.NET
How to get Block's Layer name?
30 REPLIES 30
Message 1 of 31
MGOMKD
1987 Views, 30 Replies
After searching for a long time on the web, does anyone know how to get the block's layer name?
I iterate through Blocks to get informations but i'm not able to code the source to obtain what i want?
Sample source taken from AutoCAD.NET site:
 Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            '' Step through the Block table record
            For Each acObjId As ObjectId In acBlkTblRec
                acDoc.Editor.WriteMessage(vbLf & "DXF name: " & acObjId.ObjectClass().DxfName)
                acDoc.Editor.WriteMessage(vbLf & "ObjectID: " & acObjId.ToString())
                acDoc.Editor.WriteMessage(vbLf & "Handle: " & acObjId.Handle.ToString())
                acDoc.Editor.WriteMessage(vbLf)
            Next
            '' Dispose of the transaction
        End Using
 Maybe use nested transaction to iterate through LayerTableId?
ideas?
30 REPLIES 30
Message 2 of 31
Hallex
in reply to: MGOMKD
Try this function to get the block name
		Public Shared Function EffectiveName(blkref As BlockReference) As String
			If blkref.IsDynamicBlock Then
				Using obj As BlockTableRecord = DirectCast(blkref.DynamicBlockTableRecord.GetObject(OpenMode.ForRead), BlockTableRecord)
					Return obj.Name
				End Using
			Return blkref.Name
		End Function
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 31
MGOMKD
in reply to: MGOMKD
Hi Hallex,
I don't want to get the block's name but the layer's name on which the block is attached!
Thanks a lot.
Message 4 of 31
Hallex
in reply to: MGOMKD
Sorry for that
To get a layer you have to cast object as Entity, something like:
                    Dim ent As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                    acDoc.Editor.WriteMessage(vbLf & "Layer: " & ent.Layer.ToString())
                Next
                ''Dispose of the transaction
            End Using
~'J'~
Message 5 of 31
MGOMKD
in reply to: Hallex
What the...
It  was so easy that i didn't see it! I'll try this.
You're the fastest and the best Hallex!
See you.
PS: I'm French, so all apollogies to my syntaxe script.
Message 6 of 31
MGOMKD
in reply to: MGOMKD
yeah it works!
Message 7 of 31
Hallex
in reply to: MGOMKD
Glad to help
Cheers 🙂
~'J'~
Message 8 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
How are you? I have a new matter that i cannot solve.
You helped me to find le layer's name of a block.
Now i would like to find property's block (AcadObject: Polyline, Arc....). For instance for each block in a particular layer, iterate through each ones, then showing all properties like length,  boundary closed or opened, width....
'Compte du nombre d'objet(s) dans le calque séléctionné'
                Using acTrans = acDocs.MdiActiveDocument.Database.TransactionManager.StartTransaction()
                    acBlkTbl = acTrans.GetObject(acDocs.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead)
                        Dim MyEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead)
                        If MyEnt.Layer = LayerVal Then
                            'MsgBox(acObjId.ObjectClass.DxfName)
                            Select Case acObjId.ObjectClass.DxfName
                                '* ARC *'
                                Case Is = "ARC"
                                    'LENGTH'
                                    MsgBox (?)
                                Case Is = "CIRCLE"
                                Case Is = "DIMENSION"
                                Case Is = "HATCH"
                                Case Is = "LINE"
                                Case Is = "LWPOLYLINE"
                                Case Is = "MTEXTE"
                                Case Is = "POINT"
                                Case Is = "RAY"
                                Case Is = "REGION"
                                Case Is = "TEXTE"
                                Case Is = "SPLINE"
                                Case Is = "XLINE"
                            End Select
                    Next acObjId
                End Using
            End With
 Do you have any ideas?
Message 9 of 31
MGOMKD
in reply to: MGOMKD
I think i could find a way through this link!
Through the Interface
Message 10 of 31
Hallex
in reply to: MGOMKD
This will get you started, I have no time on complete solution
Change properties for every type what you'll want to retrieve
Here is just a quick example:
        <CommandMethod("getsubentitiesinfo", "GetS", CommandFlags.Modal)> _
        Public Shared Sub explodeRef()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim info As String = ""
            Dim opts As New PromptEntityOptions(vbLf & "Select block reference")
            opts.SetRejectMessage(vbLf & "Select only type of block reference!")
            opts.AddAllowedClass(GetType(BlockReference), False)
            Dim res As PromptEntityResult = ed.GetEntity(opts)
            If res.Status <> PromptStatus.OK Then Return
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim bref As BlockReference = TryCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), BlockReference)
                Dim expobjs As New DBObjectCollection()
                bref.Explode(expobjs)
                Dim table As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                For Each obj As DBObject In expobjs
                    If TypeOf obj Is Entity Then
                        Select Case obj.GetRXClass().DxfName
                            Case "LWPOLYLINE"
                                info = ""
                                Dim poly As Polyline = TryCast(obj, Polyline)
                                info = String.Format(vbLf + "Number of points: {0}" + vbLf + "Closed? {1}" + vbLf + "Layer: {2}" + vbLf + "Color: {3}", poly.NumberOfVertices, poly.Closed, poly.Layer, poly.ColorIndex)
                                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(info)
                            Case "ARC"
                                info = ""
                                Dim arc As Arc = TryCast(obj, Arc)
                                info = String.Format(vbLf + "Center: {0}" + vbLf + "Start angle: {1}" + vbLf + "End angle: {2}" + vbLf + "Start point{3}" + vbLf + "End point: {4}" + vbLf + "Layer: {5}" + vbLf + "Color: {6}", arc.Center, arc.StartAngle, arc.EndAngle, arc.StartPoint, arc.EndPoint, arc.Layer, arc.ColorIndex)
                                ''ETC..ETC...
                            Case "CIRCLE"
                            Case "DIMENSION"
                            Case "HATCH"
                            Case "LINE"
                            Case "LWPOLYLINE"
                            Case "MTEXT"
                            Case "POINT"
                            Case "RAY"
                            Case "REGION"
                            Case "TEXT"
                            Case "SPLINE"
                            Case "XLINE"
                        End Select
                Next
                'clean up memory, optional
                    obj.Dispose()
                Next
                tr.Commit()
            End Using
        End Sub
~'J'~
Message 11 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
I'm very surprised you're very quick! Thank you.
Now i have to understand code and work on it.
See you!
Message 12 of 31
Hallex
in reply to: MGOMKD
Good to hear that,
Just a hint, you could be able to collect all of values of the particular subentity
into the
 List(Of (List (Of String))
( every single item inside into the List (of String)),
then this would be easier to write to the data file on another storage,
hth,
~'J'~
Message 13 of 31
MGOMKD
in reply to: Hallex
Hi Hallex, how are you?
I try de write the best code to obtain what i want but when i run it on AutoCAD, i have a dialog box error.
So in a module vars.
Module Paramètres
    '* Paramètres du Document Actif *'
    Public acDocs As DocumentCollection = Application.DocumentManager
    Public acDoc As Document = acDocs.MdiActiveDocument
    Public acCurDb As Database = acDoc.Database
    Public acTrans As Transaction
Public acBlkTbl As BlockTable
    Public acBlkTblRec As BlockTableRecord
End Module
 And the code
Sub ExcelApp(ByVal LayerVal)
        '* Génération du fichier Excel *'
Using acTrans = acCurDb.TransactionManager.StartTransaction() acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
For Each acObjId As ObjectId In acBlkTblRec Dim MyEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead) If MyEnt.Layer = LayerVal Then Select Case acObjId.ObjectClass.DxfName '******' '* ARC *' '******' Case Is = "ARC" Dim MyArc As AcadArc = CType(acTrans.GetObject(MyEnt.AcadObject, OpenMode.ForRead), AcadArc) MsgBox(MyArc.ArcLength) End If Next acObjId
End Using
 Error message: Impossible to cast type's object.
                          'Autodesk.AutoCAD.DatabaseServices.Arc' to 'Autodesk.AutoCAD.Interop.Common.AcadArc'
Am i on the right way?
Message 14 of 31
MGOMKD
in reply to: MGOMKD
Hi all,
I just found what's wrong in my source code!
Change these lines:
 by:
Dim MyArc As Autodesk.AutoCAD.DatabaseServices.Arc = TryCast(MyEnt, Entity)
MsgBox (MyArc.Length)
 Thanks to Hallex!
Message 15 of 31
Hallex
in reply to: MGOMKD
Glad you solved it by yourself,
Happy coding Smiley Happy
~'J'~
Message 16 of 31
MGOMKD
in reply to: Hallex
I've met another matter!
When I iterate through specifics entities (like LWPOLYLINE, LINE, CIRCLE,...etc) sometimes my source code deal with "POINT". So I would like to cast it to obtain coordinates (X, Y, Z).
Dim MyPoint As Point3d = TryCast(MyEnt, Entity)
But the matter is I cannot access coordinate of these entity, cause Point3d belongs to Autodesk.AutoCAD.Geometry whereas MyEnt belong to AutoDesk.AutoCAD.DatabaseServices
How could I reach these informations?
Message 17 of 31
Hallex
in reply to: MGOMKD
You could be able to get coordinates from polyline
with help of these functions:
''============================= LWPolyline =======================
 Public Shared Function getAllVertices(ByVal ent As Polyline) As Point2dCollection
    Dim verCollection As Point2dCollection = New Point2dCollection()
    Dim vertex As Point2d
    Dim i As Integer = 0
      For i = 0 To ent.NumberOfVertices - 1
        vertex = ent.GetPoint2dAt(i)
     verCollection.Add(vertex)
    Next
    Return verCollection
  End Function
''============================= 3dPoly =======================
     Public Shared Function Get3dPolyVertices(ByVal poly3d As Polyline3d) As Point3dCollection
            Dim pts As New Point3dCollection
            For i As Integer = 0 To poly3d.EndParam
                pts.Add(poly3d.GetPointAtParameter(i))
            Next i
        Return pts
    End Function
 From line you can get coordinates:
Dim sp as point3d= line.StartPoint
dim ep as point3d= line.EndPoint
same way for arc,circle etc
just find in Intellisence box appropriate properties for them all
~'J'~
Message 18 of 31
MGOMKD
in reply to: Hallex
Hi Hallex!
Always at the top!
I work on it, thanks a lot.
Message 19 of 31
Hallex
in reply to: MGOMKD
:Glad to help
Cheers :smileyhappy
~'J'~
Message 20 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
I had found another way to obtain coords.
Case Is = "POINT"
                                    '* POINT *'
                                    'Insertion du texte'
                                    acMText = New MText()
                                    Dim X as Double = MyEnt.GeometricExtents.MinPoint.X
                                    Dim Y as Double = MyEnt.GeometricExtents.MinPoint.Y
                                    Dim Z as Double = MyEnt.GeometricExtents.MinPoint.Z
                                    With acMText
                                        acMText.SetDatabaseDefaults()
                                        acMText.Location = New Point3d(X, Y, Z)
                                        acMText.Attachment = AttachmentPoint.BottomLeft
                                        acMText.TextHeight = acHeightText
                                        acMText.Contents = i
                                    End With
                                    acBlkTblRec.AppendEntity(acMText)
                                    acTrans.AddNewlyCreatedDBObject(acMText, True)
                                    'Libération de la variable'
                                    MyEnt = Nothing
                                    acMText = Nothing
 But what the difference between "MinPoint" and "MaxPoint"? I tried twice and it gaves the same result!
Thank You.
”Boost
