.NET
AakashChopra
Message 1 of 3 (848 Views)
How to select all entities of a layer?
848 Views, 2 Replies
10-08-2012 09:27 AM
How to select all entites of a layer?
I want to migrate my VB code to VB.NET code, can anyone help me to migrate the below code?
Private Function GetEntities(oLayerCollection As Collection, sSelectionSetName As String, _
                    Optional pointsList As Variant = Empty, _
                    Optional mode As AcSelect = acSelectionSetCrossingPolygon) As AcadSelectionSet
    Dim oSS As AcadSelectionSet
    Dim Point1(0 To 2) As Double, point2(0 To 2) As Double
    Dim gpCode(0 To 0) As Integer
    Dim dataValue(0 To 0) As Variant
    Dim groupCode As Variant, dataCode As Variant
    Dim vLayer As Variant
    Dim oCurrentDocument As AcadDocument
    ' dummy points
    Point1(0) = 0: Point1(1) = 0: Point1(2) = 0
    point2(0) = 0: point2(1) = 0: point2(2) = 0
    Set oCurrentDocument = m_oApplication.ActiveDocument
    On Error Resume Next
    Set oSS = oCurrentDocument.SelectionSets.Add(sSelectionSetName)
    On Error GoTo 0
    Set oSS = oCurrentDocument.SelectionSets(sSelectionSetName)
    Call oSS.Clear
    gpCode(0) = 8
    For Each vLayer In oLayerCollection
        If dataValue(0) = "" Then
            dataValue(0) = vLayer
        Else
            dataValue(0) = dataValue(0) & "," & vLayer
        End If
    Next vLayer
    groupCode = gpCode
    dataCode = dataValue
    If VarType(pointsList) = vbEmpty Then
         Call oSS.Select(acSelectionSetAll, Point1, point2, groupCode, dataCode)
    Else
        Call oSS.SelectByPolygon(mode, pointsList, groupCode, dataCode)
    End If
    Set GetEntities = oSS
End Function
 Layer collection will contains the various layer name
_gile
Message 2 of 3 (825 Views)
Re : How to select all entities of a layer?
10-08-2012 11:38 AM in reply to: AakashChopra
Hallex
Message 3 of 3 (769 Views)
Re: How to select all entities of a layer?
10-14-2012 12:16 PM in reply to: AakashChopra
Here is extended version of this example:
    <CommandMethod("CSW")> _
        Public Sub TestSelectWindow()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            '' dummy object types for test:
            Dim objects() As String = New String() {"INSERT", "LINE", "LWPOLYLINE", "CIRCLE"}
            '' dummy layers for test:
            Dim layers() As String = New String() {"DIM", "DWGRU", "ANNO-TLB", "Defpoints"}
            Dim layerfilt As String = String.Join(",", layers)
            Dim objfilt As String = String.Join(",", objects)
            '' Create a TypedValue array to define the filter by object types (dxf code 0) and layers (dxf code 8)
            Dim tvs() As TypedValue = New TypedValue() {New TypedValue(0, objfilt), New TypedValue(8, layerfilt)}
            '' Assign the filter criteria to a SelectionFilter object
            Dim filter As SelectionFilter = New SelectionFilter(tvs)
            Dim ppo As PromptPointOptions = New PromptPointOptions(vbLf & "Specify lower legt corner of window: ")
            Dim pres As PromptPointResult = ed.GetPoint(ppo)
            If pres.Status <> PromptStatus.OK Then Return
            Dim p1 As Point3d = pres.Value
            Dim pco As PromptCornerOptions = New PromptCornerOptions(vbLf & "Opposite corner point: ", p1)
            pres = ed.GetCorner(pco)
            Dim p2 As Point3d = pres.Value
            '' Request for objects to be selected in the drawing area
            Dim res As PromptSelectionResult
            res = ed.SelectCrossingWindow(p1, p2, filter)
            '' If the prompt status is OK, objects were selected
            'If res.Status = PromptStatus.OK Then
            Dim sset As SelectionSet = res.Value
            If sset.Count > 0 Then
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Number of objects selected: " & sset.Count.ToString)
            Else
                Return
            End If
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    For Each sobj As SelectedObject In sset
                        Dim ent As Entity = DirectCast(tr.GetObject(sobj.ObjectId, OpenMode.ForRead, False), Entity)
                        Dim blk As BlockReference = TryCast(ent, BlockReference)
                        If blk IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Block Name: {0}", blk.Name)
                        End If
                        Dim circ As Circle = TryCast(ent, Circle)
                        If circ IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Radius: {0}", circ.Radius.ToString())
                        End If
                        Dim pline As Polyline = TryCast(ent, Polyline)
                        If pline IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Number Of Vertices: {0}", pline.NumberOfVertices.ToString())
                        End If
                        Dim ln As Line = TryCast(ent, Line)
                        If ln IsNot Nothing Then
                            ed.WriteMessage(vbLf & "Start Point: {0}", ln.StartPoint.ToString())
                        End If
                    Next
                    tr.Commit()
                Catch ex As System.Exception
                    ed.WriteMessage(ex.StackTrace & vbLf & ex.StackTrace)
                End Try
            End Using
        End Sub
~'J'~
You are not logged in.
Ask the Community
