.NET
Initiate AutoCAD 2013 from Windows Service
2 REPLIES 2
chockalingam
791 Views, 2 Replies
   I am trying to initiate AutoCAD 2013 through Windows Service using the Following code but i am not getting instance. Can any one help me in this regarding.
 This is what i tried....
const string progID = "AutoCAD.Application.19";
AcadApplication acApp = null;
try
Type acType = Type.GetTypeFromProgID(progID);
acApp = (AcadApplication)Marshal.GetActiveObject(progID);
acApp.Visible = true;
return acApp;
catch
try
acApp = (AcadApplication)Activator.CreateInstance(acType);
return acApp;
catch (Exception ex)
return acApp;
2 REPLIES 2
Hi
Trying to start AutoCAD from windows service is not supported / tested. That said I think you would have much better results using the accoreconsole.exe that comes with AutoCAD 2013. Refer DevTV  “Getting started with AccoreConsole” in DevBlog @ http://adndevblog.typepad.com/autocad/2012/04/getting-started-with-accoreconsole.html
Note: Even accoreconsole.exe is not supported / tested under windows service condition
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
khoa.ho
in reply to: chockalingam
Another good resource for AutoCAD 2013 Core Console can be found at the ongoing AU 2012. The class "CP3338 - Using .NET Programming to Create New Possibilities with the AutoCAD® Core Console" of Augusto Goncalves can be found at the link. You also need to create an account to be able to download free documents.
-Khoa
”Boost
