• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Hallex
    Re: Insert Block on Multiple Selected Points
    05-01-2012 11:14 AM in reply to: bkenyon13
    Here is edited code, I've added check if point key is exist in dictionary,
    see how it works
    from other side I know nothing about using acsmcomponents18lib.tlb,
    so you have to start the new thread about,
    Code:
            <CommandMethod("insblk")> _
            Public Sub TestForInsert()
                'Selects the dwg file to be used as the block that is inserted
                Dim ofd As New OpenFileDialog(title:="Block Selection", defaultName:="", dialogName:="Block Selection", extension:="dwg", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSites)
                ofd.ShowDialog()
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim db As Database = doc.Database
                Dim ed As Editor = doc.Editor
                Dim points As IDictionary(Of Point3d, Integer) = New Dictionary(Of Point3d, Integer)
                Dim inspts As Point3dCollection = New Point3dCollection
                'Specifies the selection area
                Dim ppo As New PromptPointOptions(vbLf & "First Corner:")
                Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                Dim pco As New PromptCornerOptions(vbLf & "Second Corner:", ppr.Value)
                Dim pcr As PromptPointResult = ed.GetCorner(pco)
                'Gets the start and end points of the selected polylines
                Dim p1 As Point3d = ppr.Value
                Dim p2 As Point3d = pcr.Value
                Dim pts As New Point3dCollection()
                pts.Add(p1)
                pts.Add(New Point3d(p2.X, p1.Y, 0))
                pts.Add(p2)
                pts.Add(New Point3d(p1.X, p2.Y, 0))
                Using doclock As DocumentLock = doc.LockDocument
                    Using tr As Transaction = db.TransactionManager.StartTransaction()
                        Try
                            'Creates the specified block within the dwg
                            Dim bt As BlockTable
                            bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                            Dim blkid As ObjectId
                            Dim ndb As Database = New Database(False, True)
                            ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                            Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.Filename)
                            Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                            blkid = db.Insert(name, ndb, True)
                            'Creates a selection filter
                            Dim tv As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LWPOLYLINE,POINT")}
                            Dim flt As New SelectionFilter(tv)
                            Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
                            'check if something selected
                            If res.Status = PromptStatus.OK Then
                                'check if selected equal one or more than one item
                                If res.Value.Count > 0 Then
                                    For Each selobj As SelectedObject In res.Value
                                        Dim ent As Entity = tr.GetObject(selobj.ObjectId, OpenMode.ForRead)
                                        'Gets the selected polylines
                                        Dim pline As Polyline
                                        pline = TryCast(ent, Polyline)
                                        'Gets the selected points
                                        Dim pt As DBPoint
                                        pt = TryCast(ent, DBPoint)
                                        If pline IsNot Nothing Then
                                            'Runs the shared function to get the coordinates of the polylines
                                            Dim vertices As Point3dCollection = New Point3dCollection()
                                            For i As Integer = 0 To pline.NumberOfVertices - 1
                                                vertices.Add(pline.GetPoint3dAt(i))
                                                'Adds the block to the polylines
                                                Dim br As BlockReference = New BlockReference(vertices(i), blkid)
                                                br.SetDatabaseDefaults()
                                                btr.AppendEntity(br)
                                                tr.AddNewlyCreatedDBObject(br, True)
                                            Next
                                        Else
                                            If pt IsNot Nothing Then
                                                Dim verts As Point3d = pt.Position
                                                'Adds the block to the points
                                                Dim br2 As BlockReference = New BlockReference(verts, blkid)
                                                br2.SetDatabaseDefaults()
                                                btr.AppendEntity(br2)
                                                tr.AddNewlyCreatedDBObject(br2, True)
                                            End If
                                        End If
                                    Next
                                End If
                            End If
                            Dim tv1 As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LINE")}
                            Dim flt1 As New SelectionFilter(tv1)
                            Dim res1 As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt1)
                            If res1.Status = PromptStatus.OK Then
                                If res1.Value.Count > 0 Then
                                    For Each selobj As SelectedObject In res1.Value
                                        'Gets the selected lines
                                        Dim ln As Line
                                        ln = TryCast(ent, Line)
                                        If ln IsNot Nothing Then
                                            Dim i As Integer = 1
                                            Dim ps As Point3d = ln.StartPoint
                                            Dim pe As Point3d = ln.EndPoint
                                            ' check if point exist
                                            If Not points.ContainsKey(ps) Then
                                                points.Add(New KeyValuePair(Of Point3d, Integer)(ps, i))
                                                i += 1
                                            End If
                                            If Not points.ContainsKey(pe) Then
                                                points.Add(New KeyValuePair(Of Point3d, Integer)(pe, i))
                                                i += 1
                                            End If
                                        End If
                                    Next
                                    ' Add points to the point collection
                                    For Each kvp As KeyValuePair(Of Point3d, Integer) In points
                                        inspts.Add(kvp.Key)
                                    Next kvp
                                    'Adds the block to the lines
                                    For Each pt As Point3d In inspts
                                        Dim br3 As BlockReference = New BlockReference(pt, blkid)
                                        br3.SetDatabaseDefaults()
                                        btr.AppendEntity(br3)
                                        tr.AddNewlyCreatedDBObject(br3, True)
                                    Next
                                End If
                            End If
                            'Commits to the changes made
                            tr.Commit()
                        Catch ex As System.Exception
                            ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                        End Try
                    End Using
                End Using
            End Sub
    ~'J'~
    Please use plain text.
    Active Contributor
    05-02-2012 06:33 AM in reply to: Hallex
    This code works perfect, thank you so much.
    Hallex
    05-02-2012 07:20 AM in reply to: bkenyon13
    Glad I could help
    Cheers :smileyhappy:
    ~'J'~
    Active Contributor
    05-02-2012 08:32 AM in reply to: Hallex
    one last question if I could.
    I copied the compiled dll file to another computer and attemped to run the command and foro some reason it stops and says something about a security issue and to run the ,net configuration tool to resolve the issue.
    is there something that I missed in my compiling options or something else?
    Active Contributor
    05-02-2012 11:35 AM in reply to: bkenyon13
    Figured out what the issue was but was not able to resolve it directly.
    apparently the issue is that there is a permission problem when trying to run the command that was created when the compiled dll that is loaded is location on a network folder.
    I copied the dll file to the local computer and the command worked perfect.
