How to use correctly the PlotSettingsValidator
08:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a view on paper pace : Name "1200-900" size : 1200 x 900 unit (Unit : mm)
my little prg vb.bet :
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Using (tr)
'Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead)
Dim lo As Layout = tr.GetObject(btr.LayoutId, OpenMode.ForRead)
Dim pi As PlotInfo = New PlotInfo()
pi.Layout = btr.LayoutId
'// We need a PlotSettings object
'// based on the layout settings
'// witch we then customize
Dim ps As PlotSettings = New PlotSettings(lo.ModelType)
ps.CopyFrom(lo)
'// The PlotSettingsValidator helps
'// create a valid PlotSettings object
Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current
'retrieve the name of vue
Dim NomView As String = ChoixVue()
If NomView <> "" Then
psv.SetPlotViewName(ps, NomView) '"1200-900")
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.View)
'HERE MY PROB !!
psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters)
'psv.SetUseStandardScale(ps, True)
'psv.SetStdScaleType(ps, StdScaleType.StdScale1To50)
'Dim Scale As CustomScale = New CustomScale(1, 30)
'psv.SetStdScale(ps, 0.0)
'psv.SetCustomPrintScale(ps, Scale)
'psv.SetPlotCentered(ps, True)
'psv.RefreshLists(ps)
'***** Format paper
psv.SetPlotConfigurationName(ps, "DWG To PDF(Ce).pc3", "UserDefinedMetric (900.00 x 1500.00mm)")
'// We need to link the PlotInfo to the
'// PlotSettings and then validate it
pi.OverrideSettings = ps
Dim piv As PlotInfoValidator = New PlotInfoValidator()
piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled
piv.Validate(pi)
If PlotFactory.ProcessPlotState = ProcessPlotState.NotPlotting Then
.......I cant understand the :
- psv.SetStdScaleType(ps, StdScaleType.xxxx)
--> If i use 1to1 i dont see my drawing
--> if i use 1to 20 i see my draw
but i want create a draw with exacty the size of my view. (The size is already finewith the paper of my DesignJet T610)
So how i can just retrieve the good page layout. (CTRL+P and enter work fine)
How is calculate the StdScaleType.StdScale1To50 or StdScaleType.StdScale1To1 ?
