.NET
Valued Contributor
stuartnathan
Message 1 of 8 (1,162 Views)
Inserting block with attributes
1162 Views, 7 Replies
12-03-2011 01:58 AM
I wish to insert a title sheet dwg, which has attribute definitions, as a block in another dwg.
I can insert it, and if I explode it, the attribute definitions appear. Otherwise they are not added to the database.
I am using standard code, which I can attach if it helps.
it starts
Dim btr As BlockTableRecord
Dim blk As BlockReference = New BlockReference(ip, blkid)                        '  insert block
btr.AppendEntity(blk)
If btr.HasAttributeDefinitions Then
  ForEach attID As ObjectId In btr
etc.
but btr.HasAttributeDefinitions = False
Please help?
Valued Contributor
stuartnathan
Message 2 of 8 (1,162 Views)
Re: Inserting block with attributes
12-03-2011 01:59 AM in reply to: stuartnathan
ps. I have looked everywhere.
Alfred.NESWADBA
Message 3 of 8 (1,156 Views)
12-03-2011 02:44 AM in reply to: stuartnathan
you insert a BlockReference into a BlockTableRecord, the the BlockTableRecord will not hold AttributeDefinitions, you have not inserted multiple Objects, just added ONE BlockReference.
And you have no chance to get nested ones.
Try in AutoCAD:
create one Block inluding a rectangle + one Attribute(definition) ==> call it TABLE
copy this Block(References) 5 times
create a new Block(Definition) TABLEGROUP out of these 5 BlockReferences and insert it anywhere in your drawing ==> the BlockReference TABLEGROUP does not show Attribute(References) to work with.
- alfred -
Alfred NESWADBA
Valued Contributor
stuartnathan
Message 4 of 8 (1,152 Views)
12-03-2011 06:07 AM in reply to: Alfred.NESWADBA
Sorry, I don't understand your point.
I am using this code to insert a dwg
Dim bt As BlockTable = DirectCast(tr.GetObject(CurDb.BlockTableId, OpenMode.ForRead), BlockTable)
Dim blkid As ObjectId
If Not bt.Has(Name) Then
    btr = tr.GetObject(CurDb.CurrentSpaceId, OpenMode.ForWrite)                   '  not already inserted?
    Dim db As Database = New Database(False, True)
    Using db
       db.ReadDwgFile(Path, System.IO.FileShare.Read, False, "")                  '  insert dwg
       blkid = CurDb.Insert(Name, db, True)
    End Using
End If
btr = DirectCast(tr.GetObject(CurDb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
If String.IsNullOrEmpty(btr.Name) Then
     btr.UpgradeOpen()
     btr.Name = Name
     btr.DowngradeOpen()
End If
I understand that the dwg's attributes may not be loaded into the database. So how do I do that?
Alfred.NESWADBA
Message 5 of 8 (1,147 Views)
12-03-2011 06:44 AM in reply to: stuartnathan
could you also attach/upload the drawing that you use for this statement
- alfred -
Alfred NESWADBA
Valued Contributor
stuartnathan
Message 6 of 8 (1,146 Views)
12-03-2011 06:46 AM in reply to: Alfred.NESWADBA
OK
Alfred.NESWADBA
Message 7 of 8 (1,145 Views)
12-03-2011 07:18 AM in reply to: stuartnathan
HI,
ok, I tried ... and I understand your question now :smileywink:
You donot have a problem defining the BlockDefinition by inserting data from an external DWG
Your problem is: when inserting the BlockReference into the modelspace the AttributeReferences are not generated automatically. And yes, that is by default, to get them inserted look to >>>this sample<<< .... especially the part with:
ar.SetAttributeFromBlock(ad, blkRef.BlockTransform)
The AttRef's have to be created seperatly and attached to the BlockRef's AttributeCollection.
Good luck, - alfred -
Alfred NESWADBA
Valued Contributor
stuartnathan
Message 8 of 8 (1,140 Views)
12-03-2011 09:52 AM in reply to: Alfred.NESWADBA
:smileyvery-happy:Thanks for that.
I attach a text file showing my code as it seems to encapsulate all that I found out.
You are not logged in.
Ask the Community
