Somebody help me how to insert block, but waiting for user input rotation.
Solved by Alfred.NESWADBA. Go to Solution.
as there are muliple methods available of how to insert a block (starting with sendcommand, using com or doing it with managed coding) show what you have currently, so we know where to continue/step in.
- alfred -
My work is insert a block (waiting for user input rotation) then delete a polyline. I used 'SendStringToExecute' method.
My solution:
public static ObjectId DgiongID;
public static event EventHandler eRainManhole;
[CommandMethod("RainManhole")]
public static void RainManhole()
if (eRainManhole != null)
eRainManhole(null, null);
[CommandMethod("Rman")]
public static void InsertRman()
Get one point form user
Offset from one center line to this point, this offset objectID store in DgiongID
User pick a point in offset object store in Pchen
Insert a block at that point and waiting for user input rotation, then delete object: DgiongID
string command = "(command " + '"' + "Insert" + '"' + " " + '"' + "$RSman$ ";
command = command + "'(" + Pchen.X + " " + Pchen.Y + ") ";
command = command + "1 1 pause " + '"' + "RainManhole" + '"' + ") ";
eRainManhole += new EventHandler(DeleteGiong);
acDoc.SendStringToExecute(command, false, false, false);
public static void DeleteGiong(object sender, EventArgs e)
Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
Transaction acTrans = acCurDb.TransactionManager.StartTransaction();
using (acTrans)
DBObject Dgiong = (DBObject)acTrans.GetObject(DgiongID, OpenMode.ForWrite, true, true);
Dgiong.Erase();
acTrans.Commit();
With this solution everyhing is done. But the problem is if user hit the UP ARROW KEY in AutoCAD command history is not my defined command, they have to hit twice if want to get 'RMAN' command. It's not flexible for user when they want to do this function continuously. So I ask for a better solution.
thanks.
Perhaps, you might want to use Getangle method?
Here is my 2 cents:
[CommandMethod("insRot")] public void InsertSample() { // put your block name here string blkname = "ARW"; Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; //Specify insertion point PromptPointOptions ppo = new PromptPointOptions("\nPick Insertion point:"); PromptPointResult ppr = ed.GetPoint(ppo); if (ppr.Status != PromptStatus.OK) return; Point3d p1 = ppr.Value; //Specify rotation angle PromptAngleOptions pae = new PromptAngleOptions("\nSpecify an angle:"); pae.DefaultValue = 0.0; pae.BasePoint = p1; pae.UseBasePoint = true; PromptDoubleResult ares = ed.GetAngle(pae); if (ares.Status != PromptStatus.OK) return; double ang = ares.Value; using (Transaction tr = db.TransactionManager.StartTransaction()) { try { // get the block table BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable; // check if block exists if (!bt.Has(blkname)) { ed.WriteMessage("\nBlock does not exist!"); return; } // get objectid of BlockTableRecord ObjectId blkid = bt[blkname]; // get the current space BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord; // create new BlockReference BlockReference bref = new BlockReference(p1, blkid); bref.SetDatabaseDefaults(); // set block rotation bref.Rotation = ang; // set scale bref.ScaleFactors = new Scale3d(1); //set layer bref.Layer = "0"; //' ETC... // add block to database and transaction btr.AppendEntity(bref); tr.AddNewlyCreatedDBObject(bref, true); // < rest your work with attributes here > ' //commits the drawing changes tr.Commit(); } catch (System.Exception ex) { ed.WriteMessage(ex.Message + "\n" + ex.StackTrace); } } }
~'J'~
thank you Mr. Hallex. It's really usefull. But I need when waiting for input rotation. We already insert the block. The user can see how the block rotate in screen.
regard,
If you already use LISP in your SendCommand, then make a string based on your current one with defun():
(defun C:XX() ( .... place your command here ....) )
then send this with the first SendCommand
After that start the following string with an extra SendCommand
(command "XX")
If your customer now repeats the last command, he will repeat XX and that is what you wanted, isn't it?
- alfred -
Before I already did this way. The main function name is: Rman and the define new one in LISP is XX. But I need the lasted command in command history is the main function Rman, no more. In my solution. If user hit up key, command will return to (command .....) but right click (with settings in AutoCad options at 'User Preferences': No ShortCut menu..) it will launch my main function (Rman).
In my thinking, if we use send command any way. the lasted command will be not main command. Is there another way to do it without sending command.
then try for the last command not to start (command "XX") but just start XX
HTH, - alfred -
Then you change your command string like this
string command = "(command " + '"' + "-insert" + '"' + " " + '"' + "Your block name" + '"'; command = command + "(list " + p1.X + " " + p1.Y + ") "; command = command + "1 1 " + "pause" + ") "; //+'"' + "RainManhole" + '"' + ") "; //eRainManhole += new EventHandler(DeleteGiong); doc.SendStringToExecute(command, true, false, false);
where p1 is picked point from my code above
~'J'~
can not remove calling RainManhole in command. Also add event to it ( eRainManhole += new EventHandler(DeleteGiong);) Because of waiting finish this command, I need to continuous more work.
Yes, correctly the last command is XX. But I need lasted is: Rman (with my code). That why, I told for another solution not send command.
Regard,
sorry, then I totally misunderstood your need ;(
Well then there are two options, one is you use JIG's, the other one is to sendcommand RMAN as you last command with a built in break, so the command was called (for command history) but you have an option to cancel it when called at this specific way (but that's not a solution I would preferre).
- alfred -
