.NET
Insert WD_M block programmatically
1 REPLY 1
AdrianSaf
549 Views, 1 Reply
I'm new to working with AutoCAD so this might be a really silly question.
How can I programmatically add the electrical WD_M block using ObjectARX and the COM API?
I assume I can read the WD_M dwg and then insert each block from it to my dwg. Is that the way to go?
Does the API offer the complete path to the WD_M dwg? How can I tell from what folder I should get the WD_M from (JIC1/JIC125)?
Thank you.
1 REPLY 1
AdrianSaf
in reply to: AdrianSaf
Found a way to do it by calling the LISP ACADE api.
ResultBuffer resBuf = new ResultBuffer();
resBuf.Add(new TypedValue((int)LispDataType.Text, /*MSG0*/"c:ace_GBL_wd_m")); //Lisp function to call
resBuf.Add(new TypedValue((int)LispDataType.Int16, 1)); // options
ResultBuffer res = Application.Invoke(resBuf);
”Boost
