.NET
How to get all names of layers in a drawing by traversal layers using c#?
7 REPLIES 7
Message 1 of 8
dreamwtx
9209 Views, 7 Replies
I want to get all names of layers in a drawing ,and then  put them in a array.  how to carry out it.
7 REPLIES 7
Message 2 of 8
Hallex
in reply to: dreamwtx
I think easier to gather layer names to List of string
then you can easy to convert to array using
List.ToArray() method
Here is a quick sample:
// This method can have any name
        [CommandMethod("DisplayLayers","displa", CommandFlags.Modal)]
        public void TestDisplayLayers()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            List<string> info = LayersToList(db);
            foreach (string lname in info)
                ed.WriteMessage("\nLayer Name: \t{0}", lname);
        public List<string> LayersToList(Database db)
            List<string> lstlay = new List<string>();
            LayerTableRecord layer;
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                foreach (ObjectId layerId in lt)
                    layer = tr.GetObject (layerId, OpenMode.ForWrite) as LayerTableRecord;
                    lstlay.Add(layer.Name);
            return lstlay;
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 8
Paulio
in reply to: Hallex
Just curious Hallex, what's different about "StartOpenCloseTransaction" as opposed to "StartTransaction"?
Message 4 of 8
Hallex
in reply to: Paulio
To be honestly I did not read Arx docs about this
I use it when I just do nothing in the drawing,
as in this case to read something from document only
Smiley Indifferent
Message 5 of 8
Radnus_87
in reply to: Hallex
Thanks for Posting this routine. But i need to get the list of layer names which are turned on in current drawing not all the layers in the drawing. How to get it
Message 6 of 8
Paulio
in reply to: Radnus_87
You could test the IsOff property of the LayerTableRecord before adding it to the list:
                    if (!layer.IsOff)
You could also test for IsFrozen if required...
Message 7 of 8
_gile
in reply to: Paulio
About StartTransaction() vs StartOpenCloseTransaction(), you can read this:
http://adndevblog.typepad.com/autocad/2012/08/the-right-tools-for-the-job-autocad-part-5.html
and this:
http://docs.autodesk.com/ACD/2014/DEU/index.html?url=files/GUID-50FD6118-B2D1-4313-A7D6-830794DFDEFA...
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
Radnus_87
in reply to: Paulio
Got it..Thanks for your reply 🙂
”Boost
