.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Insert Block on Multiple Selected Points
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to put something together that will allow a user to select objects in AutoCAD and then place a block at all the selected points.
Below I have pasted the code that I have so far, but have not been able to test this to see what happens because the Dim ofd part is giving me an error that I have not been able to figure out. I am only a beginner at this so my code may be wrong and/or ugly.
The error that I am getting says that :
Argument not specified for parameter "flags" of "Public Sub New(title As String, defaultName As String, extension As String, dialogName As String, flags As Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDi
Code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Windows
PublicClass Class1
<CommandMethod("pntblk")> _
PublicSub PntBlk()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim blktbl As BlockTable
blktbl = trans.GetObject(db.BlockTableId, _
OpenMode.ForRead)
Dim ofd AsNew OpenFileDialog(dialogName:="Block Selection")
Dim ppo As PromptPointOptions = New PromptPointOptions(SelectionMethod.Crossing)
Dim ppr As PromptPointResult = ed.GetPoint(ppo)
Dim ndb As Database = New Database(False, True)
ndb.ReadDwgFile(ofd.Filename, FileOpenMode.OpenForReadAndReadShare,True, Nothing)
Dim name AsString = SymbolUtilityServices.GetBlockNameFromInsertPathNa
Dim id As ObjectId = db.Insert(name, ndb, True)
Dim btr As BlockTableRecord = CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim inst As BlockReference = New BlockReference(ppr.Value, id)
btr.AppendEntity(inst)
inst.SetDatabaseDefaults()
trans.AddNewlyCreatedDBObject(inst,True)
trans.Commit()
EndUsing
End Sub
End Class
Any Assistance will be appreciated.
Re: Insert Block on Multiple Selected Points
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure about of your task but maybe this
will help with FileDialog,
Just changea file name to save the newly created drawing:
<CommandMethod("pntblk", CommandFlags.Session Or CommandFlags.Modal)> _
Public Sub PntBlk()
Dim ofd As New Windows.Forms.OpenFileDialog
ofd.Title = "Block Selection"
ofd.Filter = "Drawings (*.dwg)|*.dwg"
ofd.FilterIndex = 0
ofd.Multiselect = False
ofd.InitialDirectory = Environment.CurrentDirectory
If ofd.ShowDialog <> Windows.Forms.DialogResult.OK Then
Return
Else
MsgBox(ofd.FileName)
End If
Dim fname As String = "C:\Test\MYDWG.dwg"
Try
Using doclock As DocumentLock = doc.LockDocument
blktbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
Dim ppo As PromptPointOptions = New PromptPointOptions("") ''(SelectionMethod.Crossing)
ppo.Message = vbLf + "Pick a point: "
ndb.ReadDwgFile(ofd.FileName, FileOpenMode.OpenForReadAndReadShare, True, Nothing)
Dim name As String = SymbolUtilityServices.GetBlockNameFromInsertPathNa me(ofd.FileName)
trans.AddNewlyCreatedDBObject(inst, True)
trans.Commit()
db.CloseInput(True)
db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
End Using
End Using
Catch ex As System.Exception
ed.WriteMessage(ex.Message)
End Try
End Sub
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is updated code
Public Sub PntBlk()
ofd.FilterIndex = 0
Return
Else
End If
Try
ppo.Message = vbLf + "Pick a first point: "
If ppr.Status <> PromptStatus.OK Then Return
doc.TransactionManager.QueueForGraphicsFlush()
ppo.Message = vbLf + "Pick a next point (or press ESC to Exit): "
Do While ppr.Status = PromptStatus.OK
ppr = ed.GetPoint(ppo)
If ppr.Status = PromptStatus.Cancel Then Exit Do
inst = New BlockReference(ppr.Value, id)
Loop
doc.TransactionManager.FlushGraphics()
ed.UpdateScreen()
trans.Commit()
' in case:
'db.CloseInput(True)
'db.SaveAs(fname, False, DwgVersion.Current, db.SecurityParameters)
End Using
End Using
End Try
End Sub
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for the response and the code it is very helpfull.
My goal is to be able to do a selection window and then based on the selection be able to have a block inserted at all the selected points such as at all the end points of all the selected lines.
Like if I had sewer lines that I need to add a manhole symbol to I would be able just to run the command, select the manhol block to use, select the lines I want to add the block too then it would add that block to all the end points of all the lines that I have selected without having to select each location to place it.
I would think it would use the "PromptSelectionOptions" and "PromptSelectionResults", but I have not been able to find a way to have it get the location of the selected entities and insert the block.
Again I am not expecting anyone to write the code, but just point me to the right direction is helpful. Thank You.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Okay, here you go, just use method as I shown before to import your blocks
and also change layer name of water profile pipeline inside the code
Public Shared Function GetPlineCoordinates(ByVal ent As Polyline) As Point3dCollection
Dim pts As Point3dCollection = New Point3dCollection()
Dim coord As Point3d
Dim i As Integer = 0
For i = 0 To ent.NumberOfVertices - 1
coord = ent.GetPoint3dAt(i)
pts.Add(coord)
Next
Return pts
End Function
<CommandMethod("manholes")> _
Public Sub InsertManholes()
Dim blkname As String = "manhole"
Dim layername As String = "MyLayer"
Dim ppo As New PromptPointOptions(vbLf & "First corner point: ")
Return
End If
Dim pco As New PromptCornerOptions(vbLf & "Other corner: ", ppr.Value)
Dim pcr As PromptPointResult = ed.GetCorner(pco)
If pcr.Status <> PromptStatus.OK Then
Return
End If
Dim p1 As Point3d = ppr.Value
Dim p2 As Point3d = pcr.Value
If p1.X = p2.X OrElse p1.Y = p2.Y Then
ed.WriteMessage(vbLf & "Wrong coordinates specified")
Return
End If
Dim pts As New Point3dCollection()
pts.Add(p1)
pts.Add(New Point3d(p2.X, p1.Y, 0))
pts.Add(p2)
pts.Add(New Point3d(p1.X, p2.Y, 0))
Dim tv As TypedValue() = New TypedValue() {New TypedValue(0, "LWPOLYLINE"), New TypedValue(8, layername)}
Dim flt As New SelectionFilter(tv)
Dim res As PromptSelectionResult = ed.SelectCrossingPolygon(pts, flt)
If res.Status <> PromptStatus.OK Then Return
MsgBox(res.Value.Count.ToString)
Using tr As Transaction = db.TransactionManager.StartTransaction
Try
Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
If Not bt.Has(blkname) Then
Return
End If
Dim blkid As ObjectId = bt(blkname)
Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
For Each selObj As SelectedObject In res.Value
Dim ent As Entity = tr.GetObject(selObj.ObjectId, OpenMode.ForRead)
Dim pline As Polyline
pline = TryCast(ent, Polyline)
If pline IsNot Nothing Then
Dim vertices As Point3dCollection = GetPlineCoordinates(pline)
For i As Integer = 0 To vertices.Count - 1
Dim inst As BlockReference = New BlockReference(vertices(i), blkid)
tr.AddNewlyCreatedDBObject(inst, True)
Next
End If
Next
tr.Commit()
End Try
End Using
End Sub
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is complete routine if you could not gather them all
pts.Add(coord)
Next
Return pts
End Function
Public Sub ApplyAttributes(db As Database, tr As Transaction, bref As BlockReference)
Dim btrec As BlockTableRecord = TryCast(tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
If btrec.HasAttributeDefinitions Then
Dim atcoll As Autodesk.AutoCAD.DatabaseServices.AttributeCollect ion = bref.AttributeCollection
For Each subid As ObjectId In btrec
Dim ent As Entity = DirectCast(subid.GetObject(OpenMode.ForRead), Entity)
Dim attDef As AttributeDefinition = TryCast(ent, AttributeDefinition)
If attDef IsNot Nothing Then
Dim attRef As New AttributeReference()
attRef.SetDatabaseDefaults()
'optional
attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
attRef.Position = attDef.Position.TransformBy(bref.BlockTransform)
attRef.Justify = attDef.Justify
'must be added all other properties for right position, eg. alignment modes etc
attRef.Tag = attDef.Tag
attRef.AdjustAlignment(db)
atcoll.AppendAttribute(attRef)
tr.AddNewlyCreatedDBObject(attRef, True)
End If
Next
End If
End Sub
<CommandMethod("manholes", CommandFlags.Session Or CommandFlags.Modal)> _
ofd.FilterIndex = 0
Return
Else
End If
Return
End If
Return
End If
Return
End If
pts.Add(p1)
pts.Add(p2)
Try
blkid = db.Insert(name, ndb, True)
End If
blkid = bt(blkname)
ApplyAttributes(db, tr, inst)
Next
End If
Next
tr.Commit()
ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
End Try
End Using
End Using
End Sub
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for all your help.
I got your code and tried it, but when I first tried it nothing happened. it did not insert any blocks and also did not give me any errors.
However I then modified the code for the OFD part to be as follows:
Dim ofd AsNew OpenFileDialog(title:="Block Selection", extension:="dwg", defaultName:="", dialogName:="Block Selection", flags:=OpenFileDialog.OpenFileDialogFlags.NoFtpSit
ofd.ShowDialog()
I am not sure exactly the difference, but I believe what I changed was for the dialog to open in AutoCAD rather then Windows.
I then ran the command again and get the following error:
eKeyNotFound
at Autodesk.AutoCAD.DatbaseServices.SymbolTable.get_i
at PntBlk.Class1.Insertmanholes ()
Not exactly sure what that means, but there is no reference to the symboltable.get_item any where in the code, but maybe needs to be??
Not sure why it would want the SymbolTable and at this time I am not able to examine the code to try and work it out. All and any assistance is greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have no ideas about this issue
Try to use "manhole.dwg" where you do the followingt:
create your "block image" as few circles and attribute definitions
but don't to create it as block itself, then save and close
then run my code again
~'J'~
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have had some time to look at the code and I have been able to get it to work.
The error was coming from the line of "blkisd= bt (blkname)"
Not exactly sure why, but I removed that and redid a liitle bit of the code and it is not working like a charm.
However there is one more factor that I would like to add and I am not sure where or how. I would like to have this command work for Lines, Polylines and Point entities in CAD.
would that be easily done by adding some more code to where the "LWPOLYLINE" is or would the entire thing have to be modified to get the coordinates of the different entities.
again if you can just let me know that I am on the right path that will help.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ammendment to the last post.
The code IS working like a charm.
and the line of code that was giving the error was "blkid = bt (blkname)"
sorry for the misspellings and so on.
Again also if I can get this to work for multiple entities other then just polylines then it would be perfect.
Thanks for all your efforts.
