.NET
ADN Support Specialist
Balaji_Ram
Message 11 of 14 (207 Views)
Re: How to select a drawing object which is in AutoCAD File from a .Net Applicat
07-25-2012 05:55 AM in reply to: CodeBug
The issue sound similar to what is discussed in this post :
http://adndevblog.typepad.com/autocad/2012/05/how-to-pass-com-optional-parameter-in-c.html
Balaji
Developer Technical Services
Autodesk Developer Network
*Expert Elite*
norman.yuan
Message 12 of 14 (203 Views)
07-25-2012 07:01 AM in reply to: CodeBug
I believe the error you got is compiling error, not runtime error. That is, your code does not compile.
1. The first compiling error:
Not like VB, in C#, you need to pass parameteres for the optional argument:
SelectOnScreen(Type.Missing, Type.Missing);
2. The second compiling error: that is because C# is strong type language, ab "object" natually does not have property that from an specific class instance. YOu need to cast the "object" into a correct specific type before to access the property. In your case, you need:
foreach (object item in sset)
    AcadEntity ent=item as AcadEntity;
    if (ent!=null)
        MessageBox.Show(string.Format("Entity Handle={0}", ent.Handle));
It looks like more .NET programming (not AutoCAD specific) learning is due.
CodeBug
Message 13 of 14 (191 Views)
07-27-2012 05:51 AM in reply to: Balaji_Ram
Hi Balaji_Ram,
Yes I had already found this solution and this line of the code is working.
Thanks for your pointer !
Message 14 of 14 (83 Views)
12-16-2013 06:32 AM in reply to: VB_Autocad_guy
coud you show me event DatabaseObjectSelected.please!!!
ko0ls
You are not logged in.
Announcements
Need installation help?
Ask the Community
