How to use function "SetUcs"
Message 1 of 8
Dim orthoView As New OrthographicView
Dim viewp As New Viewport
orthoView = OrthographicView.FrontView
viewp.SetUcs(orthoView) '''''''why not working???
viewp.UpdateDisplay()
btr.AppendEntity(viewp)
tm.AddNewlyCreatedDBObject(viewp, True)
Replies (7)
Message 2 of 8
Try setting the ucs after you added viewport to the drawing.
If that doesn't work please try to post some code that I can cut and paste
and compile (no dependencies on other stuff).
Albert
wrote in message news:4862874@discussion.autodesk.com...
Message 3 of 8
Hi Albert:
Following is the complete codes that you can compile.Please help me to find the reason why the function "SetUCS" don't work!
Private Sub btnDraw_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnDraw.Click
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tm As DBTransMan = db.TransactionManager
Dim ta As Transaction = tm.StartTransaction
Try
Dim r, w, v, h As Double
Dim x0, y0, z0, x1, y1, z1 As Double
Dim tt, n As Integer
Dim cenX0, cenY0, cenZ0 As Double
Dim p0, p1 As Point3d
Dim p1Collection As New Point3dCollection
Dim sPline As Polyline3d
Const pi = 3.1415926
n = CInt(txtN.Text)
cenX0 = CDbl(txtX.Text)
cenY0 = CDbl(txtY.Text)
cenZ0 = CDbl(txtZ.Text)
tt = 0
r = CDbl(txtRadius.Text)
h = CDbl(txtDaoCheng.Text)
Dim bt As BlockTable = tm.GetObject(db.BlockTableId, OpenMode.ForRead, False)
Dim btr As BlockTableRecord = tm.GetObject(bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False)
w = 2 * pi / 180
v = h / 180
x0 = cenX0 + r * Cos(w * tt)
y0 = cenY0 + r * Sin(w * tt)
z0 = cenZ0 + v * tt
p0 = New Point3d(x0, y0, z0)
p1 = New Point3d(x0, y0, z0)
p1Collection.Add(p1)
tt = tt + 1
Do While (tt <= (n * 180))
z0 = cenZ0 + v * tt
tt = tt + 1
Loop
sPline = New Polyline3d(Poly3dType.SimplePoly, p1Collection, False)
btr.AppendEntity(sPline)
tm.AddNewlyCreatedDBObject(sPline, True)
'''''''''Draw Screw Solid '''''''''''''''''''''''''''''''''
Dim dboCol As New DBObjectCollection
Dim cir As New Circle
Dim solid3dScrew As New Solid3d
Dim regionCir As Region
Dim regions As DBObjectCollection
''''''''''''''''''''''''''''''UCS should be changed to FrontView from TopView,But the SetUCS can not goog work!!!!!!!!!!
cir.Center = p0
cir.Radius = 10
dboCol.Clear()
dboCol.Add(cir)
btr.AppendEntity(cir)
tm.AddNewlyCreatedDBObject(cir, True)
regions = regionCir.CreateFromCurves(dboCol)
regionCir = regions(0)
'solid3dScrew.ExtrudeAlongPath(regionCir, sPline, 0)
btr.AppendEntity(solid3dScrew)
tm.AddNewlyCreatedDBObject(solid3dScrew, True)
regions.Dispose()
ta.Commit()
Catch
MsgBox( Err.Description, MsgBoxStyle.Critical, "Error")
Finally
ta.Dispose()
End Try
End Sub
Message 4 of 8
Ok. What are you trying to do? Let me rephrase in english what you are
doing:
1. You create a new viewport
2. You set the UCS in the viewport.
Note that you never add the viewport to the drawing and you never set any of
the view properties so it is unclear what this viewport is supposed to view.
I suspect that you want to set the ucs in the current viewport. Is that it?
Albert
wrote in message news:4864232@discussion.autodesk.com...
Hi Albert:
Try
n = CInt(txtN.Text)
tt = 0
w = 2 * pi / 180
v = h / 180
z0 = cenZ0 + v * tt
tt = tt + 1
z0 = cenZ0 + v * tt
tt = tt + 1
Loop
False)
cir.Center = p0
cir.Radius = 10
dboCol.Clear()
dboCol.Add(cir)
regions.Dispose()
ta.Commit()
Catch
Finally
ta.Dispose()
End Try
End Sub
Message 5 of 8
Hi Albert:
I want to set the ucs in the current viewport from TopView to FrontView becase I want to draw a circle in the FronView not TopView. And then I will extrude the circle entity along a 3DPolyLine path . But How to do it?
Message 6 of 8
You don't need to set the ucs to do this. You simply set the normal of the
Circle to say -1,0,0.
ALbert
wrote in message news:4864333@discussion.autodesk.com...
Hi Albert:
Message 7 of 8
Hi Albert:
Can you give me some sample codes about how to do it?
Regards.
John Jiang
Message 8 of 8
Here you go:
public class CircleCreator
[CommandMethod("cc")]
public void DoIt()
Database db =
Application.DocumentManager.MdiActiveDocument.Database;
using (Transaction t = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)t.GetObject(db.BlockTableId,
OpenMode.ForRead);
BlockTableRecord btr =
(BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace],
OpenMode.ForWrite);
//create circle with some arbitrary normal
using (Circle c = new Circle(new Point3d(0,0, 0),new
Vector3d(1,1,1),1))
btr.AppendEntity(c);
t.AddNewlyCreatedDBObject(c, true);
t.Commit();
wrote in message news:4866005@discussion.autodesk.com...
Hi Albert:
Regards.
John Jiang
