.NET
*Vassil
Message 1 of 8 (316 Views)
How to respond to a click on Autodesk.AutoCAD.Windows.Pane ?
316 Views, 7 Replies
10-11-2007 06:48 AM
Hello !
I'm new to vb.net (moving from VBA) so please excuse me if this sounds
stupid... I'm adding a pane to the status bar an I want to show a popup menu
(or execute a command) after clicking on the pane. This is my code :
Dim DetPane As New Autodesk.AutoCAD.Windows.Pane
DetPane.Text = "DE : "
DetPane.MinimumWidth = 30
DetPane.ToolTipText = "Current Detail : "
DetPane.Enabled = True
DetPane.Visible = True
DetPane.Style = Autodesk.AutoCAD.Windows.PaneStyles.PopUp
Application.StatusBar.Panes.Add(DetPane)
Please, let me know how to create the callback function. Thanks in advance !
Valued Mentor
cadMeUp
Message 2 of 8 (317 Views)
Re: How to respond to a click on Autodesk.AutoCAD.Windows.Pane ?
10-11-2007 01:07 PM in reply to: *Vassil
I am not sure how to hook events in VB, I use mostly use C# for customizing AutoCAD 2008. Looking in the VS object browser a 'Pane' object is derived from 'StatusBarItem' which has a 'MouseDown' event that you can hook into.
The event handler would have this similar signature:
Autodesk.AutoCAD.Windows.StatusBarMouseDownEventHandler.StatusBarMouseDownEventHandler(void (object, Autodesk.AutoCAD.Windows.StatusBarMouseDownEventArgs))
I have very limited experience with VB NET so I can't show you how you would wire it up.
*Vassil
Message 3 of 8 (315 Views)
WOW ! I'm happy !
10-12-2007 02:23 AM in reply to: *Vassil
Thanks alot !
This is the code and it is working :smileyhappy: :
AddHandler DetPane.MouseDown, AddressOf OnPaneMouseDown
Sub OnPaneMouseDown(ByVal o As Object, ByVal e As
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine
+ "Do something man !" + vbNewLine)
End Sub
Valued Mentor
cadMeUp
Message 4 of 8 (316 Views)
Re: WOW ! I'm happy !
10-12-2007 06:37 AM in reply to: *Vassil
That's great to hear! I am going to keep your sample for my possible future use! It gives me a good example of how to hook an event in VB.
stevenh0616
Message 5 of 8 (195 Views)
12-20-2012 08:12 AM in reply to: *Vassil
Anyone figure out how to make this work in 2013? Pane.MouseDown does not seem to exist? Please help!!
Steve
Windows 7 Enterprise 64-bit SP1
Intel Core i7 CPU X920 @ 1.73 GHz
16.00 GB RAM
Civil 3D 2013 - 2015
Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store
Moderator
Alexander.Rivilis
Message 6 of 8 (190 Views)
12-20-2012 08:33 AM in reply to: stevenh0616
Are you sure?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
stevenh0616
Message 7 of 8 (182 Views)
12-20-2012 09:49 AM in reply to: Alexander.Rivilis
Well I see that it's there under StatusBarItem, but it gives an error under Pane....
If I Have code like this
DetPane.MouseDown += New StatusBarMouseDownEventHandler(AddressOf OnAppMouseDown)
I get this... Could I be missing an Import??
Here are my imports...
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports cadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports cadDocExt = Autodesk.AutoCAD.ApplicationServices.DocumentExtension
Imports Autodesk.AutoCAD.Windows
Steve
16.00 GB RAM
Moderator
Alexander.Rivilis
Message 8 of 8 (178 Views)
12-20-2012 11:26 AM in reply to: stevenh0616
Sub OnPaneMouseDown(ByVal o As Object, ByVal e As StatusBarMouseDownEventArgs)
    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine + "Do something man !" + vbNewLine)
End Sub
<CommandMethod("MyCommand")> _
Public Sub MyCommand() ' This method can have any name
End Sub
