.NET
BIM_Manager_Orbicon
Message 1 of 7 (246 Views)
How to rename an existing classification object
246 Views, 6 Replies
07-30-2012 05:00 AM
My task is to write an automated routine that checks for a certain classification added to Duct objects.
In the classification definition SfB all classification names of the form (XX)X should be altered/renamed to the form XX.X
Defining a Classification object Classfc as Autodesk.Aec.DatabaseServices.Classification my problem is that the property Classfc.Name is readonly
I struggled with finding another way to solve the problem but have not been able to find a solution.
Any ideas?
Jan Grenov
CAD Manager
Orbicon A/S
ADN Support Specialist
mikako.harada
Message 2 of 7 (208 Views)
Re: How to rename an existing classification object
08-02-2012 08:43 AM in reply to: BIM_Manager_Orbicon
Hi Jan,
How about Rename() method of DictionaryClassificationDefinition class?  Dictionary is a container class of dictionary record.  If you haven't looked at it, could you try?
Mikako Harada
Developer Technical Services
Autodesk Developer Network
BIM_Manager_Orbicon
Message 3 of 7 (188 Views)
08-02-2012 11:13 PM in reply to: BIM_Manager_Orbicon
Thanks t for the hint. I will give it a try and let you know how it went.
Jan Grenov
CAD Manager
Orbicon A/S
BIM_Manager_Orbicon
Message 4 of 7 (156 Views)
08-06-2012 09:00 AM in reply to: mikako.harada
Hi Mikako
That got me some of the way. Now I can rename the classification definition using the code below. Now I just need to rename som nodes inside the classification tree. However I am having troubles using the classificationtree-rename method. (Have a look at the RenameClassification below).
Any sugestions?
Code example:
<Autodesk.AutoCAD.Runtime.
CommandMethod("RenameClassificationDef")> _
PublicSub RenameClassificationDef()
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim dictClsfcDef AsDictionaryClassificationDefinition = NewDictionaryClassificationDefinition(db)
Dim id AsObjectId = dictClsfcDef.GetAt("AAU_SfBClassification")
Try
Using tr AsTransaction = db.TransactionManager.StartTransaction
Dim SfBClsfc AsObjectId
Dim AAUClsfc AsObjectId
Try
                    SfBClsfc = dictClsfcDef.GetAt(
"SfB")
Catch
EndTry
Try
                    AAUClsfc = dictClsfcDef.GetAt(
Catch
EndTry
If AAUClsfc.IsNull AndAlsoNot SfBClsfc.IsNull Then
                    dictClsfcDef.Rename(
"SfB", "AAU_SfBClassification", tr)
EndIf
Dim Recs AsObjectIdCollection = dictClsfcDef.Records
ForEach RecID AsObjectIdIn Recs
Dim RecObj AsClassificationDefinition = RecID.GetObject(OpenMode.ForWrite)
Dim VVSID AsObjectId = RecObj.GetClassification("VVS-anlæg")
Dim VVSObj AsClassification = VVSID.GetObject(OpenMode.ForWrite)
Next
                tr.Commit()
EndUsing
Catch ex AsException
            ed.WriteMessage(
"Error : " + ex.ToString + vbCrLf)
EndTry
EndSub
Here is the RenameClassification-sub (that fails):
Public Sub RenameClassification(ByRef tr AsTransaction, ByRef node AsClassificationTree)
If node IsNothingThen
Return
EndIf
IfNot (node.Id.IsNull) Then
Dim classi AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForRead), Classification)
            node.Rename(classi.ObjectId,"SomeNewName") THIS FAILS!
EndIf
If node.Children.Count > 0 Then
ForEach ChildTree In node.Children
                RenameClassification(tr, ChildTree)
Next
EndIf
EndSub
Jan Grenov
CAD Manager
Orbicon A/S
mikako.harada
Message 5 of 7 (138 Views)
08-06-2012 03:44 PM in reply to: BIM_Manager_Orbicon
Hi Jan,
Could you post this question to AutoCAD Architecture customization forum?
http://forums.autodesk.com/t5/AutoCAD-Architecture/bd-p/54
Sounds like your question became AutoCAD Architecture specific. The audience of this forum is probably wondering what we are talking about :-)  It will be more appropriate to post in AutoCAD Architecture one.
Glad to hear you have solved the initial question of renaming the classification definition.
Thank you for cooperation.
Mikako Harada
BIM_Manager_Orbicon
Message 6 of 7 (120 Views)
08-07-2012 12:29 AM in reply to: BIM_Manager_Orbicon
I will do that.
Thanks so far :-)
Jan Grenov
CAD Manager
Orbicon A/S
BIM_Manager_Orbicon
Message 7 of 7 (114 Views)
08-07-2012 01:13 AM in reply to: mikako.harada
Posted question in the Architecture customization forum as "How to make the rename-method of the Classificationtree work?"
Jan Grenov
CAD Manager
Orbicon A/S
You are not logged in.
Ask the Community
