Solved by norman.yuan. Go to Solution.
Have you managed to find out anything on this issue of setting a pagesetup (plotsettings object) as current?
Since I have not done this before, I decided to put togeter some quick code. It copies a layout from a drawing file into the current drawing in Acad. Here is the code:
using System; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; [assembly: CommandClass(typeof(CopyPageSetup.MyCommand))] namespace CopyPageSetup { public class MyCommand { [CommandMethod("CopyLayout")] public void RunThisMethod() { //The template drawing containing a layout named as //"MyLayout" with desired page setup string sourceDwg = @"E:\Temp\Test.dwg"; string layoutName = "MyLayout"; Document dwg = Autodesk.AutoCAD.ApplicationServices .Application.DocumentManager.MdiActiveDocument; //Get source database Database db = null; try { db = GetSourceDatabase(sourceDwg); } catch (System.Exception ex) { dwg.Editor.WriteMessage( "\nReading source drawing error:\n {0}\n.", ex.Message); return; } //If a layout with the same name as in the source drawing //exists. If yes, the layout's page setup will be overwritten LayoutManager mgr = LayoutManager.Current; try { //Set the eixsting layout active mgr.CurrentLayout = layoutName; } catch { //create the alyout and set it active mgr.CreateLayout(layoutName); mgr.CurrentLayout = layoutName; } //Do layout page setup copying using (db) { try { CopyLayout(db, layoutName, dwg.Database, mgr.GetLayoutId(layoutName)); } catch (System.Exception ex) { dwg.Editor.WriteMessage( "\nCopying layout error:\n {0}\n.", ex.Message); return; } } dwg.Editor.Regen(); dwg.Editor.WriteMessage("\nLayout copy completed."); } #region private methods private Database GetSourceDatabase(string sourceFile) { Database db = new Database(); db.ReadDwgFile(sourceFile, FileOpenMode.OpenForReadAndReadShare, false, null); return db; } private void CopyLayout(Database sourceDB, string layoutName, Database thisDB, ObjectId thisLayoutID) { using (Transaction tran = sourceDB.TransactionManager.StartTransaction()) { DBDictionary lay1Dic = (DBDictionary) tran.GetObject(sourceDB.LayoutDictionaryId, OpenMode.ForRead); try { //Get source layout object in the source database ObjectId lay1ID = lay1Dic.GetAt(layoutName); Layout lay1 = (Layout)tran.GetObject(lay1ID, OpenMode.ForRead); using (Transaction t = thisDB.TransactionManager.StartTransaction()) { //Get the destination layout in current database Layout lay2 = (Layout) t.GetObject(thisLayoutID, OpenMode.ForWrite); try { //Copy layout lay2.CopyFrom(lay1); t.Commit(); } catch { t.Abort(); throw; } } } catch { tran.Abort(); throw; } } } #endregion } }
HTH.
Norman,
At the risk of sounding like the one particular smartaleck that posts on here and other AutoCAD sites simply to ridicule and poke fun at perfectly serious questions and suggestions, what does your post have to do with the original question or my query? Your code is first of all in C# and the question requests a VB.Net solution and the requested solution deals with page setup/plot settings objects while your code is for copying layouts. Sure, one or more plot settings objects would be part of the drawing the copied layout comes from and layouts are derived from plotsettings objects, but which one is current for the drawing?
I don't want to discourage anyone from answering posts, but you really need to make your reply have something to do with the posted question.
For all posters, I would like to make a request that if you post a question and then find an answer on your own, please come back and post that solution. This thread is one of several that I have found asking the same questions I was researching, but with no updates or posted solutions. Even if the result was to abandon that line of pursuit because no solution was found in the allotted time for the project that is all good information.
Kerry
Are you the same person as "mike.wohletz"? If not, where is your ORIGINALPOST which specifically requires VB.NET solution?
The posts here is focusing on logic of Acad .NET solution, not on the language itself, especially when it is .NET code. If the code does what you want, are you going to ask some do the language conversion?
I am a bit sorry if you did not find the code is useful for you, after all it is not directly to your question. Given the not-so-detailed original post, if I assumed the OP wants to import page setup/plotting setup from other drawing's layout, at least the code works on that assumption.
If you bother to describe your requirement in details in YOUR OWN POST, someone might put forth a solution perfectly suitable to you, or there might be no solution at all because of very odd requirements, no one knows ahead of time until one can see your reasonably described post.
The only thing you've achieved here is to ensure that future
requests for help from you will probably be ignored.
@KLGalloway wrote:Norman,
Kerry
Norman,
I will just quote the original post with some added emphasis which actually was pretty detailed and very concise - "I am lost as to how to go about importing a page setup from a template file and set it current, I am using vb.net and working with AutoCAD 2010".
Never said the original post was mine only the later inquiry. You wrote "Given the not-so-detailed original post, if I assumed the OP wants to import page setup/plotting setup from other drawing's layout, at least the code works on that assumption". Actually your code doesn't import a page setup from another drawings layout. It imports the entire layout which is not the same at all; it doesn’t even look for page setups much less set one of them current and is actually not a good thing at all.
If I just want the page setup I can get that easily enough and there are lots of examples in VB.Net and C# around to do that without having to drag over and add an entire layout to my drawing. The important part is setting a particular plot settings object as current programmatically which still needs a solution.
Tell you what, Tony, I don't see a downside to having you ignore my posts. After all you were the contributor I referenced in my first reply to Norman.
Mike,
Here is the code that I have so far. The one thing that it doesn't explicitly do is set the copied or created PlotSettings object to current as per the first dialog when working with PageSetups. Let me know if you have questions. The constants are pretty self-explanatory and I haven’t included their contents as many of them contain company proprietary information. The code insert function for the forum keeps the indentations, but is not wide enough to keep the lines from wrapping so you will probably want to paste the code into VS to read through it.
Kerry
These are the imports from the code module not all of which are used by the two procedures included here.
Imports System Imports System.Drawing.Printing Imports System.Windows.Forms Imports Autodesk.AutoCAD Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.ApplicationServices.Application Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.Interop Imports Autodesk.AutoCAD.Interop.Common Imports Autodesk.AutoCAD.PlottingServices Imports Autodesk.AutoCAD.Runtime
Public Function CopyPageSetupFromFile(ByVal SourceName As String, ByVal CallerName As String) As Boolean '*************************************************************************************************************** ' Procedure Name: CopyPageSetupFromFile ' ' Purpose: Checks for the Passed PlotSettings Object in the Source Drawing File and Copies It to the Current Drawing's Layout1 ' ' Return Values: True/False ' ' Assumptions: Any Called Procedures will Provide Error Handling and Messages ' ' Globals: N/A ' '*************************************************************************************************************** Const CONST_PROCEDURE_NAME As String = "CopyPageSetupFromFile" ' Declare and Instanciate the Variables Needed for Handling the External Source Document. Dim objSourceDatabase As New Database Dim objSourceTransactionManager As DatabaseServices.TransactionManager '**************** Source Transaction Starts Here **************** objSourceTransactionManager = objSourceDatabase.TransactionManager Using objSourceTransaction As DatabaseServices.Transaction = objSourceTransactionManager.StartTransaction() ' Set Up the Source File Name Dim SourceFilePath As String = CONST_SPE_FILEPATH & "\" & SourceName.ToUpper & CONST_DWG_EXTENSION.ToUpper ' Try to Open the Source Drawing File Try objSourceDatabase.ReadDwgFile(SourceFilePath, FileOpenMode.OpenForReadAndReadShare, True, "") Catch excAutoCAD As Autodesk.AutoCAD.Runtime.Exception ' Handle Specific AutoCAD Exceptions Then ' Generic AutoCAD Exceptions and Then Generic System Exceptions Dim strMessage As String If excAutoCAD.Message = "eFileNotFound" Then strMessage = "An Error Occurred While Attempting to Insert the Layout from" & vbCrLf & _ SourceFilePath & " as a Source Drawing." & vbCrLf & vbCrLf & _ "The File must be Located in Your SPE Folder and Must Have the " & vbCrLf & _ "Values Set as per the SPE Installation Instructions." & vbCrLf & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) Return False Else strMessage = CONST_ACAD_ERRMSG_START & CONST_PROCEDURE_NAME & _ CONST_GEN_ERRMSG_MIDDLE & excAutoCAD.ToString & _ CONST_GEN_ERRMSG_END & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) Return False End If Catch excGeneric As System.Exception Dim strMessage As String strMessage = CONST_GEN_ERRMSG_START & CONST_PROCEDURE_NAME & _ CONST_GEN_ERRMSG_MIDDLE & excGeneric.ToString & _ CONST_GEN_ERRMSG_END & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) Return False End Try Dim objSourcePlotSettings As PlotSettings = New PlotSettings(False) Dim objSourcePlotSettingsDictionary As DBDictionary = objSourceTransaction.GetObject _ (objSourceDatabase.PlotSettingsDictionaryId, OpenMode.ForRead) ' Get the Passed PlotSettings Object as the Source If It Exists in the Source Drawing Dim PlotSettingsFound = False If objSourcePlotSettingsDictionary.Count > 0 Then For Each objDictionaryEntry As DictionaryEntry In objSourcePlotSettingsDictionary If String.Compare(objDictionaryEntry.Key.ToString.ToUpper, SourceName.ToUpper, True) = 0 Then objSourcePlotSettings = objSourceTransaction.GetObject(objDictionaryEntry.Value, OpenMode.ForRead) PlotSettingsFound = True Exit For End If Next End If ' If It was Not Found, We Need to Send a Message and Shutdown the InsertMat Program If Not PlotSettingsFound Then Dim strMessage = "The File " & SourceFilePath & " Does Not Contain the " & SourceName & " Page Setup." & vbCrLf & _ "You Must Rebuild the " & SourceName.ToUpper & CONST_DWG_EXTENSION & " File." & vbCrLf & _ "The File must be Located in Your SPE Folder and Must Have the " & vbCrLf & _ "Values Set as per the SPE Installation Instructions." & vbCrLf & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) Return False End If '******************************************************************************************** ' Set the Current Drawing Object to the Application's Active Document - Replaces ThisDrawing '******************************************************************************************** Dim objCurrentDrawing As Document = DocumentManager.MdiActiveDocument '******** The CurrentDrawing Object will be the Destination Drawing for This Routine ******** ' Set The Other Variables Needed to Handle the CurrentDrawing and Its Objects Dim objDatabase As Database = objCurrentDrawing.Database Dim objTransactionManager As DatabaseServices.TransactionManager = objDatabase.TransactionManager '**************** Destination Transaction Starts Here **************** Using objTransaction As DatabaseServices.Transaction = objTransactionManager.StartTransaction() If SetLayoutAsCurrent(CONST_LAYOUT1, CallerName) Then ' The Layout Exists and is Current So Get a Reference to It Using the Layout Manager Dim objLayoutManager As LayoutManager = LayoutManager.Current Dim objLayout As Layout = objTransaction.GetObject(objLayoutManager.GetLayoutId(objLayoutManager.CurrentLayout), _ OpenMode.ForWrite) ' Output the Name of the Current Layout and Its Device objCurrentDrawing.Editor.WriteMessage(vbLf & "Current Layout: " & objLayout.LayoutName & vbLf) objCurrentDrawing.Editor.WriteMessage("Current Plot Configuration Name: " & objLayout.PlotConfigurationName & vbLf) ' Reference the Destination PlotSettings Dictionary Dim objPlotSettingsDictionary As DBDictionary = objTransaction.GetObject(objDatabase.PlotSettingsDictionaryId, _ OpenMode.ForRead) ' If the Passed PlotSettings Object Exists in the Current Drawing, Delete It If objPlotSettingsDictionary.Count > 0 Then For Each objDictionaryEntry As DictionaryEntry In objPlotSettingsDictionary If String.Compare(objDictionaryEntry.Key.ToString.ToUpper, SourceName.ToUpper, True) = 0 Then objPlotSettingsDictionary.UpgradeOpen() objPlotSettingsDictionary.Remove(objDictionaryEntry.Value) objPlotSettingsDictionary.DowngradeOpen() Exit For End If Next End If ' Create the Destination PlotSettings Object and Populate It from the Source PlotSettings Dim objDestinationPlotSettings As PlotSettings = New PlotSettings(False) objDestinationPlotSettings.CopyFrom(objSourcePlotSettings) ' Update the PlotSettings Object to Make It Handle the Mat Insertion Dim objDestinationPlotSettingsValidator As PlotSettingsValidator = PlotSettingsValidator.Current ' Set to Use a Standard Scale Type 1:1 If Not objDestinationPlotSettings.UseStandardScale Then objDestinationPlotSettingsValidator.SetUseStandardScale(objDestinationPlotSettings, True) End If If Not objDestinationPlotSettings.StdScaleType = StdScaleType.StdScale1To1 Then objDestinationPlotSettingsValidator.SetStdScaleType(objDestinationPlotSettings, StdScaleType.StdScale1To1) End If ' Set to Scale the Lineweights If Not objDestinationPlotSettings.ScaleLineweights Then objDestinationPlotSettings.ScaleLineweights = True End If ' Make Sure that the Plot is in Landscape If Not objDestinationPlotSettings.PlotRotation = PlotRotation.Degrees090 Then objDestinationPlotSettingsValidator.SetPlotRotation(objDestinationPlotSettings, PlotRotation.Degrees090) End If ' Set to Plot Extents If Not objDestinationPlotSettings.PlotType = DatabaseServices.PlotType.Extents Then objDestinationPlotSettingsValidator.SetPlotType(objDestinationPlotSettings, DatabaseServices.PlotType.Extents) End If ' Add the Plot Settings Object to the Destination Plot Settings Dictionary objDestinationPlotSettings.AddToPlotSettingsDictionary(objDatabase) objLayout.CopyFrom(objDestinationPlotSettings) ' Confirm that the Copied PlotSettings Object Exists in the Current Drawing's Plot Settings Dictionary PlotSettingsFound = False If objPlotSettingsDictionary.Count > 0 Then For Each objDictionaryEntry As DictionaryEntry In objPlotSettingsDictionary If String.Compare(objDictionaryEntry.Key.ToString.ToUpper, SourceName.ToUpper, True) = 0 Then PlotSettingsFound = True ' Output the Name of the Copied PlotSettings Object and Its Device Name objCurrentDrawing.Editor.WriteMessage(vbLf & "Copied PlotSettings: " & objLayout.PlotSettingsName & vbLf) objCurrentDrawing.Editor.WriteMessage("Copied Device Name: " & objLayout.PlotConfigurationName & vbLf) Exit For End If Next End If objPlotSettingsDictionary = Nothing ' If It was Not Found, We Need to Send a Message and Shutdown the InsertMat Program If Not PlotSettingsFound Then Dim strMessage = "The " & SourceName & " Page Setup Did Not Copy Correctly!" & vbCrLf & vbCrLf & _ "You Must Rebuild the " & SourceName.ToUpper & CONST_DWG_EXTENSION & " File." & vbCrLf & _ "The File must be Located in Your SPE Folder and Must Have the " & vbCrLf & _ "Values Set as per the SPE Installation Instructions." & vbCrLf & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) Return False End If ' Downgrade the Current Layout Mode Back to Read objLayout.DowngradeOpen() ' Commit and Save the Changes to the Current Drawing objTransaction.Commit() ' Clean Up the Destination Objects objDestinationPlotSettingsValidator = Nothing objDestinationPlotSettings = Nothing objLayout = Nothing objCurrentDrawing.Editor.Regen() objCurrentDrawing.Editor.UpdateScreen() Else Dim strMessage = "Layout1 could Not be Set as the Current Layout!" & vbCrLf & vbCrLf & _ "Please be Sure That Layout1 Exists in the '" & objCurrentDrawing.Name & "' Drawing" & vbCrLf & _ "and Re-run the Insert Mat Utility." & vbCrLf & vbCrLf & _ "The Insert Mat Utility will Now be Terminated." & vbCrLf & _ "Use the AutoCAD 'Undo' Button to Undo Changes Made by This Utility." MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) ' Abort and Abandon the Changes to the Current Document objTransaction.Abort() End If End Using ' Destination Transaction ' Clean Up the Current Drawing Transaction Objects objTransactionManager.Dispose() objTransactionManager = Nothing objDatabase = Nothing objCurrentDrawing = Nothing ' Abort Any Changes to the Source Drawing objSourceTransaction.Abort() ' Clean Up the Source Drawing Transaction Objects objSourcePlotSettings = Nothing objSourcePlotSettingsDictionary = Nothing End Using ' Source Transaction objSourceTransactionManager.Dispose() objSourceTransactionManager = Nothing objSourceDatabase.Dispose() objSourceDatabase = Nothing Return True End Function ' CopyPageSetupFromFile
Public Function SetLayoutAsCurrent(ByVal LayoutName As String, ByVal CallerName As String) As Boolean '*************************************************************************************************************** ' Procedure Name: SetLayoutAsCurrent ' ' Purpose: Checks for the Passed Layout in the Current Drawing, Sets It as Current, or Creates It. ' ' Return Values: N/A ' ' Assumptions: Any Called Procedures will Provide Error Handling and Messages ' ' Globals: N/A ' '*************************************************************************************************************** Const CONST_PROCEDURE_NAME As String = "SetLayoutAsCurrent" '******************************************************************************************** ' Set the Current Drawing Object to the Application's Active Document - Replaces ThisDrawing '******************************************************************************************** Dim objCurrentDrawing As Document = DocumentManager.MdiActiveDocument Using objLock As DocumentLock = objCurrentDrawing.LockDocument ' Reference the Layout Manager Dim objLayoutManager As LayoutManager objLayoutManager = LayoutManager.Current ' If the Current Layout is Not the Passed Layout If Not objLayoutManager.CurrentLayout = LayoutName Then ' Set The Other Variables Needed to Handle the Current Drawing's Layouts Dim objDatabase As Database = objCurrentDrawing.Database Dim objTransactionManager As DatabaseServices.TransactionManager = objDatabase.TransactionManager Using objTransaction As Transaction = objTransactionManager.StartTransaction ' Try to Set the Current Layout to the Passed Layout Name Try objLayoutManager.CurrentLayout = LayoutName Catch excAutoCAD As Autodesk.AutoCAD.Runtime.Exception If excAutoCAD.Message = "eSetFailed" Then ' The Passed Layout Doesn't Exist So We Will Create It Dim objLayout As Layout objLayout = objTransaction.GetObject(objLayoutManager.CreateLayout(LayoutName), OpenMode.ForRead) objLayoutManager.CurrentLayout = LayoutName objLayout = Nothing Else Dim strMessage As String strMessage = CONST_ACAD_ERRMSG_START & CONST_PROCEDURE_NAME & _ CONST_GEN_ERRMSG_MIDDLE & excAutoCAD.ToString & _ CONST_GEN_ERRMSG_END & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) objCurrentDrawing = Nothing Return False End If Catch excGeneric As System.Exception Dim strMessage As String strMessage = CONST_GEN_ERRMSG_START & CONST_PROCEDURE_NAME & _ CONST_GEN_ERRMSG_MIDDLE & excGeneric.ToString & _ CONST_GEN_ERRMSG_END & _ CONST_ERRMSG_INSERTMAT_CLOSING MsgBox(strMessage, MsgBoxStyle.ApplicationModal + MsgBoxStyle.Critical + MsgBoxStyle.OkOnly, CallerName) objCurrentDrawing = Nothing Return False End Try ' Commit the Transaction and Dispose of the Transaction Objects objTransaction.Commit() objTransactionManager.Dispose() objTransactionManager = Nothing End Using End If objLayoutManager = Nothing End Using objCurrentDrawing = Nothing Return True End Function ' SetLayoutAsCurrent
I'm pretty confident that it will not only be myself
that'll be ignoring your posts.
It's a shame that you're unable to figure out that a Layout is a PlotSettings
object, whcih explains why you were totally bewildered by the code in Norman's
post.
I'm not going to explain to you everything else you're missing, I would
much rather just sit back and watch you continue to make a complete
fool of yoursef.
It is not only unhelpful, but wrong statements such as your last which make me wish you would ignore my posts.
Here is the blurb on Plot Settings objects from the AutoCAD .NET Developer's Guide with some emphasis added to help out:
A PlotSettings object is similar to a Layout object, as both contain identical plot information and this is because the Layout class is derived from the PlotSettings class. The main difference is that a Layout object has an associated BlockTableRecord object containing the geometry to plot. A PlotSettings object is not associated with a particular BlockTableRecord object. It is simply a named collection of plot settings available for use with any geometry. PlotSettings objects are known as page setups in the AutoCAD user interface and are accessed from the Page Setup Manager.
There wouldn't be an issue if the Guide had just continued with a line or two about getting to them programmatically and performing whatever it is the "Set as Current" button does, but nothing is mentioned.
You really need to do some research before you smart off. You have been no more and probably less helpful to anyone on this issue than you were on this post of mine which first clued me in to your "I'd rather be cryptic and look clever than actually do enough research to be both clever and helpful" attitude. Please, please carry out your menacing and oh so horrible to contemplate threat not to reply to my posts!!! Please!!! Please!!! I<Lovely gratuitous comment about good advertising for your company not included because I really need to quit letting you think you have a chance so you will stop replying>.
And you just did exactly what I said I'd sit back and watch you do.
The docs you quoted unequivocally confirms what just I said (that a
Layout is a PlotSettings object). The fact that you are incapable of
figuring out how to make the settings from the latter 'current' even
after Norman's code shows how to do that, means that you should
probably stop wasting your employer's money.
It's clear from what little participation you've made here, that the problem is on your end,
rather than on mine or Norman's.
The fact that you conveniently confuse "cryptic", with your own comprehension problems
and inexperience would seem to more than adequately explain what leads you to expect
others to go out of their way to spell everything out for you in terms the average third-
grader can understand. Which in-turn, makes it abundantly clear that you really should not be
wasting your employer's money by making misrepresentations about your ability insofar as
customizing AutoCAD with the .NET API.
The attitude you've demonstrated to date in this and the thread you reference above, pretty
much seals your fate, insofar as getting help from this resource, as I'm fairly confident that
most who are able to help you will choose not to bother, after reading your posts.
