.NET
Hallex
Message 31 of 35 (350 Views)
Re: Insert Block on Multiple Selected Points
05-01-2012 11:14 AM in reply to: bkenyon13
Here is edited code, I've added check if point key is exist in dictionary,
see how it works
from other side I know nothing about using acsmcomponents18lib.tlb,
so you have to start the new thread about,
Code:
        <CommandMethod("insblk")> _
        Public Sub TestForInsert()
            'Selects the dwg file to be used as the block that is inserted
            Dim ofd As New OpenFileDialog(title:="Block Selection", defaultName:="", dialogName:="Block Selection", extension:="dwg", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSites)
            ofd.ShowDialog()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim points As IDictionary(Of Point3d, Integer) = New Dictionary(Of Point3d, Integer)
            Dim inspts As Point3dCollection = New Point3dCollection
            'Specifies the selection area
            Dim ppo As New PromptPointOptions(vbLf & "First Corner:")
            Dim ppr As PromptPointResult = ed.GetPoint(ppo)
            Dim pco As New PromptCornerOptions(vbLf & "Second Corner:", ppr.Value)
            Dim pcr As PromptPointResult = ed.GetCorner(pco)
            'Gets the start and end points of the selected polylines
            Dim p1 As Point3d = ppr.Value
            Dim p2 As Point3d = pcr.Value
            Dim pts As New Point3dCollection()
            pts.Add(p1)
            pts.Add(New Point3d(p2.X, p1.Y, 0))
            pts.Add(p2)
            pts.Add(New Point3d(p1.X, p2.Y, 0))
            Using doclock As DocumentLock = doc.LockDocument
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Try
                        'Creates the specified block within the dwg
                        Dim bt As BlockTable
                        bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                        Dim blkid As ObjectId
                        Dim ndb As Database = New Database(False, True)
                        ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                        Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.Filename)
                        Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                        blkid = db.Insert(name, ndb, True)
                        'Creates a selection filter
                        Dim tv As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LWPOLYLINE,POINT")}
                        Dim flt As New SelectionFilter(tv)
                        Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
                        'check if something selected
                        If res.Status = PromptStatus.OK Then
                            'check if selected equal one or more than one item
                            If res.Value.Count > 0 Then
                                For Each selobj As SelectedObject In res.Value
                                    Dim ent As Entity = tr.GetObject(selobj.ObjectId, OpenMode.ForRead)
                                    'Gets the selected polylines
                                    Dim pline As Polyline
                                    pline = TryCast(ent, Polyline)
                                    'Gets the selected points
                                    Dim pt As DBPoint
                                    pt = TryCast(ent, DBPoint)
                                    If pline IsNot Nothing Then
                                        'Runs the shared function to get the coordinates of the polylines
                                        Dim vertices As Point3dCollection = New Point3dCollection()
                                        For i As Integer = 0 To pline.NumberOfVertices - 1
                                            vertices.Add(pline.GetPoint3dAt(i))
                                            'Adds the block to the polylines
                                            Dim br As BlockReference = New BlockReference(vertices(i), blkid)
                                            br.SetDatabaseDefaults()
                                            btr.AppendEntity(br)
                                            tr.AddNewlyCreatedDBObject(br, True)
                                        Next
                                    Else
                                        If pt IsNot Nothing Then
                                            Dim verts As Point3d = pt.Position
                                            'Adds the block to the points
                                            Dim br2 As BlockReference = New BlockReference(verts, blkid)
                                            br2.SetDatabaseDefaults()
                                            btr.AppendEntity(br2)
                                            tr.AddNewlyCreatedDBObject(br2, True)
                                        End If
                                    End If
                                Next
                            End If
                        End If
                        Dim tv1 As TypedValue() = New TypedValue() {New TypedValue(DxfCode.Start, "LINE")}
                        Dim flt1 As New SelectionFilter(tv1)
                        Dim res1 As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt1)
                        If res1.Status = PromptStatus.OK Then
                            If res1.Value.Count > 0 Then
                                For Each selobj As SelectedObject In res1.Value
                                    'Gets the selected lines
                                    Dim ln As Line
                                    ln = TryCast(ent, Line)
                                    If ln IsNot Nothing Then
                                        Dim i As Integer = 1
                                        Dim ps As Point3d = ln.StartPoint
                                        Dim pe As Point3d = ln.EndPoint
                                        ' check if point exist
                                        If Not points.ContainsKey(ps) Then
                                            points.Add(New KeyValuePair(Of Point3d, Integer)(ps, i))
                                            i += 1
                                        End If
                                        If Not points.ContainsKey(pe) Then
                                            points.Add(New KeyValuePair(Of Point3d, Integer)(pe, i))
                                            i += 1
                                        End If
                                    End If
                                Next
                                ' Add points to the point collection
                                For Each kvp As KeyValuePair(Of Point3d, Integer) In points
                                    inspts.Add(kvp.Key)
                                Next kvp
                                'Adds the block to the lines
                                For Each pt As Point3d In inspts
                                    Dim br3 As BlockReference = New BlockReference(pt, blkid)
                                    br3.SetDatabaseDefaults()
                                    btr.AppendEntity(br3)
                                    tr.AddNewlyCreatedDBObject(br3, True)
                                Next
                            End If
                        End If
                        'Commits to the changes made
                        tr.Commit()
                    Catch ex As System.Exception
                        ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                    End Try
                End Using
            End Using
        End Sub
~'J'~
Active Contributor
bkenyon13
Message 32 of 35 (340 Views)
05-02-2012 06:33 AM in reply to: Hallex
This code works perfect, thank you so much.
Hallex
Message 33 of 35 (338 Views)
05-02-2012 07:20 AM in reply to: bkenyon13
Glad I could help
Cheers :smileyhappy:
~'J'~
Active Contributor
bkenyon13
Message 34 of 35 (335 Views)
05-02-2012 08:32 AM in reply to: Hallex
one last question if I could.
I copied the compiled dll file to another computer and attemped to run the command and foro some reason it stops and says something about a security issue and to run the ,net configuration tool to resolve the issue.
is there something that I missed in my compiling options or something else?
Active Contributor
bkenyon13
Message 35 of 35 (314 Views)
05-02-2012 11:35 AM in reply to: bkenyon13
Figured out what the issue was but was not able to resolve it directly.
apparently the issue is that there is a permission problem when trying to run the command that was created when the compiled dll that is loaded is location on a network folder.
I copied the dll file to the local computer and the command worked perfect.
You are not logged in.
Ask the Community
