Sorry, there may be an error in my example.
It may be that the entity that's highlighted is the *last*
FullSubentityPath, rather than the first, as I noted. You can verify that
with some testing, and I do believe there is some consistency with regards
to that, so if you need more than just the entity (as the rollover event
gives you), then you can still use the PointMonitor event, and get the
correct object.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"Rinze"
wrote in message news:6234000@discussion.autodesk.com...
arcticad wrote:
> http://www.caddzone.com/...
