.NET
Active Contributor
pva75
Message 1 of 4 (362 Views)
How to set Polyline.StartPoint ?
362 Views, 3 Replies
08-12-2012 01:48 PM
I tried to set Polyline.StartPoint to new position (Point3d):
Polyline.StartPoint = myNewPoint3d;
I have "not implemented" exception.
Also, I tried to do it as:
var seg0 = acEnt.GetLineSegmentAt(0);
seg0.Set(newPoint3d(0, 0, 0), seg0.EndPoint);
It doesn't work also.
I can do it as:
acEnt.SetPointAt(0, my2dPoint);
But it's 2D point, not 3d
Of course I can remove polyline and create it again, but...
How to set start point correctly for 3d point?
Pavel
Hallex
Message 2 of 4 (360 Views)
Re: How to set Polyline.StartPoint ?
08-12-2012 02:16 PM in reply to: pva75
Here is a quick and dirty snip you will be use as framework,
change to your suit
   [CommandMethod("SPT")]
        public void chageStartPoint()
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect a segment where to add a vertex: ");
            peo.SetRejectMessage("\nIncorrect entity");
            peo.AllowNone = false;
            peo.AllowObjectOnLockedLayer = false;
            peo.AddAllowedClass(typeof(Polyline), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status == PromptStatus.OK)
                ObjectId id = per.ObjectId;
                try
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        Polyline pline = tr.GetObject(id, OpenMode.ForRead, false) as Polyline;
                        if (pline != null)
                            pline.UpgradeOpen();
                            Point3d pt = ed.GetPoint("\nPick new start point location: ").Value;
                            Point2d sp = pt.Convert2d(new Plane(Point3d.Origin, pline.Normal));
                            pline.AddVertexAt(0, sp, 0, pline.ConstantWidth, pline.ConstantWidth);
                            pline.RemoveVertexAt(1);
                        tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage( ex.Message);
~'J'~
Active Contributor
pva75
Message 3 of 4 (338 Views)
08-12-2012 09:42 PM in reply to: Hallex
Thanks a lot! I think it will work for me.
Pavel.
Hallex
Message 4 of 4 (329 Views)
08-13-2012 12:55 AM in reply to: pva75
You need to extend this code
Add in there the part to work with different
coordinate system etc
You're welcome
~'J'~
You are not logged in.
Ask the Community
