.NET
*Tony Tanzillo
Message 11 of 16 (78 Views)
Re: How to wrapper the acutBuilList function?
06-03-2005 09:47 AM in reply to: tangferry
By the way, feel free to point out any mistakes
or massive blunders in that code, or embellish it
as you wish :-)
I'm very interested in finding a way to convert the
unmanaged selection set to a managed SelectionSet
(SelectionSetDelayMarshalled or SelectionSetFullyMarshalled,
depending I guess, on whether acedSSNameX information
is needed).
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Albert Szilvasy" wrote in message news:4864849@discussion.autodesk.com...
It is actually not completely useless. You just need to call acedSSGet
directly with the resbuf. I try to put together an example today or over the
weekend.
albert
"Tony Tanzillo" wrote in message
news:4864380@discussion.autodesk.com...
Sorry, I failed to consider that in order to use a
ResultBuffer for object selection filtering, you must
call the AsArray() member, and if you look at my
original workaround, you'll see the caveat that you
can't do that after hacking the ResultBuffer.
So, the workaround is essentially useless.
Let's see what else we can come up with ....
wrote in message news:4864330@discussion.autodesk.com...
I want to select circles and lines using selectionset.
The source code file is in the attachment.
But when i test it in AutoCAD,I get the following error message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by
the target of an invocation. --->
System.NullReferenceException: Object reference not set to an ins
tance of an object.
at Autodesk.AutoCAD.DatabaseServices.ResultBuffer..ctor(TypedValue[]
values)
at Autodesk.AutoCAD.EditorInput.FilterExtractor.__ctor(FilterExtractor* ,
SelectionFilter filter)
at Autodesk.AutoCAD.EditorInput.Editor.GetSelection(SelectionFilter
filter)
at ClassLibrary.DNOTClass.test()
--- End of inner exception stack trace ---
at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj,
BindingFlags invokeAttr, Binder binder, Object[]
parameters,
CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean
verifyAccess)
parameters, CultureInfo culture, Boolean verifyAccess)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags
parameters, CultureInfo culture)
at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* ,
gcroot<:REFL>
ection::MethodInfo __gc *>* mi)
at Autodesk.AutoCAD.Runtime.SEHExceptionFilter.InvokeWorker()
at Autodesk.AutoCAD.Runtime.ExceptionFilter.Invoke()
How to solve this problem?Thanks.
*Tony Tanzillo
Message 12 of 16 (78 Views)
06-03-2005 11:43 AM in reply to: tangferry
The file I posted was mangled by the news server.
Here it is again, with a .txt extension.
weekend.
albert
tance of an object.
values)
filter)
parameters,
verifyAccess)
gcroot<:REFL>
*Tony Tanzillo
Message 13 of 16 (78 Views)
06-03-2005 12:07 PM in reply to: tangferry
Nope - That didn't work either.
Let's try it with a different code page.
weekend.
albert
tance of an object.
values)
filter)
parameters,
verifyAccess)
gcroot<:REFL>
Active Contributor
tangferry
Message 14 of 16 (78 Views)
06-04-2005 12:13 AM in reply to: tangferry
Thanks everyone!
Perhaps my C++ is poor,I have used com to solve this problem,and it does work.
*Albert Szilvasy
Message 15 of 16 (78 Views)
06-06-2005 10:55 AM in reply to: tangferry
Why don't you load it and save it once in Notepad. I think that will work.
albert
news:4865216@discussion.autodesk.com...
weekend.
albert
"Tony Tanzillo"
illo@U_KNOW_WHERE.com> wrote in message
AD 2004/2005/2006
hrown by
tance of an object.
values)
filter)
at Sys
parameters,
verifyAccess)
gcroot<:REFL>
*Tony Tanzillo
Message 16 of 16 (78 Views)
06-06-2005 12:35 PM in reply to: tangferry
Hi Albert.
I tried that too, but it didn't seem to matter.
"Albert Szilvasy" wrote in message news:4866567@discussion.autodesk.com...
albert
weekend.
albert
"Tony Tanzillo"
AD 2004/2005/2006
hrown by
tance of an object.
values)
filter)
at Sys
parameters,
verifyAccess)
gcroot<:REFL>
You are not logged in.
Announcements
Need installation help?
Ask the Community
