Hi another question on eTransmit.
when i do :
doc.SendStringToExecute("-etransmit" & vbCr & _
"CH" & vbCr & _
"archivage" & vbCr & _
"C" & vbCr & _
"" & Txt & vbCr , True, False, True)
i say to etransmit : use the configuration "archivage"
so the question : how i can check if the configuration already exist in etransmit ?
if i dont check it, my string is not good and i dont have the error for this. (asynchrone command).
thank
I can see that you have another post, where you say that don't want to use the Etransmit API
Using the sendstring, you're limited to send command. Send -etransmit and select CH to select the configuration, then you can read the command line and see whats there, then decide.
Anyway, this is not very safe, I would say that the API is safer.
I dnt want use interop.
I have to many pc with different system (seven 32b / 64b, xp) i have already use the command tlbimp.exe but for automatise this i need to have the exe for each system.
>> [...] i need to have the exe
If you control AutoCAD from an EXE, how do you do that without COM? The managed part is only available within DLL's loaded via _NETLOAD (or automatic loading techniques).
- alfred -
and to be independent from specific versions of Interop or 32/64bit you can look to that samples from Hallex (others have sent a lot too, but he's the one I found most about that) for using Reflection to control via COM without referencing the Interop.DLL's
HTH, - alfred -
here my code for checking the DLL (example for PdfCreator.)
'************************************************************************************* '*** Fonction de Vérification des fichiers InterOp (ex : PDFCreator) ***************** '************************************************************************************* '== Entrée : '== NomProg : Le nom du programme qui utilisera l'InterOp '== NomApp : Le nom + path de l'application à charger '== NomDll : Le nom du fichier (avec le .DLL) (qui doit exister à coté du prog) ' '== FichierDeBase32 : Le fichier qui doit générer la DLL. (Exe ou autre) '== FichierDeBase64 : Le fichier qui doit générer la DLL. (Exe ou autre) '== '== '== Sortie '== NomFichier : Le chemin complet + le nom.dll du programme compilé sinon retourne "" '== '== '************************************************************************************* Public Function VerifieInterOp(ByVal NomProg As String, _ ByVal NomApp As String, _ ByVal NomDll As String, _ ByVal FichierDeBase32 As String, _ ByVal FichierDeBase64 As String) As Boolean Dim OkRetour As Boolean = False Dim NomFichierInterOp As String = NomApp.Remove(NomApp.LastIndexOf(NomProg)) & NomDll If Not (IO.File.Exists(NomFichierInterOp)) Then Dim NomFichierTLPImp As String Dim NomFichierBaseDLL As String If IntPtr.Size > 4 Then '64 bits NomFichierTLPImp = "C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Bin\tlbimp.exe" NomFichierBaseDLL = FichierDeBase64 Else '32bits NomFichierTLPImp = "C:\Program Files\Microsoft SDKs\Windows\v7.0A\Bin\tlbimp.exe" NomFichierBaseDLL = FichierDeBase32 End If Dim RetourProcess As System.Diagnostics.Process Try MsgBox("Le programme va essayer de créer le lien avec le programme : " & vbCrLf & _ NomFichierBaseDLL & vbCrLf & _ "Une fenêtre va s'ouvrir et le programme va attendre sa fermeture.", _ vbOKOnly & vbCritical, "Information") Dim ParamTxt = """" & NomFichierBaseDLL & """" & " /out:" & """" & NomFichierInterOp & """" RetourProcess = Process.Start(NomFichierTLPImp, ParamTxt) Do While RetourProcess.HasExited = False GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "En attente du programme de lien...") Loop GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "Fin du programme de lien, analyse du résultat.") If RetourProcess.ExitCode = 0 Then 'vérification si le fichier existe If IO.File.Exists(NomFichierInterOp) = False Then MsgBox("Le fichier " & NomFichierInterOp & " n'a pas été créé" & vbCrLf & _ "Contacter le responsable pour vérifier ce problème.", _ vbOKOnly & vbCritical, "Erreur de Programmation") GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "Programme : " & NomFichierTLPImp) GestionAUTOCAD.EcrireSurLigneDeCommande(vbCrLf & "Paramêtre : " & ParamTxt) Return False Else Return True End If End If Return False Catch ex As Exception MsgBox("Le programme de lien InterOP " & NomFichierTLPImp & "est introuvable." & vbCrLf & _ "Veuillez installer le SDK (Microsoft SDK)" & vbCrLf & _ "Contacter le responsable pour vérifier le bon répertoire." & vbCrLf & vbCrLf & _ "", vbOKOnly & vbCritical, "Erreur de Programmation") Return False End Try Else Return True End If End Function
and use this code : example :
If VerifieInterOp("GestionFolio", Str, _ "PdfCreator.dll", "C:\Program Files\PDFCreator\PDFCreator.exe", _ "C:\Program Files (x86)\PDFCreator\PDFCreator.exe") = True Then Assembly.LoadFrom(Str) '--> Ajouter un espace à la fin de la commande Application.DocumentManager.MdiActiveDocument.SendStringToExecute(strCmd, True, False, True) Else MsgBox("Pour lancer le programme GestionFolio, il faut absolument" & vbCrLf & _ "installer PdfCreator dans le répertoire : " & vbCrLf & _ "C:\Program Files\PdfCreator\ (sous XP 32Bits / Seven 32Bits)" & vbCrLf & _ "C:\Program Files (x86)\PdfCreator\ (sous XP 64Bits / Seven 64Bits)", _ MsgBoxStyle.Information, "Erreur d'installation") End If
but i need to know the exact path for the tlbimp.exe but if i have the SDK installed.
i cant have a file from earch system.
And for all your sample. i am not very good in using interop and com and reflexion.
I make very simple code for my society.
And now i need to translate all my stuff from acad 2010 32b to acad2014 64b. for this i have to install VS2012 i think.
