.NET
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to list all linetype of Acad.lin
- Highlight
- Email to a Friend
- Report Inappropriate Content
here my code :
Public Function LectureDefLine() As Collection
Dim db As Database = New Database(True, False)
Dim OkErreur As Boolean = False
dim cCollDefTypeLine as collection = New Collection
Try
Dim path As String = HostApplicationServices.Current.FindFile("acad.lin ", db, FindFileHint.Default)
db.LoadLineTypeFile("*", path)
Catch ex As Autodesk.AutoCAD.Runtime.Exception
If (ex.ErrorStatus = Autodesk.AutoCAD.Runtime.ErrorStatus.FilerError) Then
MsgBox("Impossible de trouver le fichier " & "acad.lin", MsgBoxStyle.Information, "Erreur système")
OkErreur = True
ElseIf (ex.ErrorStatus = Autodesk.AutoCAD.Runtime.ErrorStatus.DuplicateReco rdName) Then
'Ligne déja connu --> passe
Else
MsgBox(ex.ToString, MsgBoxStyle.Information, "Erreur système")
OkErreur = True
End Try
If OkErreur = False Then
'iterate les typeline
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Try
Dim TypelineT As DBObject = tr.GetObject(db.LinetypeTableId, OpenMode.ForRead)
Dim tbl As SymbolTable = CType(TypelineT, SymbolTable)
If IsNothing(tbl) = False Then
Dim tblRecId As ObjectId
For Each tblRecId In tbl
Dim tmpObj1 As DBObject = tr.GetObject(tblRecId, OpenMode.ForRead)
Dim rec As SymbolTableRecord = CType(tmpObj1, LinetypeTableRecord)
If Not (rec Is Nothing) Then
cCollDefTypeLine.Add(rec.Name, rec.Name)
'ed.WriteMessage("Adding LineType " & rec.Name & vbCrLf)
Next
Catch ex As Exception
MsgBox(ex.ToString, MsgBoxStyle.Information, "err")
Finally
tr.Commit()
tr.Dispose()
End Try
db.Dispose()
db = Nothing
Return cCollDefTypeLine
End FunctioncCollDefTypeLine : i use it for populate a ComboxColumn of a dataview.
I want populate a ColumnDataview but not integrate all the linetype in mu current dwg.
This code run but acad crash after .. So have you a function/sub working fine ?
Thx All
Re: How to list all linetype of Acad.lin
- Highlight
- Email to a Friend
There was a post on this subject here:
Hope that helps.
Quigs.
- Highlight
- Email to a Friend
I'm Not 100% sure this will solve the problem, but try calling db.CloseInput(True) before calling db.Dispose.
- Highlight
- Email to a Friend
You could also mkaybe do something like this?
[CommandMethod("ListLineTypes")]
public void ListLineTypes()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
string path = HostApplicationServices.Current.FindFile("acad.lin ", db, FindFileHint.Default);
using (StreamReader sr = new StreamReader(path))
Char[] c = new Char[] { ',' };
while (sr.Peek() >= 0)
string s = sr.ReadLine();
if (s.StartsWith("*"))
string[] info = s.Split(c);
ed.WriteMessage("\nName:{0} --- Description:{1}", info[0].Substring(1), info[1]);
- Highlight
- Email to a Friend
thank all
DesignProQuiq --> I dont want load all typeline in my current drawing.
Jeff --> Oh i have to test that tomorrow.
- Highlight
- Email to a Friend
Thx it is working good.
Here the code in vb.net.
'chargement des type de ligne connu
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.D ocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
'Dim ed As Autodesk.AutoCAD.EditorInput.Editor = doc.Editor
cCollDefTypeLine = New Collection
Dim path As String = HostApplicationServices.Current.FindFile(NomFichie rLigne, db, FindFileHint.Default)
Using sr As System.IO.StreamReader = New System.IO.StreamReader(path)
Dim c As Char() = New Char() {","}
While (sr.Peek() >= 0)
Dim s As String = sr.ReadLine()
If (s.StartsWith("*")) Then
Dim info() As String = s.Split(c)
'ed.WriteMessage("\nName:{0} --- Description:{1}", info(0).Substring(1), info(1))
cCollDefTypeLine.Add(info(0).Substring(1), info(0).Substring(1))
End While
End Using
End Function
- Highlight
- Email to a Friend
I swear I posted this last night, but it is not here now, so here it is again.
I noticed something, and checked my own code, and I believe the problem with your original code was the New Database constructor. My code is always reading an existing drawing, and calls New Database (False, True). With your code creating a databse from scratch, I think you did need the first argument {buildDefaultDrawing} to be True, but you definitely needed the second argument {noDocument} to be True.
That is pretty much "For your information", because I agree that if all you need is a list of linetype names, it is better to just parse them out of the text file than to do all that stuff with the new database.
