How to select all entites of a layer?
I want to migrate my VB code to VB.NET code, can anyone help me to migrate the below code?
Private Function GetEntities(oLayerCollection As Collection, sSelectionSetName As String, _ Optional pointsList As Variant = Empty, _ Optional mode As AcSelect = acSelectionSetCrossingPolygon) As AcadSelectionSet Dim oSS As AcadSelectionSet Dim Point1(0 To 2) As Double, point2(0 To 2) As Double Dim gpCode(0 To 0) As Integer Dim dataValue(0 To 0) As Variant Dim groupCode As Variant, dataCode As Variant Dim vLayer As Variant Dim oCurrentDocument As AcadDocument ' dummy points Point1(0) = 0: Point1(1) = 0: Point1(2) = 0 point2(0) = 0: point2(1) = 0: point2(2) = 0 Set oCurrentDocument = m_oApplication.ActiveDocument On Error Resume Next Set oSS = oCurrentDocument.SelectionSets.Add(sSelectionSetName) On Error GoTo 0 Set oSS = oCurrentDocument.SelectionSets(sSelectionSetName) Call oSS.Clear gpCode(0) = 8 For Each vLayer In oLayerCollection If dataValue(0) = "" Then dataValue(0) = vLayer Else dataValue(0) = dataValue(0) & "," & vLayer End If Next vLayer groupCode = gpCode dataCode = dataValue If VarType(pointsList) = vbEmpty Then Call oSS.Select(acSelectionSetAll, Point1, point2, groupCode, dataCode) Else Call oSS.SelectByPolygon(mode, pointsList, groupCode, dataCode) End If Set GetEntities = oSS End Function
Layer collection will contains the various layer name
You can use a SelectionFilter:
Here is extended version of this example:
<CommandMethod("CSW")> _ Public Sub TestSelectWindow() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor '' dummy object types for test: Dim objects() As String = New String() {"INSERT", "LINE", "LWPOLYLINE", "CIRCLE"} '' dummy layers for test: Dim layers() As String = New String() {"DIM", "DWGRU", "ANNO-TLB", "Defpoints"} Dim layerfilt As String = String.Join(",", layers) Dim objfilt As String = String.Join(",", objects) '' Create a TypedValue array to define the filter by object types (dxf code 0) and layers (dxf code 8) Dim tvs() As TypedValue = New TypedValue() {New TypedValue(0, objfilt), New TypedValue(8, layerfilt)} '' Assign the filter criteria to a SelectionFilter object Dim filter As SelectionFilter = New SelectionFilter(tvs) Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "Specify lower legt corner of window: ") Dim pres As PromptPointResult = ed.GetPoint(ppo) If pres.Status <> PromptStatus.OK Then Return Dim p1 As Point3d = pres.Value Dim pco As PromptCornerOptions = New PromptCornerOptions(vbLf & "Opposite corner point: ", p1) pres = ed.GetCorner(pco) If pres.Status <> PromptStatus.OK Then Return Dim p2 As Point3d = pres.Value '' Request for objects to be selected in the drawing area Dim res As PromptSelectionResult res = ed.SelectCrossingWindow(p1, p2, filter) '' If the prompt status is OK, objects were selected 'If res.Status = PromptStatus.OK Then Dim sset As SelectionSet = res.Value If sset.Count > 0 Then Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Number of objects selected: " & sset.Count.ToString) Else Return End If Using tr As Transaction = db.TransactionManager.StartTransaction() Try For Each sobj As SelectedObject In sset Dim ent As Entity = DirectCast(tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False), Entity) Dim blk As BlockReference = TryCast(ent, BlockReference) If blk IsNot Nothing Then ed.WriteMessage(vbLf & "Block Name: {0}", blk.Name) End If Dim circ As Circle = TryCast(ent, Circle) If circ IsNot Nothing Then ed.WriteMessage(vbLf & "Radius: {0}", circ.Radius.ToString()) End If Dim pline As Polyline = TryCast(ent, Polyline) If pline IsNot Nothing Then ed.WriteMessage(vbLf & "Number Of Vertices: {0}", pline.NumberOfVertices.ToString()) End If Dim ln As Line = TryCast(ent, Line) If ln IsNot Nothing Then ed.WriteMessage(vbLf & "Start Point: {0}", ln.StartPoint.ToString()) End If Next tr.Commit() Catch ex As System.Exception ed.WriteMessage(ex.StackTrace & vbLf & ex.StackTrace) End Try End Using End Sub
~'J'~
