.NET
How to get the current drawings scale
3 REPLIES 3
1626 Views, 3 Replies
I am trying to get scale factor of whole drwaing using c# code.I am able to get only single entities scale factor. So does any body have solution for this?
Thanks in advance
3 REPLIES 3
Do you mean the sysvar "DIMSCALE" as the drawing scale factor?
You could use:
double dDimScale =
(double)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DIMSCALE");
schreef in bericht news:5405712@discussion.autodesk.com...
this?
Thanks in advance
Database.Ltscale
Is that what you want?
"Henk Loonstra" wrote in message
news:5405715@discussion.autodesk.com...
You could use:
double dDimScale =
this?
Thanks in advance
Yaa thank you got the way
”Boost
