.NET
How to jig a Spline (fit points) using AutoCAD 2013 .NET API?
5 REPLIES 5
JoseVicario
1752 Views, 5 Replies
How can I draw Spline with fit points in AutoCAD 2013 .NET API using my own jig?
5 REPLIES 5
Balaji_Ram
in reply to: JoseVicario
Here is a sample code that might help in getting started with jigging of spline. It is a modified version of the code from this blog post dealing with polyline jigging.
http://through-the-interface.typepad.com/through_the_interface/2010/12/jigging-an-autocad-polyline-w...
Here is the code :
using System;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(SplineJig.SplineJigCmds))]
namespace SplineJig
	public class SplineDrawJig : DrawJig
		// members
		private Point3d _point;
		private Point3dCollection _points = new Point3dCollection();
		public Point3dCollection Coordinates
			get
				return _points;
		public SplineDrawJig()
		public void DoIt()
			Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
			PromptResult jigRes = null;
			do
				jigRes = ed.Drag(this);
				if (jigRes.Status == PromptStatus.OK)
					_points.Add(_point);
				else if (jigRes.Status == PromptStatus.None)
					break;
			while (jigRes.Status == PromptStatus.OK);
		protected override Autodesk.AutoCAD.EditorInput.SamplerStatus
		Sampler(Autodesk.AutoCAD.EditorInput.JigPrompts prompts)
			JigPromptPointOptions jigOpts = new JigPromptPointOptions();
			jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
			jigOpts.Message = "Select fit point: ";
			PromptPointResult jigRes = prompts.AcquirePoint(jigOpts);
			Point3d pt = jigRes.Value;
			if (pt == _point)
				return SamplerStatus.NoChange;
			_point = pt;
				return SamplerStatus.OK;
			return SamplerStatus.Cancel;
		protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
			if (_points.Count == 0)
				return true;
			Point3dCollection vertices = new Point3dCollection();
			foreach (Point3d point in _points)
				vertices.Add(point);
			vertices.Add(_point);
			int totalVertices = vertices.Count;
			if(totalVertices >= 2)
				Line chordLine = new Line(vertices[totalVertices - 1], vertices[totalVertices-2]);
				draw.Geometry.Draw(chordLine);
			Spline spline = new Spline(vertices, KnotParameterizationEnum.Chord, 3, 0.0);
			draw.Geometry.Draw(spline);
			return true;
	public class SplineJigCmds
		public SplineJigCmds() { }
		[CommandMethod("SplineJig")]
		static public void SplineJig()
			try
				Database db = ed.Document.Database;
				SplineDrawJig splineJig = new SplineDrawJig();
				splineJig.DoIt();
				// order of the curve can be between 2 and 26
                int order = 6;
                // determines extent of interpolation through all the points
                double fitTolerance = .5;
				Spline spline = new Spline(splineJig.Coordinates, KnotParameterizationEnum.Chord, 3, 0.0);
				using (Transaction tr = db.TransactionManager.StartTransaction())
					BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
					btr.AppendEntity(spline);
					tr.AddNewlyCreatedDBObject(spline, true);
					tr.Commit();
			catch (System.Exception ex)
				MessageBox.Show(ex.Message, "Exception", MessageBoxButtons.OK, MessageBoxIcon.Error);
 Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
JoseVicario
in reply to: Balaji_Ram
Thank You for answer. Perfect solution!
SRSDS
I'd like to add an rotated entity to the ends of the spline.
The Spline.StartFitTangent is giving a result of (0,0,0)
Is there another way of getting the angle of the start and endpoints?
hgasty1001
in reply to: SRSDS
you can obtain the tangent angle from the first derivative of the curve with: MySpline.GetFirstDerivative(AtSomePoint), check the docs for others method that the curve class have.
Gaston Nunez
SRSDS
in reply to: hgasty1001
Thanks Gaston!
”Boost
