.NET
Active Contributor
bkenyon13
Message 1 of 35 (790 Views)
Insert Block on Multiple Selected Points
790 Views, 34 Replies
04-20-2012 06:56 AM
I am trying to put something together that will allow a user to select objects in AutoCAD and then place a block at all the selected points.
Below I have pasted the code that I have so far, but have not been able to test this to see what happens because the Dim ofd part is giving me an error that I have not been able to figure out.  I am only a beginner at this so my code may be wrong and/or ugly.
The error that I am getting says that :
Argument not specified for parameter "flags" of "Public Sub New(title As String, defaultName As String, extension As String, dialogName As String, flags As Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags)
Code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Windows
PublicClass Class1
    <CommandMethod("pntblk")> _
PublicSub PntBlk()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim blktbl As BlockTable
            blktbl = trans.GetObject(db.BlockTableId, _
                                     OpenMode.ForRead)
Dim ofd AsNew OpenFileDialog(dialogName:="Block Selection")
Dim ppo As PromptPointOptions = New PromptPointOptions(SelectionMethod.Crossing)
Dim ppr As PromptPointResult = ed.GetPoint(ppo)
Dim ndb As Database = New Database(False, True)
            ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare,True, Nothing)
Dim name AsString = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.Filename)
Dim id As ObjectId = db.Insert(name, ndb, True)
Dim btr As BlockTableRecord = CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim inst As BlockReference = New BlockReference(ppr.Value, id)
            btr.AppendEntity(inst)
            inst.SetDatabaseDefaults()
            trans.AddNewlyCreatedDBObject(inst,True)
            trans.Commit()
EndUsing
End Sub
End Class
Any Assistance will be appreciated.
Hallex
Message 2 of 35 (765 Views)
Re: Insert Block on Multiple Selected Points
04-21-2012 12:00 PM in reply to: bkenyon13
Not sure about of your task but maybe this
will help with FileDialog,
Just changea  file name to save the newly created drawing:
        <CommandMethod("pntblk", CommandFlags.Session Or CommandFlags.Modal)> _
        Public Sub PntBlk()
            Dim ofd As New Windows.Forms.OpenFileDialog
            ofd.Title = "Block Selection"
            ofd.Filter = "Drawings (*.dwg)|*.dwg"
            ofd.FilterIndex = 0
            ofd.Multiselect = False
            ofd.InitialDirectory = Environment.CurrentDirectory
            If ofd.ShowDialog <> Windows.Forms.DialogResult.OK Then
                Return
            Else
                MsgBox(ofd.FileName)
            End If
            Dim fname As String = "C:\Test\MYDWG.dwg"
            Try
                Using doclock As DocumentLock = doc.LockDocument
                        blktbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
                        Dim ppo As PromptPointOptions = New PromptPointOptions("") ''(SelectionMethod.Crossing)
                        ppo.Message = vbLf + "Pick a point: "
                        ndb.ReadDwgFile(ofd.FileName, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
                        Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(ofd.FileName)
                        trans.AddNewlyCreatedDBObject(inst, True)
                        trans.Commit()
                        db.CloseInput(True)
                        db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
                    End Using
                End Using
            Catch ex As System.Exception
                ed.WriteMessage(ex.Message)
            End Try
        End Sub
~'J'~
Hallex
Message 3 of 35 (761 Views)
04-21-2012 01:46 PM in reply to: Hallex
Here is updated code
        Public Sub PntBlk()
            ofd.FilterIndex = 0
                Return
            Else
            End If
            Try
                        ppo.Message = vbLf + "Pick a first point: "
                        If ppr.Status <> PromptStatus.OK Then Return
                        doc.TransactionManager.QueueForGraphicsFlush()
                        ppo.Message = vbLf + "Pick a next point (or press ESC to Exit): "
                        Do While ppr.Status = PromptStatus.OK
                            ppr = ed.GetPoint(ppo)
                            If ppr.Status = PromptStatus.Cancel Then Exit Do
                            inst = New BlockReference(ppr.Value, id)
                        Loop
                        doc.TransactionManager.FlushGraphics()
                        ed.UpdateScreen()
                        trans.Commit()
                        ' in case:
                        'db.CloseInput(True)
                        'db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
                    End Using
                End Using
            End Try
        End Sub
~'J'~
Active Contributor
bkenyon13
Message 4 of 35 (740 Views)
04-23-2012 06:38 AM in reply to: bkenyon13
Thank you for the response and the code it is very helpfull.
My goal is to be able to do a selection window and then based on the selection be able to have a block inserted at all the selected points such as at all the end points of all the selected lines.
Like if I had sewer lines that I need to add a manhole symbol to I would be able just to run the command, select the manhol block to use, select the lines I want to add the block too then it would add that block to all the end points of all the lines that I have selected without having to select each location to place it.
I would think it would use the "PromptSelectionOptions" and "PromptSelectionResults", but I have not been able to find a way to have it get the location of the selected entities and insert the block.
Again I am not expecting anyone to write the code, but just point me to the right direction is helpful.  Thank You.
Hallex
Message 5 of 35 (730 Views)
04-23-2012 09:24 AM in reply to: bkenyon13
Okay, here you go, just use method as I shown before to import your blocks
and also change layer name of water profile pipeline inside the code
        Public Shared Function GetPlineCoordinates(ByVal ent As Polyline) As Point3dCollection
            Dim pts As Point3dCollection = New Point3dCollection()
            Dim coord As Point3d
            Dim i As Integer = 0
            For i = 0 To ent.NumberOfVertices - 1
                coord = ent.GetPoint3dAt(i)
                pts.Add(coord)
            Next
            Return pts
        End Function
        <CommandMethod("manholes")> _
        Public Sub InsertManholes()
            Dim blkname As String = "manhole"
            Dim layername As String = "MyLayer"
            Dim ppo As New PromptPointOptions(vbLf & "First corner point: ")
                Return
            End If
            Dim pco As New PromptCornerOptions(vbLf & "Other corner: ", ppr.Value)
            Dim pcr As PromptPointResult = ed.GetCorner(pco)
            If pcr.Status <> PromptStatus.OK Then
                Return
            End If
            Dim p1 As Point3d = ppr.Value
            Dim p2 As Point3d = pcr.Value
            If p1.X = p2.X OrElse p1.Y = p2.Y Then
                ed.WriteMessage(vbLf & "Wrong coordinates specified")
                Return
            End If
            Dim pts As New Point3dCollection()
            pts.Add(p1)
            pts.Add(New Point3d(p2.X, p1.Y, 0))
            pts.Add(p2)
            pts.Add(New Point3d(p1.X, p2.Y, 0))
            Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE"), New TypedValue(8, layername)}
            Dim flt As New SelectionFilter(tv)
            Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
            If res.Status <> PromptStatus.OK Then Return
            MsgBox(res.Value.Count.ToString)
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Try
                    Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                    If Not bt.Has(blkname) Then
                        Return
                    End If
                    Dim blkid As ObjectId = bt(blkname)
                    Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
                    For Each selObj As SelectedObject In res.Value
                        Dim ent As Entity = tr.GetObject(selObj.ObjectId, OpenMode.ForRead)
                        Dim pline As Polyline
                        pline = TryCast(ent, Polyline)
                        If pline IsNot Nothing Then
                            Dim vertices As Point3dCollection = GetPlineCoordinates(pline)
                            For i As Integer = 0 To vertices.Count - 1
                                Dim inst As BlockReference = New BlockReference(vertices(i), blkid)
                                tr.AddNewlyCreatedDBObject(inst, True)
                            Next
                        End If
                    Next
                    tr.Commit()
                End Try
            End Using
        End Sub
~'J'~
Hallex
Message 6 of 35 (725 Views)
04-23-2012 11:33 AM in reply to: Hallex
Here is complete routine if you could not gather them all
                pts.Add(coord)
            Next
            Return pts
        End Function
        Public Sub ApplyAttributes(db As Database, tr As Transaction, bref As BlockReference)
            Dim btrec As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
            If btrec.HasAttributeDefinitions Then
                Dim atcoll As Autodesk.AutoCAD.DatabaseServices.AttributeCollection = bref.AttributeCollection
                For Each subid As ObjectId In btrec
                    Dim ent As Entity = DirectCast(subid.GetObject(OpenMode.ForRead), Entity)
                    Dim attDef As AttributeDefinition = TryCast(ent, AttributeDefinition)
                    If attDef IsNot Nothing Then
                        Dim attRef As New AttributeReference()
                        attRef.SetDatabaseDefaults()
                        'optional
                        attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                        attRef.Position = attDef.Position.TransformBy(bref.BlockTransform)
                        attRef.Justify = attDef.Justify
                        'must be added all other properties for right position, eg. alignment modes etc
                        attRef.Tag = attDef.Tag
                        attRef.AdjustAlignment(db)
                        atcoll.AppendAttribute(attRef)
                        tr.AddNewlyCreatedDBObject(attRef, True)
                    End If
                Next
            End If
        End Sub
        <CommandMethod("manholes", CommandFlags.Session Or CommandFlags.Modal)> _
            ofd.FilterIndex = 0
                Return
            Else
            End If
                Return
            End If
                Return
            End If
                Return
            End If
            pts.Add(p1)
            pts.Add(p2)
                    Try
                            blkid = db.Insert(name, ndb, True)
                        End If
                        blkid = bt(blkname)
                                    ApplyAttributes(db, tr, inst)
                                Next
                            End If
                        Next
                        tr.Commit()
                        ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                    End Try
                End Using
            End Using
        End Sub
~'J'~
Active Contributor
bkenyon13
Message 7 of 35 (713 Views)
04-24-2012 06:18 AM in reply to: bkenyon13
Thank you for all your help.
I got your code and tried it, but when I first tried it nothing happened.  it did not insert any blocks and also did not give me any errors.
However I then modified the code for the OFD part to be as follows:
Dim ofd AsNew OpenFileDialog(title:="Block Selection", extension:="dwg", defaultName:="", dialogName:="Block Selection", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSites)
        ofd.ShowDialog()
I am not sure exactly the difference, but I believe what I changed was for the dialog to open in AutoCAD rather then Windows.
I then ran the command again and get the following error:
eKeyNotFound
at Autodesk.AutoCAD.DatbaseServices.SymbolTable.get_item(String Key)
at PntBlk.Class1.Insertmanholes ()
Not exactly sure what that means, but there is no reference to the symboltable.get_item any where in the code, but maybe needs to be??
Not sure why it would want the SymbolTable and at this time I am not able to examine the code to try and work it out.  All and any assistance is greatly appreciated.
Hallex
Message 8 of 35 (708 Views)
04-24-2012 07:08 AM in reply to: bkenyon13
I have no ideas about this issue
Try to use "manhole.dwg" where you do the followingt:
create your "block image" as few circles and attribute definitions
but don't to create it as block itself, then save and close
then run my code again
~'J'~
Active Contributor
bkenyon13
Message 9 of 35 (685 Views)
04-26-2012 07:13 AM in reply to: bkenyon13
I have had some time to look at the code and I have been able to get it to work.
The error was coming from the line of "blkisd= bt (blkname)"
Not exactly sure why, but I removed that and redid a liitle bit of the code and it is not working like a charm.
However there is one more factor that I would like to add and I am not sure where or how.  I would like to have this command work for Lines, Polylines and Point entities in CAD.
would that be easily done by adding some more code to where the "LWPOLYLINE" is or would the entire thing have to be modified to get the coordinates of the different entities.
again if you can just let me know that I am on the right path that will help.
Active Contributor
bkenyon13
Message 10 of 35 (682 Views)
04-26-2012 07:31 AM in reply to: bkenyon13
Ammendment to the last post.
The code IS working like a charm.
and the line of code that was giving the error was "blkid = bt (blkname)"
sorry for the misspellings and so on.
Again also if I can get this to work for multiple entities other then just polylines then it would be perfect.
Thanks for all your efforts.
You are not logged in.
Ask the Community
