.NET
Iam still failure in .net
14 REPLIES 14
Message 1 of 15
Amremad
786 Views, 14 Replies
see attatch
14 REPLIES 14
Message 2 of 15
Alexander.Rivilis
in reply to: Amremad
1. What AutoCAD version are you using?
2. Why you add Interops from two version (2011 and 2013) ?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 15
Amremad
in reply to: Alexander.Rivilis
2010 and 2013
Message 4 of 15
Alexander.Rivilis
I do not think you can write one application at once for two versions of AutoCAD. So decide which version of AutoCAD you work. In any case, ObjectARX SDK 2011 is not suitable for AutoCAD 2010 - AutoCAD 2010 need to ObjectARX SDK 2010.
Expert Elite Member
Message 5 of 15
Amremad
!!!! ObjectARX 2013 doesn't work with early version !!!!!!
Message 6 of 15
Alexander.Rivilis
Of course! You read casually (or not read?) what was write for you. @hgasty1001 wrote for you:
Use the ARX SDK with the same name as the AutoCAD version that the appliaction will  run on. Also check the .NET framework supported by the AutoCAD version:
AutoCAD 2011, ARX SDK 2011, .Net 2.0 or 3.5
AutoCAD 2012, ARX SDK 2012, .Net 4.0
AutoCAD 2013, ARX SDK 2013, .Net 4.0
Expert Elite Member
Message 7 of 15
Amremad
in my company we use diffrenet version .. so i must create diffrenet dll to every version??
but it will be hard to create code three time or 4 , 5  🙂 🙂 🙂
Message 8 of 15
Amremad
so i think i can use  ARX SDK 2013 with AutoCAD 2012 & AutoCAD 2013
and i think i can use  ARX SDK 2012 with AutoCAD 2012 & AutoCAD 2013
cause it's have the same verison of .net??
Message 9 of 15
Alexander.Rivilis
It may be same source code (.vb - files) but different project/solution which produce different dll-files. Other way is most hard - using Reflection. As you are beginner I can not recommend to use reflection in order to produce  one dll-file which can work in any AutoCAD version.
Expert Elite Member
Message 10 of 15
Amremad
sorry i have a big confflict in my mind with this techonology 🙂
i think there is why to check version in class that i will do like
if Autocad2013 then
elseif AutoCAD2010 then
end if
Message 11 of 15
Alexander.Rivilis
NO!!!
Expert Elite Member
Message 12 of 15
Alexander.Rivilis
It is look like you have to study VB.NET before. You can use preprocessor directive:
#If expression Then
   statements
[ #ElseIf expression Then
   [ statements ]
   [ statements ] ]
[ #Else
   [ statements ] ]
#End If
http://msdn.microsoft.com/en-us/library/tx6yas69.aspx
Expert Elite Member
Message 13 of 15
Amremad
this is reflection??
Message 14 of 15
Alexander.Rivilis
No. I think you can search internet with string "VB.NET Reflection" yourself.
Expert Elite Member
Message 15 of 15
Amremad
thx alot
”Boost
