• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    doum90
    Inserting MText into .dwg
    178 Views, 5 Replies
    01-27-2013 07:41 PM
    Hello everyone!
    I'm trying to make a small program in vb.net that creates are laser drawing. So far I was able to create the drawing from a part in inventor. The only left to do is to add the Part Number + description into this drawing. I'm really struggling on this one. I'm currently able to open the drawing and that's all. I've tried many things from examples I found on forums but it's not working. This is a sample of what I have regarding autocad in my program:
    Imports Inventor
    Imports System.IO
    Imports AutoCAD
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.EditorInput
    Private Sub OpenDrawing()
    Dim oACAD As New Object
    Dim oMtext As AcadMText
    oACAD = CreateObject("AutoCAD.Application")
    oACAD.visible = True
    oACAD.Documents.Open(fileNameAndPath, False)
    End Sub
    I need to find a way to add Mtext but I don't find anything that I'm able to use in my program. If any of you know a good reference, or have a sample of code I would really appreciate it.
    Please use plain text.
    Re: Inserting MText into .dwg
    01-28-2013 01:36 AM in reply to: doum90
    as you are working from an external EXE /APP (otherwise you would not have to create the AutoCAD-object and so start the application) you only can use COM/ActiveX for communication to the AcadApplication-instance.
    And as long as you use VB.NET and COM your best help might be to look to the VBA-internal help as it's quite similar (same object model). So install the VBA-Enabler (be careful, some guys have measured timing conflicts just because it is installed) and look to this help.
    In case of MTEXT you'll find that:
    Sub Example_AddMtext()
        ' This example creates an MText object in model space.
        Dim MTextObj As AcadMText
        Dim corner(0 To 2) As Double
        Dim width As Double
        Dim text As String
        corner(0) = 0#: corner(1) = 10#: corner(2) = 0#
        width = 10
        text = "This is the text String for the mtext Object"
        ' Creates the mtext Object
        Set MTextObj = ThisDrawing.ModelSpace.AddMText(corner, width, text)
        ZoomAll
    End Sub
    HTH, - alfred -
    Alfred NESWADBA
    Moderator
    Alexander.Rivilis
    01-28-2013 01:57 AM in reply to: alfred.neswadba
    Hi, Alfred!
    No need to install VBA Enabler in order to read AutoCAD ActiveX Documentation. It can be downloaded from http://images.autodesk.com/adsk/files/autocad_2013_activex_help.zip
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    01-28-2013 02:04 AM in reply to: Alexander.Rivilis
    Hi Alexander,
    Much appreciated!
    Where do you get that info's from?
    Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
    - alfred -
    Alfred NESWADBA
    Moderator
    Alexander.Rivilis
    01-28-2013 02:10 AM in reply to: alfred.neswadba
    alfred.neswadba wrote:
    ... Where do you get that info's from? ...
    http://hyperpics.blogs.com/beyond_the_ui/2012/09/updated-autocad-2013-activex-developer-documentatio...
    ...Have you got a list of files where to download what from Autodesk? I would like to have the link to the source-code!animierte smilies lachen grinsen happy freuen smilen witzig froh
    Oh! I also want a list of such files. :smileyhappy:
    doum90
    01-28-2013 04:49 PM in reply to: alfred.neswadba
    here is the code I use in my vb.net program by the way:
    Dim oMtext As AutoCAD.AcadMText
    Dim width As Double = 10
    Dim Text As String
    Dim XPosition As Double = (-width / 2) + (PartLength / 2)
    Dim YPosition As Double = -0.25
    corner(0) = XPosition# : corner(1) = YPosition# : corner(2) = 0.0#
    Text = "{\fTahoma|b0|i0|c0|p34;\L\C3DWG #" & txtNomLaser.Text & "\l\P\C3MATL: " & DescriptionPiece & "\P\C3QTY:____}"
    oACAD.visible = False
    lblStatus.Text = "Ouverture d'Autocad en cours..."
    Retry = 0
    Dim oDoc As AutoCAD.AcadDocument
    oDoc = oACAD.ActiveDocument
    lblStatus.Text = "Création des layers en cours..."
    Dim LayerText As AutoCAD.AcadLayer = oDoc.Layers.Add("Text")
    lblStatus.Text = "Ajout du texte dans le DWG en cours..."
    oMtext = oDoc.ModelSpace.AddMText(corner, width, Text)
    oMtext.AttachmentPoint = AcAttachmentPoint.acAttachmentPointTopCenter
    oMtext.Layer = LayerText.Name.ToString
    lblStatus.Text = "Sauvegarde du fichier"
    oDoc.Save()
    lblStatus.Text = "Fermeture d'Autocad"
    oACAD.Quit()
    oACAD = Nothing
    Thank you very much for your help!
