• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor spu
    How verify presence of a block in paper space
    222 Views, 1 Replies
    01-30-2012 09:47 PM
    How to verify a block is already inserted in a layout [paper space] using autocad .net. There will be only one instance per layout.
    Shijith
    Please use plain text.
    Valued Contributor
    SENL1362
    Re: How verify presence of a block in paper space
    01-31-2012 02:11 AM in reply to: spu
    Several solutions possible:
    1. general solution to be used for every BlockTable, i.e. Modelspace, paperspace etc
    // based on samples from http://drive-cad-with-code.blogspot.com/2011/04/tips-of-using-linq-in-autocad-net.html
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
                    BlockTableRecord btr = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    BlockTableRecord ptr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForRead);
                    var psIDs = ptr.Cast<ObjectId>().ToList();
                    ed.WriteMessage("\n{0} paperspace entities", psIDs.Count);
                    //All blocks Named=xxx
                   var blks = psIDs.Where(id => id.ObjectClass.DxfName.ToUpper() == "INSERT").Select(id => GetBlockRef(id, trans)).ToList<BlockReference>();
                   var myNamedblks = blks.Where(c => c.Name.ToUpper() == "MyXXX".ToUpper()).ToList<BlockReference>();
                    foreach (BlockReference myBlk in myNamedblks)
                        ed.WriteMessage("\n" + myBlk.Name + ", " + myBlk.Handle);
    2. Selection sample for active Layout
              TypedValue[] selectBlkName = new TypedValue[]
                                                    new TypedValue((int)DxfCode.Start, "INSERT"),
                                                    new TypedValue((int)DxfCode.Name, blkName),
                SelectionFilter selFilter = new SelectionFilter(selectBlkName );
                db.TileMode=false;  //activate paperspace
                PromptSelectionResult prSelRes = ed.SelectAll(selFilter);
                //return new ObjectIdCollection(prSelRes.Value.GetObjectIds());
                if (prSelRes.Status == PromptStatus.OK)
                        foreach (ObjectId selID in prSelRes.Value.GetObjectIds())
                            Entity theEnt = (Entity)trans.GetObject(selID, OpenMode.ForRead);
                            ed.WriteMessage("\n" + selID.ObjectClass.DxfName + ", " + theEnt.GetType().ToString() + ", " + theEnt.Handle.ToString() + ", " + theEnt.Layer.ToString());
    3. select from specific layout only
                   LayoutManager.Current.CurrentLayout = layoutname;
