.NET
Distinguished Contributor spu
spu
Message 1 of 4 (361 Views)
Insert blockreference using block name
361 Views, 3 Replies
11-17-2012 09:24 PM
Drawing contains a block with "BlkName". I want to insert blockreferences of this existing block using .Net. I gone through the help and some other threads. All shows how to insert a new block and then use the BlockID returned by the insert function. In my case I only have the block name and there is no Block id. How to get it or how to create a block reference of an existing block?
Shijith
Hallex
Message 2 of 4 (347 Views)
Re: Insert blockreference using block name
11-17-2012 10:24 PM in reply to: spu
Try this sample code,
add to namespace declarations:
using Autodesk.AutoCAD.Internal;
      public void testInsertBlock()
            string blockName = "BlockName";//<-- block name to be inserted
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            DocumentLock doclock = doc.LockDocument();
            using (doclock)
                Transaction tr = db.TransactionManager.StartTransaction();
                using (tr)
                    try
                        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        if (!bt.Has(blockName))
                            ed.WriteMessage("\nBlock \"{0}\" does not exist", blockName);
                            return;
                        ObjectId blkID = bt[blockName];
                        ed.WriteMessage("\nBlock \"{0}\" does exist, ObjectId is: {1}", blockName, blkID);
                        PromptPointOptions ptOpt = new PromptPointOptions("\nSpecify a block position : ");
                        PromptPointResult res = ed.GetPoint(ptOpt);
                        if (res.Status != PromptStatus.OK)
                            if (res.Status == PromptStatus.Cancel)
                                ed.WriteMessage("\nInterrupted by user. Exit.."); return;
                            else
                                ed.WriteMessage("\nError on specifying a point.Exit..."); return;
                        Point3d pt = res.Value;
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                        BlockTableRecord btrec = tr.GetObject(blkID, OpenMode.ForRead) as BlockTableRecord;
                        BlockReference bref = new BlockReference(pt, blkID);
                        bref.SetDatabaseDefaults();
                        if (btrec.Annotative == AnnotativeStates.True)
                            ObjectContextManager ocm = db.ObjectContextManager;
                            ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
                            ObjectContexts.AddContext(bref, occ.CurrentContext);
                        Matrix3d mat = Matrix3d.Identity;
                        bref.TransformBy(mat);
                        btr.AppendEntity(bref);
                        tr.AddNewlyCreatedDBObject(bref, true);
                        if (btrec.HasAttributeDefinitions)
                            Autodesk.AutoCAD.DatabaseServices.AttributeCollection atcoll = bref.AttributeCollection;
                            foreach (ObjectId subid in btrec)
                                Entity ent = (Entity)subid.GetObject(OpenMode.ForRead);
                                AttributeDefinition attDef = ent as AttributeDefinition;
                                if (attDef != null)
                                    //ed.WriteMessage("\nValue: " + attDef.TextString);// for debug only
                                    AttributeReference attRef = new AttributeReference();
                                    attRef.SetDatabaseDefaults();
                                    attRef.SetAttributeFromBlock(attDef, bref.BlockTransform);
                                    attRef.Position = attDef.Position.TransformBy(bref.BlockTransform);
                                    attRef.Tag = attDef.Tag;
                                    attRef.AdjustAlignment(db);
                                    atcoll.AppendAttribute(attRef);
                                    tr.AddNewlyCreatedDBObject(attRef, true);
                        tr.Commit();
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        ed.WriteMessage(("AutoCAD Exception: " + ex.Message + "\n" + ex.StackTrace));
                    catch (System.Exception ex)
                        ed.WriteMessage(("Sytem Exception: " + ex.Message + "\n" + ex.StackTrace));
                    finally
                        // optional message
spu
Message 3 of 4 (334 Views)
11-17-2012 11:02 PM in reply to: Hallex
Hi Hallex,
Thanks man it worked. I am actualy looking for this portion of the code "blkId = bt[bname];". I got the "has" but didn't find the item collection. I never thought about bt[]. Thanks again.
Is it required to have the code for attributes? is it nesessory or a better idea?
With Thanks
Shijith
Hallex
Message 4 of 4 (312 Views)
11-18-2012 05:31 AM in reply to: spu
This line of code is answer:
// add attribute here
//otherwise this code will be ignored and you
go further usual way
Glad you got it to work btw
You are not logged in.
Ask the Community
