Insert Method
Insert Method
Insert Method
Can someone give me an example of how you would insert the modelspace entities from an external drawing file into the active drawing with .net?
Steve
I use C# with VS 2003 and AutoCAD 2005. I haven't quite figured out how to
write attributes to it yet, but this is a start (the code is pasted at the
end).
Does anyone out there know of a way to call AutoCAD commands from C#? In
ObjectARX C++ there was the acedCommand method, so I could use:
acedCommand(RTSTR, "-INSERT", RTSTR, "My Block", ... etc etc)
It would be nice to have that again.
Hope this helps. I'm curious about the other responses too.
-Carlos
public void InsertIntoAutoCAD()
// Insert the block into the AutoCAD model
try
Document doc = Application.DocumentManager.MdiActiveDocument;
string fname = "C:\\Blocks\\My Block.dwg";
using (Database db = new Database(false, false))
//read block drawing
db.ReadDwgFile(fname, System.IO.FileShare.Read, true, null);
using (Transaction t = doc.TransactionManager.StartTransaction())
//insert the new block
Autodesk.AutoCAD.ApplicationServices.CommandLinePrompts.Message("\n
Inserting the block...");
ObjectId idBTR = doc.Database.Insert("My Block",db,false);
//create a ref to the block
BlockTable bt = (BlockTable)t.GetObject(doc.Database.BlockTableId,
OpenMode.ForRead);
BlockTableRecord btr =
(BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace],
OpenMode.ForWrite);
Autodesk.AutoCAD.Geometry.Point3d location = new Point3d(0.0, 0.0, 0.0);
using (BlockReference bref = new BlockReference(location, idBTR))
btr.AppendEntity(bref);
t.TransactionManager.AddNewlyCreatedDBObject(bref, true);
t.Commit();
catch
wrote in message news:4906068@discussion.autodesk.com...
Steve
Never mind...
I guess you can't. I had missed the other posts on the acedCommand topic.
-Carlos
"Carlos" wrote in message
news:4906567@discussion.autodesk.com...
end).
-Carlos
try
OpenMode.ForRead);
OpenMode.ForWrite);
t.Commit();
catch
Steve
