• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    How to pass parameter in interface to the programe of .dll file using c#?
    366 Views, 8 Replies
    03-14-2012 11:51 PM
    I  have developped  the  interface using c#,i want to turn off or on the layer according to the parameter in interface.
    now i have carried out turn off or on a specified layer using a .dll file. but how i can connect the parameter in interface to the program in .dll file .thanks
    Please use plain text.
    Distinguished Contributor
    Re: How to pass parameter in interface to the programe of .dll file using c#?
    03-15-2012 07:33 AM in reply to: dreamwtx
    What interface did you develop?  Is it a ribbon? tool palette? Is it an external program?
    -Mark
    03-15-2012 06:06 PM in reply to: MarkPendergraft
    -Mark
    yes ,it is anexternal program. the interface is developped using c#.
    03-15-2012 08:00 PM in reply to: dreamwtx
    If it's an external program, then you need to use the COM API to access functionality inside autocad from your external program.
    Take a look here for someone with the same idea:
    http://forums.autodesk.com/t5/NET/Stand-alone-applications/m-p/2513610/highlight/true#M15108
    You can also search for stand alone applications.  There has been a lot of discussion on this type of thing, but it's not something I've ever explored.
    -Mark
    03-15-2012 10:07 PM in reply to: MarkPendergraft
    Thank you
    Hallex
    03-15-2012 10:21 PM in reply to: dreamwtx
    Show us your code you get started with
    maybe it will be more effective
    ~"J"~
    03-16-2012 12:48 AM in reply to: Hallex
    2. using System;
      using System.Collections.Generic;
      using System.ComponentModel;
      using System.Data;
      using System.Drawing;
      using System.Linq;
      using System.Text;
      using System.Windows.Forms;
      using System.Runtime.InteropServices;
      using Autodesk.AutoCAD.Interop;
      using Autodesk.AutoCAD.Interop.Common;
      using Autodesk.AutoCAD;
      using System.IO;
      //using Autodesk.AutoCAD.ApplicationServices;
      //using Autodesk.AutoCAD.DatabaseServices;
      //using Autodesk.AutoCAD.Runtime;
      //using TurnLayerOff;
      namespace Demo
          public partial class Form1 : Form
              private AcadApplication a;//声明AutoCAD对象
              public Form1()
                  InitializeComponent();
              private void button1_Click(object sender, EventArgs e)
                  a = new AcadApplicationClass();
                  a.Visible = true;
                  string strFileName = "C:\\G4P4-S01.dwg";
                  a.Application.Update();//更新显示
                  a.Application.Documents.Open(strFileName, false, 1);
                  //Autodesk.AutoCAD.Interop.AcadDocument aDocument;
                  //Autodesk.AutoCAD.Interop.Common.AcadLayers acDoc;
                  //a.ActiveDocument.Layers.Item("IN_SWGEAR_CAB_USED").LayerOn=false;
                  //AcadDocument acDocComObj;
                  //acDocComObj = acAppComObj.ActiveDocument;
                  // Optionally, load your assembly and start your command or if your assembly
                  // is demandloaded, simply start the command of your in-process assembly.
                  a.ActiveDocument.SendCommand("(command " + (char)34 + "NETLOAD" + (char)34 + " " +
                                          (char)34 + "c:/myapps/mycommands.dll" + (char)34 + ") ");
                  TurnLayerOff.Class1.TurnLayerOff(textBox2.Text);
                  a.ActiveDocument.SendCommand("TurnLayerOff");
    3.
            TurnLayyerOff  is .dll file.but i can't pass textBox2.text to the ,dll file.
    Hallex
    03-16-2012 02:49 AM in reply to: dreamwtx
    You may want to use direct access to all
    AutoCAD objects this way instead:
                a.Visible = true;
                string strFileName = @"C:\G4P4-S01.dwg";
                AcadApplication acad = (AcadApplication)a as AcadApplication;
                acad.WindowState = AcWindowState.acMax;
                AcadDocument adoc = (AcadDocument)acad.ActiveDocument as AcadDocument;
                AcadUtility acutil = (AcadUtility)adoc.Utility as AcadUtility;
                string layername = textBox2.Text;
                acutil.Prompt(string.Format("\nLAYER SELECTED\t{0}",layername));
                AcadLayers aclayers = (AcadLayers)adoc.Layers;
                AcadLayer aclayer = aclayers.Item(layername) as AcadLayer;
                if (aclayer == null)
                    MessageBox.Show("Layer \"{0}\" does not exist, try another layer name");
                    this.textBox2.Select();
                    this.textBox2.Text = string.Empty;
                    return;
                if (aclayer.ObjectID == adoc.ActiveLayer.ObjectID)
                    MessageBox.Show("This is active layer, program exiting...");
                    return;
                if (aclayer.LayerOn)
                    aclayer.LayerOn = false;
                acutil.Prompt(string.Format("\n\tLAYER \"{0}\" IS OFF", layername));
    ~'J'~
    03-19-2012 08:59 PM in reply to: dreamwtx
    there is an error  "HRESULT:0x80010001 (RPC_E_CALL_REJECTED"
