.NET
Valued Contributor
Ertqwa
Message 1 of 2 (313 Views)
Insert wblock - annotative
313 Views, 1 Replies
01-19-2012 01:00 PM
Hello forum,
I use the following code to insert a wblock:
using (dbInsert = new Database(false, true))
    dbInsert.ReadDwgFile(strDwgPath, System.IO.FileShare.Read, true, "");
    oidInsert = dbActive.Insert(System.IO.Path.GetFileNameWithoutExtension(strDwgPath), dbInsert, true);
 Works as it should, and I can create a reference and use it. But when strDwgPath is an annotative block, it is inserted as a non-annotative block (BlockReference.Annotative == false).
I can use the following code, but then ALL blocks are inserted as annotative:
// Get the new blocktablerecord.
btrInsert = transActive.GetObject(oidInsert, OpenMode.ForWrite) as BlockTableRecord;
btrInsert.Annotative = AnnotativeStates.True;
How am I suppose to insert a wblock so annotative wblocks will be annotative and non-annotatives wont be?
Thank you.
Active Contributor
cincir
Message 2 of 2 (309 Views)
Re: Insert wblock - annotative
01-19-2012 01:51 PM in reply to: Ertqwa
bool bIsAnnotative = false;
    bIsAnnotative = dbInsert.AnnotativeDrawing;
will help you i think. then
if (bIsAnnotative)
You are not logged in.
Ask the Community
