.NET
Valued Contributor
RamanSBV
Message 1 of 3 (208 Views)
Inserting Text in Autocad
208 Views, 2 Replies
05-24-2012 12:03 AM
Could you please any body suggest on
Inserting text into Autocad drawing file (like inserting image )using c#.
Raman
ADN Support Specialist
augusto.goncalves
Message 2 of 3 (192 Views)
Re: Inserting Text in Autocad
05-24-2012 06:45 AM in reply to: RamanSBV
Try this post: http://through-the-interface.typepad.com/through_the_interface/2010/06/creating-an-autocad-mtext-obj...
Regards
Augusto Goncalves
Autodesk Developer Network
Valued Mentor
gasty1001
Message 3 of 3 (176 Views)
05-24-2012 04:20 PM in reply to: RamanSBV
Try this simple text (no style) insert:
Public Sub addText(ByVal p1 As Point3d, ByVal txt As String, ByVal h As Double)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = HostApplicationServices.WorkingDatabase()
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            Dim t As New DBText
            t.Position = p1
            t.TextString = txt
            t.Height = h
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            t.SetDatabaseDefaults()
            acBlkTblRec.AppendEntity(t)
            acTrans.AddNewlyCreatedDBObject(t, True)
            acTrans.Commit()
        End Using
    End Sub
You are not logged in.
Ask the Community
