• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Leimhu
    How to open autocad.exe in C# , PLEASE HELP!
    1095 Views, 23 Replies
    02-05-2012 12:13 AM
    I am using Visual.net 2008 with autocad.net API, autocad2010, windows 7 home
    right now, i want to start autocad.exe, and draw some lines in it, by using C# WindowsFormsApplication, not  C# Class Library
    still i cannot start autocad.exe
    I hope to open cad by autocad.net API, not ObjectARX or others
    I am a new one,  please HELP ME
    thanks very very much !
    Please use plain text.
    Valued Contributor
    Re: How to open autocad.exe in C# , PLEASE HELP!
    02-05-2012 02:12 AM in reply to: Leimhu
    There is no exe autocad, you mean acad.exe?
    You cant program in autocad through windows forms with just opening acad.exe with out ObjectARX
    Hallex
    02-05-2012 03:14 AM in reply to: Leimhu
    If you want to don't add any reference to acad's libraries
    in this case just one way to do it is using late-binding to AutoCAD
    There is a ton of code to do this work
    Hallex
    02-05-2012 05:43 AM in reply to: Leimhu
    Here are 2 files were written on vb.net
    See if this will be working fror you
    Leimhu
    02-06-2012 01:54 AM in reply to: Hallex
    Thanks very much ! really appreciate your great help ~
    actually i work it out by using C# library
    Hallex
    02-06-2012 08:17 AM in reply to: Leimhu
    Create Wndws Forms Application project
    Name it AcadTestExe
    Add form Form1 to project
    Drop on form OpenFileDialog, texbox and button
    Keep default names for all controls
    Add class ReflectionCommands.cs
    Copy all codes accodingy to classes, then hit F5
    ~'J'~
    Leimhu
    02-06-2012 06:26 PM in reply to: Hallex
    Dear Hallex, you are genius!!!
    I tried your codes, and it works very well~
    Thank for your help, It's really great~
    althought I cannot figured out how you fix it without adding any CAD liraries or dll
    I am a new one in cad developping , these days I kept searching for any useful book or documents
    still there is no result
    Can you give me some advice for learning cad with C# ? Is there any useful documents for me ?
    PS: I can draw circle by your  incredible codes, Could you please tell me how to draw a ARC ?
    Hallex
    02-06-2012 09:00 PM in reply to: Leimhu
    C'mon
    This is very simple code
    Glad you like it
    This project does not require any
    CAD library
    I tested it on A2009-2010 Win7
    Will be back
    ~'J'~
    Leimhu
    02-06-2012 11:07 PM in reply to: Hallex
    your code is incredible simple, I enjoy it
    I cannot understand you until now
    with your help, I figured it how to draw an arc
    thanks ~~~~~~
    and please give me some advice :smileytongue:
    Leimhu
    02-07-2012 12:27 AM in reply to: Hallex
    dear Hallex:
       I use your code to draw some lines in cad,
      It is ok in WIN7 64bit + AUTOCAD2008 and WinXP + AUTOCAD2004
     but errors happened in WinXP + AUTOCAD2008
     my code is :
    for (int k = 1; k < iHH.OutHHXY.Row - 1; k++)
    pt2[0] = iHH.OutHHXY[k, 0];
    pt2[1] = iHH.OutHHXY[k, 1];
    drawLineInObject(oSpace, pt1[0], pt1[1], pt2[0], pt2[1], "0");
    pt1[0] = pt2[0];
    pt1[1] = pt2[1];
    The error happened in these lines:
    object oLine = oBlock.GetType().InvokeMember("AddLine", BindingFlags.InvokeMethod, null, oBlock, pts);
    oLine.GetType().InvokeMember("Layer", BindingFlags.SetProperty, null, oLine, new object[] { layer });
    oLine.GetType().InvokeMember("Update", BindingFlags.InvokeMethod, null, oLine, null);
    BUT , if I debug the loops one by one, It runs well. I am so confused~
    please help me ~~
    Thanks very much !!!
    1
