.NET
How to get the AlignmentPoint according the ObjectID of DBtext?
2 REPLIES 2
242 Views, 2 Replies
Help me! Friends:
I have got the ObjectID of a Entity of DBtext,and I want to get the AlignmentPoint of the DBText.
The Codes below :
Dim ent As Entity = tm.GetObject(id, OpenMode.ForWrite, False)
Dim dbtxt As DBText= CType(ent, DBText)
the value of "dbtxt.textString" is correct
but the value of "dbtxt.AlignmentPoint.Y" is 0 !!!
I don't know Why I can't get the X,Y,Z of the AlignmentPoint
Maybe the issue is "Dim dbtxt As DBText= CType(ent, DBText)",but I don't know how to solve the problem.
please Help me!
Regards!
2 REPLIES 2
I sovle it
use "position" property
thank zmkm1234!
Just notice that Position and AlignmentPoint are two different properties. Normally they display the same thing, but if you for example center a text, AlignmentPoint and Position are different. Check the AlignmentPoint of your text in the Properties panel in Autocad to see if it has a Y value different than 0.
”Boost
