• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Accepted Solution
    Insert Block on Multiple Selected Points
    523 Views, 34 Replies
    04-20-2012 06:56 AM
    I am trying to put something together that will allow a user to select objects in AutoCAD and then place a block at all the selected points.
    Below I have pasted the code that I have so far, but have not been able to test this to see what happens because the Dim ofd part is giving me an error that I have not been able to figure out.  I am only a beginner at this so my code may be wrong and/or ugly.
    The error that I am getting says that :
    Argument not specified for parameter "flags" of "Public Sub New(title As String, defaultName As String, extension As String, dialogName As String, flags As Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags)
    Code:
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.Windows
    PublicClass Class1
        <CommandMethod("pntblk")> _
    PublicSub PntBlk()
    Dim doc As Document = Application.DocumentManager.MdiActiveDocument
    Dim db As Database = doc.Database
    Dim ed As Editor = doc.Editor
    Using trans As Transaction = db.TransactionManager.StartTransaction()
    Dim blktbl As BlockTable
                blktbl = trans.GetObject(db.BlockTableId, _
                                         OpenMode.ForRead)
    Dim ofd AsNew OpenFileDialog(dialogName:="Block Selection")
    Dim ppo As PromptPointOptions = New PromptPointOptions(SelectionMethod.Crossing)
    Dim ppr As PromptPointResult = ed.GetPoint(ppo)
    Dim ndb As Database = New Database(False, True)
                ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare,True, Nothing)
    Dim name AsString = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.Filename)
    Dim id As ObjectId = db.Insert(name, ndb, True)
    Dim btr As BlockTableRecord = CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
    Dim inst As BlockReference = New BlockReference(ppr.Value, id)
                btr.AppendEntity(inst)
                inst.SetDatabaseDefaults()
                trans.AddNewlyCreatedDBObject(inst,True)
                trans.Commit()
    EndUsing
    End Sub
    End Class
    Any Assistance will be appreciated.
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: Insert Block on Multiple Selected Points
    04-21-2012 12:00 PM in reply to: bkenyon13
    Not sure about of your task but maybe this
    will help with FileDialog,
    Just changea  file name to save the newly created drawing:
            <CommandMethod("pntblk", CommandFlags.Session Or CommandFlags.Modal)> _
            Public Sub PntBlk()
                Dim ofd As New Windows.Forms.OpenFileDialog
                ofd.Title = "Block Selection"
                ofd.Filter = "Drawings (*.dwg)|*.dwg"
                ofd.FilterIndex = 0
                ofd.Multiselect = False
                ofd.InitialDirectory = Environment.CurrentDirectory
                If ofd.ShowDialog <> Windows.Forms.DialogResult.OK Then
                    Return
                Else
                    MsgBox(ofd.FileName)
                Dim fname As String = "C:\Test\MYDWG.dwg"
                Try
                    Using doclock As DocumentLock = doc.LockDocument
                            blktbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
                            Dim ppo As PromptPointOptions = New PromptPointOptions("") ''(SelectionMethod.Crossing)
                            ppo.Message = vbLf + "Pick a point: "
                            ndb.ReadDwgFile(ofd.FileName, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                            Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.FileName)
                            trans.AddNewlyCreatedDBObject(inst, True)
                            trans.Commit()
                            db.CloseInput(True)
                            db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
                        End Using
                    End Using
                Catch ex As System.Exception
                    ed.WriteMessage(ex.Message)
                End Try
            End Sub
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    *Expert Elite*
    Hallex
    04-21-2012 01:46 PM in reply to: Hallex
    Here is updated code
            Public Sub PntBlk()
                ofd.FilterIndex = 0
                    Return
                Else
                Try
                            ppo.Message = vbLf + "Pick a first point: "
                            If ppr.Status <> PromptStatus.OK Then Return
                            doc.TransactionManager.QueueForGraphicsFlush()
                            ppo.Message = vbLf + "Pick a next point (or press ESC to Exit): "
                            Do While ppr.Status = PromptStatus.OK
                                ppr = ed.GetPoint(ppo)
                                If ppr.Status = PromptStatus.Cancel Then Exit Do
                                inst = New BlockReference(ppr.Value, id)
                            Loop
                            doc.TransactionManager.FlushGraphics()
                            ed.UpdateScreen()
                            trans.Commit()
                            ' in case:
                            'db.CloseInput(True)
                            'db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
                        End Using
                    End Using
                End Try
            End Sub
    ~'J'~
    Active Contributor
    04-23-2012 06:38 AM in reply to: bkenyon13
    Thank you for the response and the code it is very helpfull.
    My goal is to be able to do a selection window and then based on the selection be able to have a block inserted at all the selected points such as at all the end points of all the selected lines.
    Like if I had sewer lines that I need to add a manhole symbol to I would be able just to run the command, select the manhol block to use, select the lines I want to add the block too then it would add that block to all the end points of all the lines that I have selected without having to select each location to place it.
    I would think it would use the "PromptSelectionOptions" and "PromptSelectionResults", but I have not been able to find a way to have it get the location of the selected entities and insert the block.
    Again I am not expecting anyone to write the code, but just point me to the right direction is helpful.  Thank You.
    *Expert Elite*
    Hallex
    04-23-2012 09:24 AM in reply to: bkenyon13
    Okay, here you go, just use method as I shown before to import your blocks
    and also change layer name of water profile pipeline inside the code
            Public Shared Function GetPlineCoordinates(ByVal ent As Polyline) As Point3dCollection
                Dim pts As Point3dCollection = New Point3dCollection()
                Dim coord As Point3d
                Dim i As Integer = 0
                For i = 0 To ent.NumberOfVertices - 1
                    coord = ent.GetPoint3dAt(i)
                    pts.Add(coord)
                Next
                Return pts
            End Function
            <CommandMethod("manholes")> _
            Public Sub InsertManholes()
                Dim blkname As String = "manhole"
                Dim layername As String = "MyLayer"
                Dim ppo As New PromptPointOptions(vbLf & "First corner point: ")
                    Return
                Dim pco As New PromptCornerOptions(vbLf & "Other corner: ", ppr.Value)
                Dim pcr As PromptPointResult = ed.GetCorner(pco)
                If pcr.Status <> PromptStatus.OK Then
                    Return
                Dim p1 As Point3d = ppr.Value
                Dim p2 As Point3d = pcr.Value
                If p1.X = p2.X OrElse p1.Y = p2.Y Then
                    ed.WriteMessage(vbLf & "Wrong coordinates specified")
                    Return
                Dim pts As New Point3dCollection()
                pts.Add(p1)
                pts.Add(New Point3d(p2.X, p1.Y, 0))
                pts.Add(p2)
                pts.Add(New Point3d(p1.X, p2.Y, 0))
                Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE"), New TypedValue(8, layername)}
                Dim flt As New SelectionFilter(tv)
                Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
                If res.Status <> PromptStatus.OK Then Return
                MsgBox(res.Value.Count.ToString)
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    Try
                        Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                        If Not bt.Has(blkname) Then
                            Return
                        Dim blkid As ObjectId = bt(blkname)
                        Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                        For Each selObj As SelectedObject In res.Value
                            Dim ent As Entity = tr.GetObject(selObj.ObjectId, OpenMode.ForRead)
                            Dim pline As Polyline
                            pline = TryCast(ent, Polyline)
                            If pline IsNot Nothing Then
                                Dim vertices As Point3dCollection = GetPlineCoordinates(pline)
                                For i As Integer = 0 To vertices.Count - 1
                                    Dim inst As BlockReference = New BlockReference(vertices(i), blkid)
                                    tr.AddNewlyCreatedDBObject(inst, True)
                                Next
                        Next
                        tr.Commit()
                    End Try
                End Using
            End Sub
    ~'J'~
    *Expert Elite*
    Hallex
    04-23-2012 11:33 AM in reply to: Hallex
    Here is complete routine if you could not gather them all
                    pts.Add(coord)
                Next
                Return pts
            End Function
            Public Sub ApplyAttributes(db As Database, tr As Transaction, bref As BlockReference)
                Dim btrec As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                If btrec.HasAttributeDefinitions Then
                    Dim atcoll As Autodesk.AutoCAD.DatabaseServices.AttributeCollection = bref.AttributeCollection
                    For Each subid As ObjectId In btrec
                        Dim ent As Entity = DirectCast(subid.GetObject(OpenMode.ForRead), Entity)
                        Dim attDef As AttributeDefinition = TryCast(ent, AttributeDefinition)
                        If attDef IsNot Nothing Then
                            Dim attRef As New AttributeReference()
                            attRef.SetDatabaseDefaults()
                            'optional
                            attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                            attRef.Position = attDef.Position.TransformBy(bref.BlockTransform)
                            attRef.Justify = attDef.Justify
                            'must be added all other properties for right position, eg. alignment modes etc
                            attRef.Tag = attDef.Tag
                            attRef.AdjustAlignment(db)
                            atcoll.AppendAttribute(attRef)
                            tr.AddNewlyCreatedDBObject(attRef, True)
                    Next
            End Sub
            <CommandMethod("manholes", CommandFlags.Session Or CommandFlags.Modal)> _
                ofd.FilterIndex = 0
                    Return
                Else
                    Return
                    Return
                    Return
                pts.Add(p1)
                pts.Add(p2)
                        Try
                                blkid = db.Insert(name, ndb, True)
                            blkid = bt(blkname)
                                        ApplyAttributes(db, tr, inst)
                                    Next
                            Next
                            tr.Commit()
                            ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                        End Try
                    End Using
                End Using
            End Sub
    ~'J'~
    Active Contributor
    04-24-2012 06:18 AM in reply to: bkenyon13
    Thank you for all your help.
    I got your code and tried it, but when I first tried it nothing happened.  it did not insert any blocks and also did not give me any errors.
    However I then modified the code for the OFD part to be as follows:
    Dim ofd AsNew OpenFileDialog(title:="Block Selection", extension:="dwg", defaultName:="", dialogName:="Block Selection", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSites)
            ofd.ShowDialog()
    I am not sure exactly the difference, but I believe what I changed was for the dialog to open in AutoCAD rather then Windows.
    I then ran the command again and get the following error:
    eKeyNotFound
    at Autodesk.AutoCAD.DatbaseServices.SymbolTable.get_item(String Key)
    at PntBlk.Class1.Insertmanholes ()
    Not exactly sure what that means, but there is no reference to the symboltable.get_item any where in the code, but maybe needs to be??
    Not sure why it would want the SymbolTable and at this time I am not able to examine the code to try and work it out.  All and any assistance is greatly appreciated.
    *Expert Elite*
    Hallex
    04-24-2012 07:08 AM in reply to: bkenyon13
    I have no ideas about this issue
    Try to use "manhole.dwg" where you do the followingt:
    create your "block image" as few circles and attribute definitions
    but don't to create it as block itself, then save and close
    then run my code again
    ~'J'~
    Active Contributor
    04-26-2012 07:13 AM in reply to: bkenyon13
    I have had some time to look at the code and I have been able to get it to work.
    The error was coming from the line of "blkisd= bt (blkname)"
    Not exactly sure why, but I removed that and redid a liitle bit of the code and it is not working like a charm.
    However there is one more factor that I would like to add and I am not sure where or how.  I would like to have this command work for Lines, Polylines and Point entities in CAD.
    would that be easily done by adding some more code to where the "LWPOLYLINE" is or would the entire thing have to be modified to get the coordinates of the different entities.
    again if you can just let me know that I am on the right path that will help.
    Active Contributor
    04-26-2012 07:31 AM in reply to: bkenyon13
    Ammendment to the last post.
    The code IS working like a charm.
    and the line of code that was giving the error was "blkid = bt (blkname)"
    sorry for the misspellings and so on.
    Again also if I can get this to work for multiple entities other then just polylines then it would be perfect.
    Thanks for all your efforts.
