.NET
How to save a file in DXF?
6 REPLIES 6
686 Views, 6 Replies
Please help!
6 REPLIES 6
Alfred.NESWADBA
is that what you are missing?
   <Runtime.CommandMethod("ADESK_saveAsDxf")> _
   Public Shared Sub ADESK_saveAsDxf()
      Dim tFileName As String = "C:\TEMP\myDxfFileName.DXF"
      Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.DxfOut(tFileName, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current)
   End Sub
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
I used this code:
        [CommandMethod("DrawingSaved")]
        public static void DrawingSaved()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.DxfOut(acDoc.Name, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current);
 But it's giving error:  Exception was unhandles by user code
eFileAccessErr
Alfred.NESWADBA
if you take acDoc.Name as name for your DXF-file you will recognize, that it will have included the extension ".DWG", but if you want to save it as DXF you should have DXF as extension 😉
      Dim tAcadDoc As ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
      Dim tFileName As String = tAcadDoc.Name
      If tFileName.ToUpper.EndsWith(".DWG") Then tFileName = Left(tAcadDoc.Name, tAcadDoc.Name.Length - 4) & ".DXF"
      tAcadDoc.Database.DxfOut(tFileName, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current)
   End Sub
 HTH, - alfred -
Alfred NESWADBA
My file was already in the extension. Dxf
🙂 Since yesterday I'm puzzling over it but nothing works 😞
It worked using the command line.
 acadDocument.SetVariable("FILEDIA", 0);
 acadDocument.SendCommand("SAVE " + FileTxt.FullName + "\nv\n2007\n16\nyes\n");
 acadDocument.SetVariable("FILEDIA", 1);
I was creating a dll just to save, so it is better not to have to create a dll.
Thank you!
Alfred.NESWADBA
Ok, the more info, the better we can "debug" 😉
Well the DXFOUT-function exports the current drawing, but it is not to compare with SAVEAS, it's more like WBLOCK. And for WBLOCK you know, that if you are working on a drawing AA.DWG you cannot start WBLOCK and export some elements to AA.DWG ==> you have to take another filename.
And same situation is to use for DXFOUT, you cannot use the same name as you already have opened.
- alfred -
Alfred NESWADBA
That must be what was wrong then.
Good to know, I'll try!
 Smiley Happy
”Boost
