.NET
Hallex
Message 21 of 31 (274 Views)
Re: How to get Block's Layer name?
08-18-2012 12:38 PM in reply to: MGOMKD
Shortly, the Minpoint is means a lower left corner of bounding box of the object,
Maxpoint is opposite corner, kind of 2 corners of text frame
Here is a code to demonstate the mtext frame
    <CommandMethod("FMM")> _
    Public Shared Sub TextFrame()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Using docloc As DocumentLock = doc.LockDocument()
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "select mtext")
                    peo.SetRejectMessage(vbCr & "selected object is not mtext")
                    peo.AddAllowedClass(GetType(MText), True)
                    Dim id As ObjectId = ed.GetEntity(peo).ObjectId
                    Using mtext As MText = CType(tr.GetObject(id, OpenMode.ForWrite), MText)
                        If mtext Is Nothing Then
                            Return
                        End If
                        Using newtxt As MText = mtext.Clone()
                            newtxt.Rotation = 0
                            newtxt.Width = mtext.ActualWidth
                            newtxt.Height = mtext.ActualHeight
                            Dim off As Double = newtxt.TextHeight * 0.35
                            Dim ext As Extents3d = newtxt.GeometricExtents
                            Dim p1 As Point2d = New Point2d(ext.MinPoint.X - off, ext.MinPoint.Y - off)
                            Dim p3 As Point2d = New Point2d(ext.MaxPoint.X + off, ext.MaxPoint.Y + off)
                            Dim p2 As Point2d = New Point2d(p3.X, p1.Y)
                            Dim p4 As Point2d = New Point2d(p1.X, p3.Y)
                            Dim pline As New Polyline(4)
                            pline.AddVertexAt(0, p1, 0, 0, 0)
                            pline.AddVertexAt(1, p2, 0, 0, 0)
                            pline.AddVertexAt(2, p3, 0, 0, 0)
                            pline.AddVertexAt(3, p4, 0, 0, 0)
                            pline.Closed = True
                            pline.ColorIndex = 1
                            pline.ConstantWidth = newtxt.TextHeight * 0.13
                            pline.TransformBy(Matrix3d.Rotation(mtext.Rotation, ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis, mtext.Location))
                            Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                            Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                            btr.AppendEntity(pline)
                            tr.AddNewlyCreatedDBObject(pline, True)
                        End Using
                    End Using
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(vbCr & ex.Message & vbCr & ex.StackTrace)
                End Try
            End Using
        End Using
    End Sub
~'J'~
Hallex
Message 22 of 31 (270 Views)
08-18-2012 01:38 PM in reply to: Hallex
Here is example how to create the mtext (I'm using syntax fo A2010)
 <CommandMethod("mtx")> _
    Public Sub createMtext()
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using tr
            Dim strvalue As String = "first text line\Psecond text line\Pthird text line"
            Dim pt As Point3d = New Point3d(10, 20, 0)
            Dim mtx As New MText
            mtx.Location = pt
            mtx.SetDatabaseDefaults()
            mtx.TextStyleId = db.Textstyle
            mtx.TextHeight = db.Dimtxt
            mtx.Width = 0
            mtx.Contents = strvalue
            mtx.Attachment = AttachmentPoint.BottomCenter
            mtx.SetAttachmentMovingLocation(mtx.Attachment)
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
            btr.AppendEntity(mtx)
            tr.AddNewlyCreatedDBObject(mtx, True)
            mtx.Width = mtx.ActualWidth
            tr.Commit()
        End Using
    End Sub
~'J'~
Active Contributor
MGOMKD
Message 23 of 31 (256 Views)
08-20-2012 01:53 AM in reply to: Hallex
Hi Hallex,
I worked on your source code about stocking Polylines coordinates.
'Insertion du texte'
                                    Dim MyVertices as Point3d
Dim Coord as Long
Dim X as Double
Dim Y as Double
Dim Z as Double
For Coord = 0 To MyPolyLine.NumberOfVertices - 1 MyVertices = MyPolyLine.GetPoint3dAt(Coord) X = X + MyVertices.Coordinate(0) Y = Y + MyVertices.Coordinate(1) Z = Z + MyVertices.Coordinate(2) Next X = X / MyPolyLine.NumberOfVertices Y = Y / MyPolyLine.NumberOfVertices Z = Z / MyPolyLine.NumberOfVertices
 I use your function to obtain average X, Y and Z to insert MText in the middle of the piece!
Do you know how to obtain NumberOfVertices of "Region"?
You drive me on the right way! Thank you Hallex.
Hallex
Message 24 of 31 (247 Views)
08-20-2012 04:25 AM in reply to: MGOMKD
You have to calculate middle point using GetPoint3dAt method,
like this:
Dim cp as point3d= pline.GetPoint3dAt((pline.endparam-plne.startparam)/ 2)
then change mtext attachment like this:
mtx.location=cp
mtx.Attachment = AttachmentPoint.MiddleCenter etc...
~'J'~
Active Contributor
MGOMKD
Message 25 of 31 (244 Views)
08-20-2012 05:25 AM in reply to: Hallex
Great source code Hallex, but GetPoint3d method doesn't appear with "Region".
I found a another way to get midpoint by using "Centroid", i used it when i wrote source code in VBA.
'Déclaration variable'
Dim MyRegion As AcadRegion = TryCast(MyEnt, Entity)
acMText = New MText() X = MyRegion.Centroid(0) Y = MyRegion.Centroid(1) Z = MyRegion.Centroid(2)
With acMText acMText.SetDatabaseDefaults() acMText.Location = New Point3d(X, Y, Z) acMText.Attachment = AttachmentPoint.MiddleCenter acMText.TextHeight = acHeightText acMText.Contents = i End With
acBlkTblRec.AppendEntity(acMText) acTrans.AddNewlyCreatedDBObject(acMText, True)
 Centroid only works with "Region".
Hallex
Message 26 of 31 (240 Views)
08-20-2012 05:47 AM in reply to: MGOMKD
Sorry I've  thought you told me about Polyline coordinates,
Glad you got it to work by yourself
Cheers :smileyhappy:
~'J'~
Active Contributor
MGOMKD
Message 27 of 31 (238 Views)
08-20-2012 05:59 AM in reply to: Hallex
Your help is always welcome, and I understant more and more the structure of AutoCAD.
Thanks a lot.
Hallex
Message 28 of 31 (228 Views)
08-20-2012 08:36 AM in reply to: MGOMKD
I used same way but a bit different one, see if thisis  working for you
    ''  Imports System.Reflection
    ''  Imports Autodesk.AutoCAD.Interop.Common
    ''------------------------------------    WH    ------------------------------''
    <CommandMethod("LabelArea", "lar", CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
    Public Shared Sub CreateRegionFromPline()
        Try
                Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf + "Select Polyline: ")
                peo.SetRejectMessage(vbLf + "You have to select closed Polyline!")
                peo.AddAllowedClass(GetType(Polyline), False)
                Dim res As PromptEntityResult = ed.GetEntity(peo)
                If res.Status <> PromptStatus.OK Then Return
                Dim ent As Entity = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), Entity)
                Dim pline As Polyline = TryCast(ent, Polyline)
                If Not pline.Closed Then Return
                Dim copy As Polyline = pline.Clone
                If Not copy.IsWriteEnabled Then copy.UpgradeOpen()
                btr.AppendEntity(copy)
                tr.AddNewlyCreatedDBObject(copy, True)
                Dim dbcoll As New DBObjectCollection()
                dbcoll.Add(copy)
                Dim regColl As New DBObjectCollection()
                regColl = Region.CreateFromCurves(dbcoll)
                Dim reg As Region = DirectCast(regColl(0), Region)
                btr.AppendEntity(reg)
                tr.AddNewlyCreatedDBObject(reg, True)
                tr.TransactionManager.QueueForGraphicsFlush()
                Dim obj As Object = reg.AcadObject
                Dim dbl() As Double = TryCast(obj.GetType().InvokeMember("Centroid", BindingFlags.GetProperty, Nothing, obj, Nothing), Double())
                Dim cp As Point3d = New Point3d(dbl(0), dbl(1), pline.Elevation)
                ed.WriteMessage(vbLf + "{0}" + "{1}", cp.X, cp.Y)
                mtx.Location = cp
                mtx.Width = 0
                mtx.Contents = String.Format("{0:f3}", pline.Area)
                If copy IsNot Nothing Then
                    copy.Erase()
                End If
                If reg IsNot Nothing Then
                    reg.Erase()
                End If
                tr.Commit()
            End Using
            ed.WriteMessage((vbLf + ex.Message & vbLf) + ex.StackTrace)
        Finally
        End Try
    End Sub
~'J'~
Active Contributor
MGOMKD
Message 29 of 31 (197 Views)
08-22-2012 01:30 AM in reply to: Hallex
Hi Hallex,
Thank you for your code, I really have to work on it! Not quietly but surely!
Another way to obtain Region.Centroid.
Dim MyRegion As AcadRegion = MyEnt.AcadObject
Z = 0
With acMText
End With
 Coding is so fascinating!
Hallex
Message 30 of 31 (181 Views)
08-23-2012 04:47 AM in reply to: MGOMKD
So, the issue is solved?
~'J'~
You are not logged in.
Ask the Community
