.NET
ugur35
Message 1 of 12 (1,098 Views)
I want to read data from a DWG excel file using C#.
1098 Views, 11 Replies
05-18-2013 01:10 AM
this dwg file data reading with c#?
ADN Support Specialist
Balaji_Ram
Message 2 of 12 (1,039 Views)
Re: I want to read data from a DWG excel file using C#.
05-21-2013 06:18 AM in reply to: ugur35
For an embedded Ole object as in your drawing, you can cast the OleObject as "Microsoft.Office.Interop.Excel.Workbook" and then you can use it appropriately using the Excel API to retrieve the data.
Here is a sample code snippet :
Ole2Frame oleFrame = tr.GetObject(id, OpenMode.ForRead) as Ole2Frame;
Microsoft.Office.Interop.Excel.Workbook wb = oleFrame.OleObject as Microsoft.Office.Interop.Excel.Workbook;
Microsoft.Office.Interop.Excel.Worksheet ws = wb.ActiveSheet;
Microsoft.Office.Interop.Excel.Range range = ws.UsedRange;
Balaji
Developer Technical Services
Autodesk Developer Network
ugur35
Message 3 of 12 (1,014 Views)
05-22-2013 12:26 AM in reply to: Balaji_Ram
Hello thank you,
but I could not
can you help me please
Balaji_Ram
Message 4 of 12 (977 Views)
05-23-2013 04:29 AM in reply to: ugur35
Here is a sample code that displays all the values read from the embedded Oleobject.
I have attached a screenshot image to show the output.
[CommandMethod("Test")]
public static void TestMethod()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        BlockTableRecord bt = Tx.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
        foreach (ObjectId id in bt)
            if (id.ObjectClass.Name != "AcDbOle2Frame")
                continue;
            Ole2Frame oleFrame = Tx.GetObject(id, OpenMode.ForRead) as Ole2Frame;
            if (! oleFrame.IsLinked)
                for (int row = 1; row <= 15; row++)
                    for (int col = 1; col <= range.Columns.Count; col++)
                        ed.WriteMessage(String.Format("{0}{1}{2}-{3}", Environment.NewLine, row, col, Convert.ToString((range.Cells[row, col] as Microsoft.Office.Interop.Excel.Range).Value2)));
Balaji
ugur35
Message 5 of 12 (936 Views)
05-25-2013 12:18 AM in reply to: Balaji_Ram
thank you very much
source code was useful :smileyhappy:
ugur35
Message 6 of 12 (708 Views)
07-03-2013 07:00 AM in reply to: ugur35
Thanks for the source code but the transaction did not complete.
I want to do the program .
thank you very much.
ugur35
Message 7 of 12 (637 Views)
07-05-2013 05:25 AM in reply to: ugur35
hi Balaji Thank you for the source code, but unable to set winform can you help?
Balaji_Ram
Message 8 of 12 (632 Views)
07-05-2013 05:52 AM in reply to: ugur35
Can you please explain what you mean by "unable to set winform" ?
You can try having a datagrid in a winform and then provide a data table as its source. The data read from the excel can be used to create a data table.
Sample code to for this can be found in MSDN help :
http://msdn.microsoft.com/en-us/library/system.data.datatable.aspx
http://msdn.microsoft.com/en-us/library/system.windows.forms.datagrid.datasource.aspx
Balaji
ugur35
Message 9 of 12 (626 Views)
07-05-2013 06:02 AM in reply to: Balaji_Ram
hello balaji
application on a Windows form application will be.(C# .NET 4.0)
DO YOU WANT TO PROGRAM
source code is being sent to you in advance .
                continue;
I can not run this code in windows form application.
norman.yuan
Message 10 of 12 (615 Views)
07-05-2013 06:34 AM in reply to: ugur35
Of course you CANNOT run the code in Win Form EXE app: the code uses AutoCAD managed (.NET) API, which CAN ONLY be used to run inside AutoCAD.
If you HAVE to do a stand-alone EXE app, then you have to use AutoCAD COM API to automate AutoCAD. Or, if you do not mind making things more complicated, you could expose the managed code as COM. But either way, AutoCAD must run.
Now, if AutoCAD must run, why do you need the trouble to have an external EXE app? You can just build the same Win form into AutoCAD with the very minor change to the code you showed here. Simply start AutoCAD, enter the command defined in the CommandMethod, off you go.
You are not logged in.
Ask the Community
