BlockTableRecord
    Dim blk As BlockReference = New BlockReference(ip, blkid)                        '  insert block
    btr.AppendEntity(blk)
    If btr.HasAttributeDefinitions Then
      ForEach attID As ObjectId In btr
    etc.
    but btr.HasAttributeDefinitions = False
    Please help?
    Please use plain text.
    Valued Contributor
    Re: Inserting block with attributes
    12-03-2011 01:59 AM in reply to: stuartnathan
    ps. I have looked everywhere.
    12-03-2011 02:44 AM in reply to: stuartnathan
    you insert a BlockReference into a BlockTableRecord, the the BlockTableRecord will not hold AttributeDefinitions, you have not inserted multiple Objects, just added ONE BlockReference.
    And you have no chance to get nested ones.
    Try in AutoCAD:
    create one Block inluding a rectangle + one Attribute(definition) ==> call it TABLE
    copy this Block(References) 5 times
    create a new Block(Definition) TABLEGROUP out of these 5 BlockReferences and insert it anywhere in your drawing ==> the BlockReference TABLEGROUP does not show Attribute(References) to work with.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    12-03-2011 06:07 AM in reply to: alfred.neswadba
    Sorry, I don't understand your point.
    I am using this code to insert a dwg
    Dim bt As BlockTable = DirectCast(tr.GetObject(CurDb.BlockTableId, OpenMode.ForRead), BlockTable)
    Dim blkid As ObjectId
    If Not bt.Has(Name) Then
        btr = tr.GetObject(CurDb.CurrentSpaceId, OpenMode.ForWrite)                   '  not already inserted?
        Dim db As Database = New Database(False, True)
        Using db
           db.ReadDwgFile(Path, System.IO.FileShare.Read, False, "")                  '  insert dwg
           blkid = CurDb.Insert(Name, db, True)
        End Using
    End If
    btr = DirectCast(tr.GetObject(CurDb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
    If String.IsNullOrEmpty(btr.Name) Then
         btr.UpgradeOpen()
         btr.Name = Name
         btr.DowngradeOpen()
    End If
    I understand that the dwg's attributes may not be loaded into the database. So how do I do that?
    12-03-2011 06:44 AM in reply to: stuartnathan
    could you also attach/upload the drawing that you use for this statement
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    12-03-2011 06:46 AM in reply to: alfred.neswadba
    OK
    12-03-2011 07:18 AM in reply to: stuartnathan
    HI,
    ok, I tried ... and I understand your question now :smileywink:
    You donot have a problem defining the BlockDefinition by inserting data from an external DWG
    Your problem is: when inserting the BlockReference into the modelspace the AttributeReferences are not generated automatically. And yes, that is by default, to get them inserted look to >>>this sample<<< .... especially the part with:
    ar.SetAttributeFromBlock(ad, blkRef.BlockTransform)
    The AttRef's have to be created seperatly and attached to the BlockRef's AttributeCollection.
    Good luck, - alfred -
    Alfred NESWADBA
    Valued Contributor
    12-03-2011 09:52 AM in reply to: alfred.neswadba
    :smileyvery-happy:Thanks for that.
    I attach a text file showing my code as it seems to encapsulate all that I found out.
