.NET
Active Contributor
brianaubert
Message 1 of 8 (313 Views)
Insert Block with Attributes Error
313 Views, 7 Replies
11-26-2012 11:08 AM
I have the following code that Inserts a Block with Attributes by using an empty database and
ReadDwgFile. But I seem to be missing something because it has caused memory errors that lead to Exception Errors in Autocad, which then bombs out. Is there something in addition to the db.CloseInput(true) and db.Dispose() that I need to fully release the unseen instance of Autocad?
Thanks in advance,
Brian
Code:
<Autodesk.AutoCAD.Runtime.
CommandMethod("InsertDetailCallOut", CommandFlags.Session)> _
PublicSharedSub InsertDetailCallOut(ByVal BlockPath AsString, ByVal thePoint AsPoint3d, ByVal BlockName AsString, ByVal dblscale AsDouble, _
ByVal Detail_Number AsInteger, ByVal Detail_Name AsString, ByVal Detail_Qty AsInteger, _
ByVal Detail_Material AsString, ByVal Detail_Stock AsString, ByVal Detail_Notes AsString)
Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim fname AsString= BlockPath
Dim idBTR AsObjectIdHostApplicationServices.Current.FindFile(fname, acDoc.Database, FindFileHint.Default)
Using docloc AsDocumentLock= acDoc.LockDocument
TryDim trans AsTransaction= acDoc.TransactionManager.StartTransaction
TryDim bt AsBlockTable = CType(trans.GetObject(acDoc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
Dim db AsNewDatabase(False, False)
db.ReadDwgFile(fname, System.IO.
FileShare.Read, True, "")
idBTR = acDoc.Database.Insert(BlockName, db,
False)
Dim btr AsBlockTableRecord = CType(trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
Dim bref AsBlockReference = NewBlockReference(thePoint, idBTR)
Dim theScale AsScale3d = NewScale3d(dblscale, dblscale, dblscale)
bref.ScaleFactors = theScale
bref.Layer =
"StockList"Try
btr.AppendEntity(bref)
trans.TransactionManager.AddNewlyCreatedDBObject(bref,
True)
FinallyEndTryDim RefBTR AsBlockTableRecord = trans.GetObject(bref.BlockTableRecord, OpenMode.ForRead)
Dim attEnt AsEntityForEach attID AsObjectIdInRefBTR
attEnt = trans.GetObject(attID,
OpenMode.ForRead)
IfTypeOf attEnt IsAttributeDefinitionThenDim attDef AsAttributeDefinition= attEnt
Dim attRef AsAttributeReference = NewAttributeReference()
attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
Dim attRefID AsObjectId
attRefID = bref.AttributeCollection.AppendAttribute(attRef)
SelectCaseattDef.Tag
Case"DET-NAME"
attRef.TextString = Detail_Name
Case"DET-NO"
attRef.TextString = Trim(Str(Detail_Number))
Case"DET-QTY"
attRef.TextString =
"(" & Trim(Str(Detail_Qty)) & ") - REQ'D. / HEATER"Case"DET-MAT"
attRef.TextString = Detail_Material
Case"DET-STK"
attRef.TextString = Detail_Stock
Case"DET-NOTES"
attRef.TextString = Detail_Notes
EndSelect
trans.AddNewlyCreatedDBObject(attRef,
True)
EndIfNext
trans.Commit()
db.CloseInput(
True)
db.Dispose()
FinallyEndTryFinallyEndTry
acDoc.Editor.UpdateScreen()
EndUsingEndSub
Active Contributor
brianaubert
Message 2 of 8 (305 Views)
Re: Insert Block with Attributes Error
11-26-2012 11:42 AM in reply to: brianaubert
In addition I forgot to mention:
I use this routine multiple times in the same drawing. It appears that after about 10 calls to it that problems start.
But not always. There are times the program will finish properly. Weird.
Valued Mentor
gasty1001
Message 3 of 8 (288 Views)
11-26-2012 06:06 PM in reply to: brianaubert
Try disposing the attref after adding it to the db.
Gaston Nunez
Hallex
Message 4 of 8 (274 Views)
11-27-2012 01:10 AM in reply to: brianaubert
I see nothing wrong with your code
just chaged few lines in there
See how it will works
        ' changed on short command "idc"
        <CommandMethod("InsertDetailCallOut", "idc", CommandFlags.Session)> _
        Public Shared Sub testInsertCallout()
            Dim fname As String = "c:\test\myfile.dwg"
            ' check if file exist
            If Not File.Exists(fname) Then
                Exit Sub
            End If
            '' you have also to check if layer "StockList" existbefore
            '' you have also to check if block "YourBlockName" exist before
            Dim p As Point3d = New Point3d(90.5, 90.1, 0) 'dummy point
            InsertDetailCallOut(fname, p, "YourBlockName", 0.5, 777, "Detail Name =", 100, "Detail Material =", "Detail_Stock= ", "Detail_Notes= ")
        End Sub
        Public Shared Sub InsertDetailCallOut(ByVal BlockPath As String, ByVal thePoint As Point3d, ByVal BlockName As String, ByVal dblscale As Double, _
ByVal Detail_Number As Integer, ByVal Detail_Name As String, ByVal Detail_Qty As Integer, _
ByVal Detail_Material As String, ByVal Detail_Stock As String, ByVal Detail_Notes As String)
            Dim fname As String = BlockPath
            Dim idBTR As ObjectId
            Try
                Using docloc As DocumentLock = acDoc.LockDocument
                    Using trans As Transaction = acDoc.TransactionManager.StartTransaction
                        Dim bt As BlockTable = CType(trans.GetObject(acDoc.Database.BlockTableId, OpenMode.ForRead), BlockTable)
                        ' you have before to check if layer "Stocklist" exist
                        Dim db As New Database(False, False)
                        Using db
                            db.ReadDwgFile(fname, System.IO.FileShare.Read, True, "")
                            idBTR = acDoc.Database.Insert(BlockName, db, False)
                            Dim btr As BlockTableRecord = CType(trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                            Dim bref As BlockReference = New BlockReference(thePoint, idBTR)
                            Dim theScale As Scale3d = New Scale3d(dblscale, dblscale, dblscale)
                            bref.Layer = "StockList"
                            trans.TransactionManager.AddNewlyCreatedDBObject(bref, True)
                            Dim RefBTR As BlockTableRecord = trans.GetObject(bref.BlockTableRecord, OpenMode.ForRead)
                            Dim attEnt As Entity
                            For Each attID As ObjectId In RefBTR
                                attEnt = trans.GetObject(attID, OpenMode.ForRead)
                                If TypeOf attEnt Is AttributeDefinition Then
                                    Dim attDef As AttributeDefinition = attEnt
                                    Dim attRef As AttributeReference = New AttributeReference()
                                    Dim attRefID As ObjectId
                                    Select Case attDef.Tag()
                                        Case "DET-NAME"
                                        Case "DET-NO"
                                        Case "DET-QTY"
                                            attRef.TextString = "(" & Trim(Str(Detail_Qty)) & ") - REQ'D. / HEATER"
                                        Case "DET-MAT"
                                        Case "DET-STK"
                                        Case "DET-NOTES"
                                    End Select
                                    attRef.AdjustAlignment(acDoc.Database)
                                    trans.AddNewlyCreatedDBObject(attRef, True)
                                End If
                            Next
                        End Using
                        trans.Commit()
                    End Using
                End Using
            Catch ex As System.Exception
                MsgBox(ex.Message)
            Finally
            End Try
        End Sub
Active Contributor
brianaubert
Message 5 of 8 (256 Views)
11-27-2012 12:07 PM in reply to: brianaubert
Thank you for both of your replies.
I've added attRef.Dispose() as Gasty suggested.
I also made the changes suggested by Hallex.
I still get the Unhandled exception error.
It's telling me that:
"Attempted to read or write protected memory. This is often an
indication that other memory is corrupt."
This application is still in development. So I'm the only one using it.
I have run it about 10 times in a row to complettion of the program with no error.
Then other times it will error half way through.
If I bypass the InsertCallOut sub, I have no problems with the program.
Any other suggestions?
Could this be an Autocad bug?
Brian
Hallex
Message 6 of 8 (238 Views)
11-28-2012 08:33 AM in reply to: brianaubert
I did't find this problem with my code
I've added 1000 blocks using my routine
like this
                Exit Sub
            End If
            Dim p As Point3d = Point3d.Origin 'dummy point
            ' add 1000 block for quick test
            For i As Integer = 0 To 999
                InsertDetailCallOut(fname, New Point3d(p.X + (i + 1) * 10, p.Y + (i + 1) * 10, 0), "YourBlockName", 0.5, 777, "Detail Name =", 100, "Detail Material =", "Detail_Stock= ", "Detail_Notes= ")
            Next
            ' time expired about 1.3 minutes on my machine
        End Sub
Active Contributor
brianaubert
Message 7 of 8 (228 Views)
11-28-2012 11:39 AM in reply to: brianaubert
        Try
              Using db
                idBTR = acDoc.Database.Insert(BlockName & ".dwg", db, False)
	<< Fails on the line Above >>
 Update to the problem.
I've changed my code to build an array of data for the placement and information for the detail call outs.
Then after all the details have been drawn I run through the array list to insert the details call outs.
There are 14 items in the array and it fails on the second pass each time, at the line above.
Any thoughts?
Brian
Active Contributor
brianaubert
Message 8 of 8 (222 Views)
11-28-2012 12:44 PM in reply to: brianaubert
Ok, after further testing, I now believe the problem is an error in my code in another routine.
I think I might be going past the bounds of a collection which is causing this problem.
:smileyembarrassed:
I'll update after more debugging.
Brian
You are not logged in.
Ask the Community
