.NET
Active Contributor
anikakramer2006
Message 1 of 3 (128 Views)
Accepted Solution
How to get all MLeaders, even in Blocks nested ones?
128 Views, 2 Replies
08-13-2013 10:12 PM
Hello alltogether,
I need to EnableFrameText to all MLeaders in a drawing,
I also want to get the MLeaders who are nested in Blocks
automatically...
I started this way but It just works fine with the Mleaders in Modelspace
or if I open the Blockeditor to edit Mleaders nested in a Block...
I know I'm not going to "deep", maybe I need an other Transaction,
or thirst open each Block to edit... not right sure...
maybe I'm on a wrong way, absolutely...
can somebody help me?
Thank you :smileysurprised:)
my example:
        //Ändert leider nur die MLeader die nicht in einem Block sind....
        [CommandMethod("MLeaderIterator")]
        public static void MLeaderIterator_Method()
            Database database = HostApplicationServices.WorkingDatabase;
            using (Transaction transaction = database.TransactionManager.StartTransaction())
                BlockTable blkTable = (BlockTable)transaction.GetObject(database.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btRecord = (BlockTableRecord)transaction.GetObject(blkTable[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                foreach(ObjectId id in btRecord)
                    if(id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(MLeader))))
                        MLeader _mLeader = (MLeader)transaction.GetObject(id, OpenMode.ForRead);
                        if (_mLeader.EnableFrameText == true)
                            _mLeader.UpgradeOpen();
                            _mLeader.EnableFrameText = false;
                            _mLeader.TextColor = Color.FromColorIndex(ColorMethod.ByColor, 240);
                            _mLeader.DowngradeOpen();
                transaction.Commit();
Valued Mentor
Message 2 of 3 (123 Views)
Re: How to get all MLeaders, even in Blocks nested ones?
08-13-2013 10:32 PM in reply to: anikakramer2006
Just iterate all BlockTableRecords in the BlockTable.
A 45 second refactor from previous snippet
           IntPtr mleaderPtr = RXClass.GetClass(typeof(MLeader)).UnmanagedObject;
               foreach (ObjectId btRecordId in blkTable)
                   BlockTableRecord btRecord = (BlockTableRecord)transaction.GetObject(btRecordId, OpenMode.ForRead);
                   if (!(btRecord.IsDependent || btRecord.IsFromExternalReference || btRecord.IsAProxy))
                       foreach (ObjectId id in btRecord)
                           if (id.ObjectClass.UnmanagedObject == mleaderPtr)
You can also find your answers @ TheSwamp
Active Contributor
anikakramer2006
Message 3 of 3 (119 Views)
08-13-2013 10:49 PM in reply to: jeff
Good Morning,
wow, with an blink of an eye...
it worked perfect!
The only thing I had to add on the end of the transaction was:
Application.DocumentManager.MdiActiveDocument.Editor.Regen();
so the frames of the MLeaders are all gone.
Thank you so much!
This example will also help me for other selections.
Big help! :smileysurprised:)
Have a nice day,
Anika
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
