.NET
How to rename an existing classification object
6 REPLIES 6
BIM_Admin_Orbicon
587 Views, 6 Replies
My task is to write an automated routine that checks for a certain classification added to Duct objects.
In the classification definition SfB all classification names of the form (XX)X should be altered/renamed to the form XX.X
Defining a Classification object Classfc as Autodesk.Aec.DatabaseServices.Classification my problem is that the property Classfc.Name is readonly
I struggled with finding another way to solve the problem but have not been able to find a solution.
Any ideas?
Jan Grenov
CAD Manager
Orbicon A/S
6 REPLIES 6
Hi Jan,
How about Rename() method of DictionaryClassificationDefinition class?  Dictionary is a container class of dictionary record.  If you haven't looked at it, could you try?
Mikako Harada
Developer Technical Services
Thanks t for the hint. I will give it a try and let you know how it went.
Jan Grenov
CAD Manager
Orbicon A/S
Hi Mikako
That got me some of the way. Now I can rename the classification definition using the code below. Now I just need to rename som nodes inside the classification tree. However I am having troubles using the classificationtree-rename method. (Have a look at the RenameClassification below).
Any sugestions?
Code example:
<Autodesk.AutoCAD.Runtime.
CommandMethod("RenameClassificationDef")> _
PublicSub RenameClassificationDef()
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim dictClsfcDef AsDictionaryClassificationDefinition = NewDictionaryClassificationDefinition(db)
Dim id AsObjectId = dictClsfcDef.GetAt("AAU_SfBClassification")
Try
Using tr AsTransaction = db.TransactionManager.StartTransaction
Dim SfBClsfc AsObjectId
Dim AAUClsfc AsObjectId
Try
                    SfBClsfc = dictClsfcDef.GetAt(
"SfB")
Catch
EndTry
Try
                    AAUClsfc = dictClsfcDef.GetAt(
Catch
EndTry
If AAUClsfc.IsNull AndAlsoNot SfBClsfc.IsNull Then
                    dictClsfcDef.Rename(
"SfB", "AAU_SfBClassification", tr)
EndIf
Dim Recs AsObjectIdCollection = dictClsfcDef.Records
ForEach RecID AsObjectIdIn Recs
Dim RecObj AsClassificationDefinition = RecID.GetObject(OpenMode.ForWrite)
Dim VVSID AsObjectId = RecObj.GetClassification("VVS-anlæg")
Dim VVSObj AsClassification = VVSID.GetObject(OpenMode.ForWrite)
Next
                tr.Commit()
EndUsing
Catch ex AsException
            ed.WriteMessage(
"Error : " + ex.ToString + vbCrLf)
EndTry
EndSub
Here is the RenameClassification-sub (that fails):
Public Sub RenameClassification(ByRef tr AsTransaction, ByRef node AsClassificationTree)
If node IsNothingThen
Return
EndIf
IfNot (node.Id.IsNull) Then
Dim classi AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForRead), Classification)
            node.Rename(classi.ObjectId,"SomeNewName") THIS FAILS!
EndIf
If node.Children.Count > 0 Then
ForEach ChildTree In node.Children
                RenameClassification(tr, ChildTree)
Next
EndIf
EndSub
Jan Grenov
CAD Manager
Orbicon A/S
Hi Jan,
Could you post this question to AutoCAD Architecture customization forum?
http://forums.autodesk.com/t5/AutoCAD-Architecture/bd-p/54
Sounds like your question became AutoCAD Architecture specific. The audience of this forum is probably wondering what we are talking about 🙂  It will be more appropriate to post in AutoCAD Architecture one.
Glad to hear you have solved the initial question of renaming the classification definition.
Thank you for cooperation.
Mikako Harada
I will do that.
Thanks so far 🙂
Jan Grenov
CAD Manager
Orbicon A/S
Posted question in the Architecture customization forum as "How to make the rename-method of the Classificationtree work?"
Jan Grenov
CAD Manager
Orbicon A/S
”Boost
