• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    How to set multiple file extension of the OpenFileDialg?
    385 Views, 4 Replies
    03-09-2007 08:52 PM
    I can set the single file extension for Autodesk.AutoCAD.Windows.OpenFileDialg like this:
    Autodesk.AutoCAD.Windows.OpenFileDialg dlg = new Autodesk.AutoCAD.Windows.OpenFileDialog("select files", null, "dwg", null, Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowMultiple);
    But how to set set multiple file extension?
    I have tried "dwg|dxf",but it does not work.
    Please use plain text.
    Active Contributor
    Re: How to set multiple file extension of the OpenFileDialg?
    03-09-2007 11:13 PM in reply to: csharpbird
    Give it a try......
    OpenFileDialog Ofn = new OpenFileDialog();
    Ofn.Filter = "C Sharp Files (*.cs)|*.cs|Text Files (*.txt)|*.txt";
    Ofn.Title = "Type File";
    Ofn.Multiselect = true;
    Ofn.ShowDialog();
    Best Regards,
    Basha
    *Kerry Brown
    03-10-2007 12:28 AM in reply to: csharpbird
    For Multiple file extension options as you indicate, you could use :-
    // using SWF = System.Windows.Forms;
    SWF.OpenFileDialog dlg = new SWF.OpenFileDialog();
    dlg.Filter = "Drawing Based Files (*.dwg, *.dxf)|*.dwg;*.dxf";
    dlg.Multiselect = true;
    //kwb
    wrote in message news:5514377@discussion.autodesk.com...
    03-10-2007 04:56 PM in reply to: csharpbird
    If you're using OpenFileDialog from Autocad, separate the extensions with semicolons eg. "dwg;dwt"
    hoangvuminh
    05-23-2011 08:12 AM in reply to: GlennR
    For example
    Dim dlg As Autodesk.AutoCAD.Windows.OpenFileDialog = New Autodesk.AutoCAD.Windows.OpenFileDialog("Open Dat Files", "", "dat", "", 0)
    Works like a Champ
