.NET
How to use Export API for autocad document object?
2 REPLIES 2
yuh0317
2839 Views, 2 Replies
 void Export([In, MarshalAs(UnmanagedType.BStr)] string FileName, [In, MarshalAs(UnmanagedType.BStr)] string Extension, [In, MarshalAs(UnmanagedType.Interface)] AcadSelectionSet SelectionSet);
Who can tell me how to use Export API?
Autodesk.AutoCAD.Interop.AcadApplicationClass acadApp = null;
try
acadApp = new Autodesk.AutoCAD.Interop.AcadApplicationClass();
if (acadApp != null)
string dwgFileName = @"C:\Test.dwg";
Autodesk.AutoCAD.Interop.AcadDocument document = acadApp.Documents.Open(dwgFileName);
document.Export(...);
document.Close(false);
catch (Exception ex)
Console.Write(ex.ToString());
finally
acadApp.Quit();
2 REPLIES 2
Balaji_Ram
in reply to: yuh0317
Here is a sample code directly migrated from the ActiveX documentation (acadauto.chm).
[CommandMethod("MyExport")]
public void ExportMethod()
	Document doc = Application.DocumentManager.MdiActiveDocument;
	Editor ed = doc.Editor;
	AcadDocument acadDoc = doc.AcadDocument as AcadDocument;
	// This example exports the current drawing to DXF format.
	// Note that a valid selection set must be provided, even
	// though the contents of the selection set are ignored.
	// Define the name for the exported file
	string exportFile = null;
	exportFile = "C:\\Temp\\DXFExprt.dxf";
	// Adjust path to match your system
	// Create an empty selection set
	AcadSelectionSet sset = default(AcadSelectionSet);
	sset = acadDoc.SelectionSets.Add("TEST");
	// Export the current drawing to the file specified above.
	acadDoc.Export(exportFile, "DXF", sset);
 Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
Juergen_Becker
in reply to: Balaji_Ram
I must export into a object, which are on specific layer.
I changed your code as followed:
Int16[] hFilterType = new Int16[1];
object[] hFilterData = new object[1];
hFilterType[0] = 8;
hFilterData[0] = "Kontur";
AcadDocument acadDoc = doc.GetAcadDocument() as AcadDocument;
exportFile = "C:\\Temp\\DXFExport";
sset.Clear();
sset.Select(Autodesk.AutoCAD.Interop.Common.AcSelect.acSelectionSetAll, Type.Missing, Type.Missing, hFilterType, hFilterData);
sset.Highlight(true);
 The selectionset is ok, because the objects are highlighted, but the DXF-File is wrong. The DXF file contains all object objects of the drawing not only the ones on the layer "Kontur".
What is wrong with my code?
Best Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
”Boost
