.NET
phives
Message 1 of 5 (170 Views)
How to open database from an open drawing
170 Views, 4 Replies
08-26-2012 07:05 AM
Once I have the dwg open how do I get to the database?
        Dim AcadApp As Object = Nothing
        Dim AcadDoc As Object = Nothing
        Try
            AcadApp = GetObject(, "AutoCAD.Application.18")
        Catch ex As Exception
            AcadApp = CreateObject("AutoCAD.Application.18")
        End Try
        AcadApp.Visible = False
        Try
            AcadDoc = AcadApp.Documents.Open("C:\Users\PAUL\Desktop\B-03-J-H135.dwg", True)
            Exit Sub
        End Try
        Dim MyDb As Database = AcadApp.DocumentManager.MdiActiveDocument.Database
Alfred.NESWADBA
Message 2 of 5 (168 Views)
Re: How to open database from an open drawing
08-26-2012 07:11 AM in reply to: phives
You have it, where is the question?
You have it here:
That <MyDb> is the database of your currently active drawing!
- alfred -
Alfred NESWADBA
norman.yuan
Message 3 of 5 (154 Views)
08-26-2012 10:09 AM in reply to: phives
From he code yoy showed (and also the code you showed in previous post), it looks like you are doing Stabdalone EXE apllication.
If so, you can forget about setting reference to acdbmgd.dll and acmgd.dll and using APIs exposed in these 2 assemblies: they CANNOT be used outside AutoCAD in a standalone app. End of story.
You have to use COM APIs. The code would be sililar to VBA code.
phives
Message 4 of 5 (152 Views)
08-26-2012 10:18 AM in reply to: norman.yuan
Well then tell me how. Because there are other apps out there doing what I need to do. According to the docs from ACAD, that is what those DLL's are for.
Hallex
Message 5 of 5 (144 Views)
08-26-2012 11:32 AM in reply to: phives
As you're mentioned above you HAVE NOT use dll libraries
in your .exe aplppliction at all,
so forget about them, indeed
Use just VBA like syntax and nothiing else, in the short words
~'J'~
