• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    vince1327
    Hyperlinks in attribute values and tables
    148 Views, 8 Replies
    05-15-2012 01:10 PM
    Hey guys,
    I've been going through older posts with not too much luck. Using C# (VS2010, Acad2012) i've created a block, imported it, given it the required attibute tags and values, and then created an array out of this block for a total of "x" identical blocks for our purposes. As these blocks are desigend to represent real-world products, is there any way that one of my attribute values can reflect a hyperlink to the manufacturers datasheet?
    So essentially
    Product Info http://www.google.ca/testproduct.pdf
    Also, one of my functions lists all of the blocks in the current drawing and tallys them up and drops them into a table where it reports the block name, details, and quantity. I would also like this block name to be a hyperlink as well...is this doable?
    Cheers
    Vince
    *** Edted for spelling and code
    AttributeDefinition attDef15 = new AttributeDefinition(new Point3d(0d, 0d, 0d), productinfo, "Web Link", "", db.Textstyle);
                        attDef12.Invisible = true;
    Please use plain text.
    ADN Support Specialist
    Re: Hyperlinks in attribute values and tables
    05-15-2012 07:04 PM in reply to: vince1327
    You could add a hyperlink to each block reference. The same that you can achieve in the user interface using the HYPERLINK command. With that you can assign a URL to any entity (inc. a block reference) so that if the user hovers above the entity then information with the URL will come up, and if the user presses Ctrl+Click, then the browser comes up with the given URL.
    Actually, what you asked should also be possible, i.e. to set an attribute reference's value to a URL, by including a field type called hypertext, e.g. like
    %<\AcVar \href "http://www.autodesk.com##www.autodesk.com#0">%
    There, again, the user could just click on the attribute text and get to the given website.
    I hope this helps.
    Adam Nagy
    Autodesk Developer Network
    Adam Nagy
    Developer Technical Services
    vince1327
    05-16-2012 05:20 AM in reply to: adam.nagy
    Great thanks adam. I've been trying however no luck though, is my hyperlink a string value?
    for example:
    string url = "%<\AcVar \href "http://www.autodesk.com##www.autodesk.com#0">%"
    or is there another way to do this. The first set of quotes encompassing the link tends to throw things off.
    Cheers
    Vince
    Moderator
    Alexander.Rivilis
    05-16-2012 09:30 PM in reply to: vince1327
    for example:
    Cheers
    Vince
    Maybe like this:
    string url = "%<\\AcVar \\href \"http://www.autodesk.com##www.autodesk.com#0\">%";
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    vince1327
    05-17-2012 05:16 AM in reply to: Alexander.Rivilis
    Thanks Alexander. When i do this, the URL shows up in my properties window but is not clickable...is this normal?
    Cheers
    Vince
    Moderator
    Alexander.Rivilis
    05-17-2012 05:29 AM in reply to: vince1327
    What about Ctrl+Left Mouse Button click on attribute in drawing?
    vince1327
    05-17-2012 05:33 AM in reply to: Alexander.Rivilis
    That doesn't seem to be working...It seems as though the hyperlink isn't being treated any differently than any other attribute. I can click it, select it, etc....but it doens't behave as a hyperlink, just as a standard attribute.
    Valued Mentor
    05-17-2012 09:48 AM in reply to: vince1327
    Try the attached.  It needs to be inserted into some drawing.
    vince1327
    05-17-2012 09:57 AM in reply to: fieldguy
    Thanks fieldguy...so that does work...but i think i'm just explaining this badly...What i'm trying to do is get the attribute value that shows up in the property window to be clickable. I know how to create hyperlinks in the drawing itself, but is it possible to make an attribute value a hyperlink? So that way if i click a filter for instance, the model number, size, etc, all pop up as attributes in the properties window, and then i have a hyperlink there that links directly to the manufacturers datasheet
    Cheers
    Vince
