.NET
How to insert block with attributes into a drawing using .NET
11 REPLIES 11
Message 1 of 12
3480 Views, 11 Replies
Has everyone tried to insert blocks with attributes into a drawing file by
using dotnet (C# or VB.NET)?
There is an example "How to insert block with attributes into a drawing
using VB.NET" from ADN web site. But unfortunately, it doesn't work. Anytime
the attributes are inserted on Original position no matter how Position
properties of the attributes are set.
Following is part of my code:
AttributeDefinition attDef = (AttributeDefinition)ent;
AttributeReference attRef = new AttributeReference();
attRef.SetAttributeFromBlock(attDef, Matrix3d.Identity);
Point3d ptBase = new Point3d(blkRef.Position.X + attDef.Position.X,
blkRef.Position.Y + attDef.Position.Y,
blkRef.Position.Z + attDef.Position.Z);
//attRef.Position = ptBase;
//attRef.Position = insPoint;
attRef.Position = new Point3d(50, 50, 50);
attRef.Rotation = attDef.Rotation;
attRef.Tag = attDef.Tag;
attRef.TextString = "Attribute Text";
attRef.Height = attDef.Height;
attRef.FieldLength = attDef.FieldLength;
Can anybody help? Thank you very much.
Zhongwei Xia
11 REPLIES 11
Message 2 of 12
Does the sample code from ADN actually show a call
to SetAttributeFromBlock(), with Matrix3d.Identity as
the second parameter???
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Zhongwei Xia" wrote in message news:4967475@discussion.autodesk.com...
Zhongwei Xia
Message 3 of 12
Hi, Tony,
Yes, it does. Thank you for your reply.
Zhongwei
"Tony Tanzillo" wrote in message
news:4967690@discussion.autodesk.com...
Zhongwei Xia
Message 4 of 12
Amazing.
The Matrix3d argument to SetAttributeFromBlock()
should be set to the value of the BlockTransform
property of the owning BlockReference object.
"Zhongwei Xia" wrote in message news:4967872@discussion.autodesk.com...
Hi, Tony,
Zhongwei
Zhongwei Xia
Message 5 of 12
Hi, Tony,
Guess what!? I just comment the following line out, and set TextStyle from
AttributeDefinition. It works!!!.
// attRef.SetAttributeFromBlock(attDef, Matrix3d.Identity);
attRef.TextStyle = attDef.TextStyle;
Thank you very much. You emails help me alot.
Zhongwei
news:4968102@discussion.autodesk.com...
Amazing.
Hi, Tony,
Zhongwei
Zhongwei Xia
Message 6 of 12
Most of the code from the example is not required if
you make the change I noted. For example, there
should be no need for manual translation, rotation,
and scaling since the BlockTransform matrix contains
all of that information, and SetAttributeFromBlock()
should do the transformation for you.
If I'm wrong about that, please let me know.
"Zhongwei Xia" wrote in message news:4968152@discussion.autodesk.com...
Hi, Tony,
Zhongwei
Amazing.
Hi, Tony,
Zhongwei
Zhongwei Xia
Message 7 of 12
Thank you for your email.
SetAttributeFromBlock() can't be called. If I call this function, attributes
will go to (0,0,0) position.
And also, if I set HorisontalMode of attribute, the attributes go to (0,0,0)
again.
attRef.HorizontalMode =
Autodesk.AutoCAD.DatabaseServices.TextHorizontalMode.TextCenter;
Zhongwei
news:4968338@discussion.autodesk.com...
Hi, Tony,
Zhongwei
Amazing.
Hi, Tony,
Zhongwei
Zhongwei Xia
Message 8 of 12
>> If I call this function, attributes will go to (0,0,0) position.
Did you pass the value of the BlockTransform property of
the BlockReference object to the second argument to
SetAttributesFromBlock, as I had mentioned earlier?
"Zhongwei Xia" wrote in message news:4969406@discussion.autodesk.com...
Message 9 of 12
I just tried it. I works great.
I appreciate your helps very much.
Zhongwei
news:4969620@discussion.autodesk.com...
Message 10 of 12
Is it possible for you to post the final code?
Roland
"Zhongwei Xia" schrieb im Newsbeitrag
news:4969745@discussion.autodesk.com...
Zhongwei
Message 11 of 12
Following is the code to insert AttributeReference.
public static void InsertBlockAttibuteRef(ObjectId blockDefID,
BlockReference blkRef,
string strAttributeText, Point3d ptInsert)
Database dbCurrent = HostApplicationServices.WorkingDatabase;
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm =
dbCurrent.TransactionManager;
using (Transaction tr = tm.StartTransaction())
DBObject objBlkRef = tr.GetObject(blkRef.ObjectId, OpenMode.ForWrite);
BlockTableRecord btAttRec;
btAttRec = (BlockTableRecord)tr.GetObject(blockDefID, OpenMode.ForRead);
foreach (ObjectId idAtt in btAttRec)
Entity ent = (Entity)tr.GetObject(idAtt, OpenMode.ForRead);
if (ent is AttributeDefinition)
attRef.SetAttributeFromBlock(attDef, blkRef.BlockTransform);
attRef.TextString = strAttributeText;
ObjectId idTemp = blkRef.AttributeCollection.AppendAttribute(attRef);
tr.AddNewlyCreatedDBObject(attRef, true);
tr.Commit();
} // end of using
wrote in message news:4971700@discussion.autodesk.com...
Roland
Zhongwei
Message 12 of 12
Thank you!
Roland Feletic
”Boost
